Internal, I replied to E?ID=269727 asking him to try the V383 and V381 Output Tests after the new flap motors are calibrated using the Convertible Top Flap Initialisation procedure.
I await the results with interest - lets see if his Flap Output Test works or not
We received an update today but I didn't get explicit permission to use it online so I'll summarize below.
This was a market 2008 TT Roadster 2.0T
Date of production 18.03.2008 | Sales type 8J952X | Engine Code BPY | Transmission Code KNC
> Address 26: Auto Roof Labels: 8J7-959-255.lbl
> Part No: 8J7 959 255 B
> Component: 256 VSG TT H14 0110
The previously revised
Convertible Top Flap Initialisation procedure fixed that vehicle with new flap motors installed:
When performing repairs/replacement of the Flap Motors it will be necessary to perform the Adaption of the Flap Motors.
Ref: TSB 61-09-02 or 2018777 for NAR (North American Region) vehicles.
The faults associated with the bulletins include: 02000, 03246, and 03247.
After diagnosis and repairs per TPI 2015779 (Convertible top adjustment options) perform the following Output Test:
[Select]
[26 - Auto Roof]
[Output Tests - 03]
[Select] Selective Output Tests
[Choose]Convertible Top Flap Initialisation
[Start]
Operate the Convertible Top throughout a complete Open/Close sequence BEFORE exiting the Output Test function.
[Done, Go Back]
[Close Controller, Go Back - 06]
After completing it all fault codes cleared and the roof functions were normal.
The technician did compare MVBs before and after repairs in addition to testing the Output tests in question. I will remove those steps from the page but the original text was:
Additional Output Tests on both right and left Flap Motors can be completed if needed:
[Select]
[26 - Auto Roof]
[Output Tests - 03]
[Choose] - Motor for Convertible Top Flap Left (V383)
[Start]
Wait until the Flap has open and closed,
[Choose] - Motor for Convertible Top Flap Right (V381)
[Start]
Wait until the Flap has open and closed, then
Operate the Convertible Top 3 times, Open/close = 1 time, do this 2 more times.
[Done, Go Back]
Check Measuring Value Blocks Group 008 to verify correct values of the Flap Motors.
The MVBs did not change and the flaps did not move. In conclusion, the V383 and V381 Outputs didn't do anything on a vehicle in good working order with the latest motors.
