- Joined
- Jun 21, 2015
- Messages
- 18
- Reaction score
- 0
- VCDS Serial number
- C?ID=250378
Hello!
I am having some issues working on my 2013 Q5 3.0. I have found most vag com upgrades work, except for a few key ones that I would like to do. I have not found a list updated with the codes that work with my MMI 3 2013 Q5, does anyone have a newly updated list by chance? It's odd that some of the codes from pre-facelift work, and some from the facelift list work with my car, is it because it was built at end of one, and very start of the other perhaps?
For example:
When I follow all directions for aux circulation, it blacks out my normal ac screen, and sometimes enables aux, and sometimes does not. I have done it several times with same result.
I have since turned off Aux Air, it's out of MMI now, and still working on getting AC MMI tab to be live. It is there, just not active, so I can't properly operate AC.
My daytime running lights are not working when set to "ON," although in MMI it says they are set to on? Coding from another upgrade must have changed this?
I can't turn off "lights on" annoying dinging, none of the posted code lists have seemed to work yet, any suggestions?
Does anyone have the codes, or new upgrade lists, used on a 2013 Q5 3.0TFSI, or similar MMI?
Anyone know how go fix these, or run into same on similar, that can help?
Thank you for any help, below is the last Auto-Scan:
For example:
VCDS Version: Release 15.7.0 Running on Windows 8.1 x86
Data version: 20150729
Thursday,06,August,2015,16:36:22:41105
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 36 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1DGAFP9DA037579 Mileage: 135010km-83891miles
Address 01: Engine (J623-CTUC) Labels: None
Part No SW: 8R0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0001
Revision: --H07---
Coding: 2A2A0034052601060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218R0907551A 001002
ROD: EV_ECM30TFS0218R0907551A.rod
VCID: 3620EC0489E7EC8EBC-8062
6322 - Air Intake System
P307A 00 [032] - Flow too Low
Mileage: 134974 km
Date: 2015.08.06
Time: 13:12:11
6307 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
Mileage: 134974 km
Date: 2015.08.06
Time: 13:12:12
Readiness: 0000 0100
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 AM HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1003
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
ROD: EV_TCMAL551211_AU48.rod
VCID: 085C52FCB393AA7E1E-805C
Part No SW: 8R0 907 379 AK HW: 8R0 907 379 AK
Component: ESP8 quattro H09 0080
Coding: 191D1C
Shop #: WSC 06335 000 00000
VCID: 095A57F8A099D37601-805C
Fault Frequency: 32
Reset counter: 61
Mileage: 134804 km
Date: 2015.08.03
Time: 18:04:28
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x1094
Hex Value: 0x0000
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Coding: 0DA54040000000000000
VCID: 044446CC87BB8E1E72-8050
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01011120121276
Coding: 66183A8080
Shop #: WSC 06335 123 12345
VCID: 393AE738B0F903F651-806C
01207 - Control Module for Auxiliary Heater (J364)
Reset counter: 60
Mileage: 134804 km
Date: 2015.08.03
Time: 18:02:53
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000502516202
Coding: 2600000181388FE01F00408300003D0D4F9CC748A6090221000008004000070100000034000000
Shop #: WSC 52140 001 104857
VCID: 78BC223CCB73DAFE6E-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 121023 H11 0050
Coding: 01D513
Component: G397_RLFS H06 0002
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
03110 - Active Steering Control Module (J792)
Reset counter: 59
Mileage: 134853 km
Date: 2015.08.04
Time: 14:38:10
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 C HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0054
Revision: 00000000 Serial number: 16101201280001
Coding: 010181
VCID: 3A38F834B5FF08EE58-806E
Reset counter: 100
Mileage: 134853 km
Date: 2015.08.04
Time: 14:31:21
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD90YDUE
Coding: 303634313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 47DE91C0FE0D6506D7-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000BAGZ
Serial number: 6334MSME73204C001
Serial number: 6344MSME7320447FG
Serial number: 6352QSME6221304A5
Serial number: 6362QSME30233E76G
Serial number: 63732SME47241758.
Serial number: 63832SME49245350W
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LJQ000H8
Coding: 000037
VCID: 43C685D0C23549260B-8016
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 T HW: 8R0 920 980 T
Component: KOMBIINSTR. H35 0556
Revision: 00000000 Serial number: UWH5AAZAD
Coding: 035D22001301D705020001
VCID: 4AD8A8F4E51F986EC8-801E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0055
Revision: 1Y060027 Serial number: 2741Y12A220261
Coding: 80CF07FF00
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000038219943
Coding: 01581B00000000000000
VCID: 42C880D4DD2F402E00-8016
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000043523668
Coding: 011D13205E00440004
VCID: 4DD2A3E814718F56ED-8018
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0014514699
Coding: 000000000000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X.rod
VCID: 45C29BC8C401771625-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0186866330
Coding: 01261E3A20FA70958730053600040007
Shop #: WSC 45202 123 104857
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H04 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H04 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813007565802
VCID: 2D12C36874B1AF56CD-8078
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000043760237
VCID: 4CD4AEECEF6B865EFA-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000123198
ROD: EV_ParkiBrake_AU48.rod
VCID: 383CE23C83F31AFEAE-806C
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156KC0C7662995
Coding: 020007010000000001
VCID: 2404264C277B6E1E12-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R1 035 746 G HW: 8R1 035 746 B
Component: H-BNT-NA H44 0901
Revision: -------- Serial number: 204JR0C7540151
Coding: 1A0200060205E3FF47029F5E0B000403140000000100000000
VCID: 3B36FD30BAC531E643-806E
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Component: CD-Database 4949
Fault Frequency: 10
Reset counter: 61
Mileage: 135019 km
Date: 2015.08.06
Time: 16:27:12
Bin. Bits: 00000000 00001010
Bin. Bits: 00000000 00000001
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000043649578
Coding: 010C13204000240004
VCID: 46C09CC4F1077C0E2C-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07--- Serial number: 525PA8-J2XA4EL
Coding: 1020010
VCID: 3424D60C579BFE9E82-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000071759842
Shop #: WSC 45202 000 1048576
End-------------------------(Elapsed Time: 02:59)----------------
