Results 1 to 4 of 4
Thread: back to stock and DRL problems
    Jul 2015
    Smile back to stock and DRL problems
    im new to the vdcs wolrd, also my English is not so good.
    How can I reset my vcds settings back to stock
    Problems
    1: my drl is active on my MFI but they don't come on when i disengage the E-brake
    2: I bought a uspmotorsports RBF automatic headlight conversion kit and im having some problems for when I turn on my parking light my low beam also comes on
    3: im getting the light indicator because i installed some led back up lights, how can I clear that up
    Jul 2015
    Chassis Type: AJ (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
    VIN: WVWGD7AJ7CW092017   Mileage: 63590km-39512miles
    Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Component: 2.0l R4/4V TFSI     0010
       Revision: E3H26---    Serial number:
       Coding: 0403010818070160
       VCID: 78FFBAB40B0718E156F-802D
    005924 - Starter Interlock Signal
                   P1724 - 000 - Short to Ground - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        RPM: 161 /min
                        Load: 81.9 %
                        Temperature: 96.0C
                        Temperature: 55.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 10.922 V
    050217 - Implausible Data Received from Steering Column Control Module
                   U0429 - 000 -  - Intermittent
                        Mileage: 63080 km
                        Date: 2015.07.17
                        Time: 13:02:29
                        RPM: 1231 /min
                        Load: 9.0 %
                        Temperature: 96.0C
                        Temperature: 54.0C
                        Voltage: 12.065 V
    005386 - Engine Off Timer Performance
                   P150A - 000 -  - Intermittent
                        Mileage: 63353 km
                        Date: 2015.07.19
                        Time: 19:54:30
                        RPM: 1016 /min
                        Load: 14.5 %
                        Temperature: 87.0C
                        Temperature: 73.0C
                        Voltage: 11.938 V
       Revision: 00H31001
       Coding: 114B600C492B00FC880B06E592200041B70800
       VCID: 7BF5A5B8FA3133F93BD-802E
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001015
       Coding: 0000001002
       VCID: 000FD2549BD750216EF-8055
       Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 6F180A1A90272AC4008800C170000D4448052086434D8D20E48420240040
       VCID: 3D716BA0A4A5FDC9459-8068
       Component: Wischer 12081  26  0512
       Coding: 009795
                        Fault Status: 00100111
                        Fault Frequency: 10
                        Reset counter: 240
                        Mileage: 62827 km
                        Date: 2015.07.15
                        Time: 11:13:36
                            Term 15 Off
                        Voltage: 12.30 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 24
                        Reset counter: 200
                        Mileage: 63341 km
                        Date: 2015.07.19
                        Time: 18:21:32
                        Voltage: 12.30 V
                            Term 50 On
                        Fault Frequency: 24
                        Reset counter: 200
                        Mileage: 63341 km
                        Date: 2015.07.19
                        Time: 18:22:12
                        Voltage: 12.30 V
                            Term 50 On
       Serial number: 003GVRA0GXDK
       Coding: 00003131
       VCID: 3F8D11A8A6A9EFD9575-806A
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--00060WHR00
       Serial number: 3572MSME2C6B1363ZZZ.
       Serial number: 3582MSME7E015362ZZZW
       Serial number: 3512QSME76035D61ZZZW
       Serial number: 3522QSME4E445A46ZZZ0
       Serial number: 35527SME4A1B1728ZZZK
       Serial number: 35627SME5B341728ZZZI
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90422KGT000RI
       Coding: 108A140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 72EB889CA57B72B168B-8027
       Serial number: 0428503
       Coding: 820000
       Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
       Coding: 270F01
       VCID: 3663748C89932E91843-8063
       Revision:   H42       Serial number: 030811F1001134
       Coding: 350002
       VCID: 356173809C9525898D9-8060
       Component: IMMO          H03 0607
       VCID: 6ADB90FC8DABBA71D0B-803F
       Revision: A1001003    Serial number: 7660641902
       Coding: 020000
       VCID: 2959AFF0402D7169191-807C
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H32 0265
       Serial number: VWZAZ2L8465234
       Coding: 04000401040005000000100A
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2345BDD82A01AB3953D-8076
       Component: NAR_V2  0002
              B11CF 53 [008] - Deactivated
                        Reset counter: 238
                        Mileage: 40448 km
                        Date: 2014.01.04
                        Time: 19:42:07
       Coding: 0001204
       VCID: 31694790A8FD09A9D11-8064
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 74     3201
       Revision: 00H20000
       VCID: 34674E8457EF3C81BA7-8061
       Coding: 0001204
       VCID: 326B489CADFB32B1A8B-8067
       Coding: 1446940
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000022
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 356173805C9525898D9-8060
       Coding: 0001168
       VCID: 3663748C41932E91843-8063
    End-------------------------(Elapsed Time: 02:20)--------------------------
    In the Debug sub-folder where you installed VCDS, typically C:\Ross-Tech\VCDS\Debug\ there will be a file called Coding-Log.txt; it will contain a list of all the changes you made.
    Jul 2015
    thank you for your help
