02635 - Tuner Not Enabled/Activated / VW TDi 2009 Radio issues with Aux input
Geoff
C?ID=226192
Hello, Ive owned this car from new, few years ago the Aux input for the Radio suddenly stopped working, that is to say, I cannot even select "aux" by pressing the CD button twice.
Other than that radio works great, CD, tuner, and Satellite radio, just no "aux" . Any suggestions would be much appreciated.
Sunday,09,August,2015,10:33:17:22623
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 3VWRL71K99M065556   License Plate: JETTA TDI
Mileage: 195420km-121428mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWRL71K99M065556   Mileage: 195420km-121428miles
Address 01: Engine
Address 03: ABS Brakes
Address 08: Auto HVAC
Address 09: Cent. Elect.
   Revision: 00000000    Serial number: AUZ4Z7H0435814
   Coding: 0000100
   VCID: 334BF13B526D37B9A29-8066
                    Reset counter: 113
                    Mileage: 195423 km
                    Time: 19:05:58
Address 15: Airbags
Address 16: Steering wheel
   Part No SW: 1K0 920 974 N    HW: 1K0 920 974 N
   Component: KOMBIINSTRUMENT 3HL 2418
   Revision: V0003000    Serial number: VWX7Z0H824U00R
   Coding: 0023203
   VCID: 3957C3137001CDE9685-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 230808F2001817
   Coding: E9807F070013021002
   VCID: 354FCF235C1929898CD-8060
Address 1C: Position Sensing
   Component: IMMO            3HL 2418
Address 44: Steering Assist
Address 46: Central Conv.
Address 52: Door Elect, Pass.
Address 56: Radio
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 72: Door, Rear Right
End-------------------------(Elapsed Time: 00:54)--------------------------
Was the ignition ON during this scan? There are a whole lot of systems that "Cannot be reached", including everything related to the radio.
Also, please update your VCDS to the current version.
Geoff
C?ID=226192
Here is the new scan, with newest software rev, and ignition turned on.
Monday,10,August,2015,07:32:43:22623
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 016 N    HW: 03L 906 022 J
   Component: R4 2,0L EDC G000SG  8680
   Revision: 12H01---    Serial number: VWX7Z0H824U00R
   Coding: 0050072
   VCID: 3D5FD7036429F1D67D-8068
006472 - Control Module 2 for Cooling Fan
               P1948 - 000 - Output Short Circuit - Intermittent
                    Mileage: 195399 km
                    Time: 18:44:16
                    RPM: 1311 /min
                    Speed: 21.0 km/h
                    Temperature: 36.9°C
                    Temperature: 90.9°C
                    Temperature: 29.7°C
                    Lambda: 34.7 %
                    Lambda: 0.0 %
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D492800FF881002E9921F00423000
   VCID: 74C93227D7E3709E42-8020
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78D106170B8B14FE6E-802C
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Revision: 00H54000    Serial number: 00000001089339
   Coding: 14018E234004150007140000001400000008730B5C000120000000000000
   VCID: 3245F43FAD773EAE90-8066
   Component: Wischer 091008 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00101100
                    Fault Frequency: 9
                    Reset counter: 139
                    Mileage: 191385 km
                    Voltage: 13.55 V
   Coding: 0000100
   VCID: 334BF13B526D37A69B-8066
                    Reset counter: 113
                    Mileage: 195423 km
                    Time: 19:05:58
   Revision: 05034000    Serial number: 003B6M074UYV
   Coding: 0013889
   VCID: 6CF92A474FD3A85E9A-8038
   Subsystem 2 - Serial number: 6332MSME3E636421A
   Subsystem 3 - Serial number: 6342MSME3E632D59R
   Subsystem 4 - Serial number: 6351HSME181C1D317
   Subsystem 5 - Serial number: 6361HSME18022E3FD
   Subsystem 6 - Serial number: 63727SME18141820S
   Subsystem 7 - Serial number: 63827SME177C083A9
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0002021
   VCID: 042962E74743401E72-8050
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Coding: 0023203
   VCID: 3957C3137001CDF651-806C
   VCID: 354FCF235C192996B5-8060
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T3E9504
   Coding: 0000003
   Revision: 72009005    Serial number: 00000507188913
   Coding: 0001205
   VCID: 6FC33D4B7EC55346BF-803A
                    Fault Status: 01100101
                    Reset counter: 113
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 128
                    Mileage: 194579 km
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A75EC5F85A7766E28-807E
   Coding: 13900F880186281B0904058FB0880F0488DC00
            000 -  -  - Intermittent
                    Fault Frequency: 35
                    Reset counter: 152
                    Mileage: 194131 km
                    Time: 01:09:12
   Revision: 72009005    Serial number: 00000028488830
   Coding: 0001204
   VCID: 70C13E3763FB4CBEA6-8024
                    Reset counter: 113
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2239917
   Coding: 0010400
   VCID: 2977135380A17D7621-807C
00003 - Control Module
            014 - Defective
   Revision: 12006001    Serial number: 00000003487709
   Coding: 0001168
   VCID: 76CD082F019F628E7C-8022
00934 - Electric Window Motor; Rear Left (V26)
                    Reset counter: 113
   Coding: 0100101
   Revision: 12006001    Serial number: 00000003537727
   Coding: 0001168
   VCID: 77D3052B06951B8667-8022
                    Fault Status: 01111000
                    Fault Frequency: 42
                    Reset counter: 113
                    Mileage: 195232 km
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 113
                    Fault Status: 01111100
                    Fault Frequency: 10
                    Reset counter: 113
End-------------------------(Elapsed Time: 01:24)--------------------------
Well, your radio thinks it's "Defective", meaning it has identified some sort of internal problem.
   Coding: 0010400
            014 - Defective
Not sure what to tell you beyond that.
Santos
With all the ignition switch codes, i wouldnt be surprised if the radio is confused.
try recoding the radio: 0010401
Geoff
C?ID=226192
Santos, thank you. That took care of the problem. :)
