How to code XM Radio Module
JamesNYC
C?ID=208762
I am attempting to install an Audi OEM XM Radio module that I bought off eBay. I get the error code "0144 Control Module Incorrectly Coded 000— —". Also, "Fault Status 01100000. Priority 5". And "No Internal Module Malfunction".
This has happened with 2 separate modules. I can find no reference for recoding an XM module. Nor a VCDS Equipment number for the XM module. So I don't know how address the module directly.
Can someone help me recode? I am using a Hex-Net.
Thank you,
James
PS I saw an Audi factory bulletin about 6 weeks ago online for installing an XM module. It did say something about recoding and I remember the number "99", I think. However I cannot find this bulletin now.
We're gonna need to see a full scan from your car with the XM radio installed in order to have much chance of giving you the help you need.
JamesNYC
C?ID=208762
Really? Hmm, apparently that can't be done with a Mac, right? I don't know anyone who has a Windows machine anymore. I'll ask around.
VCDS Mobile has an Auto-Scan function.
JamesNYC
C?ID=208762
Just as I posted my previous comment I realized I was an idiot. Duh, I didn't think to use my MacBook instead of the iPhone. I am auto scanning as i write this. Hmm found a new error. "Bank 1: Camshaft A (Intake)
P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) - Intermittent"
What the heck is that?
I'll post the whole auto scan in a few. Why did you mention in another thread that you wanted 2 scans?
I asked for two scans from people with Windows PCs who could run the 'classic' version of VCDS for Windows -- we've been having some issues with that.
Edit/PS: Since you're installing an XM radio in a car that didn't have one to begin with, this belongs in the retrofits section, not "Car Repair", so I'm moving it.
JamesNYC
C?ID=208762
Well the auto scan seems to be stuck "trying Address 65". It's spent about 10 minutes at it.
This is what I have so far:
VCDS-Mobile
Auto-Scan
Progress: 75%
Trying address 65...
Chassis Type:8E
Scan:
	 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
	 69 75 76 77
VIN: WAUKF78E77A208152
Address 01: Engine	Labels:06F-907-115-AXX.lbl
	Part Number SW: 8E1-910-115	HW: 8E0907115D
	Component: 2.0l R4/4V TFSI      0030
	Revision: 5EH15---	Serial Number:
	Coding: 010C010A180F0120
	Shop #: WSC 06335 000 00000
	VCID: DF81B07F5F340CEDDC90-808A
001090 - EVAP Emission Control Sys
	P0442 - 001 - Small Leak - MIL ON
001109 - EVAP System
	P0455 - 001 - Large Leak Detected - MIL ON
000017 - Bank 1: Camshaft A (Intake)
Address 03: ABS Brakes	Labels:8E0-910-517.lbl
	Part Number SW: 8E0-910-517-J	HW: 8E0614517BH
	Component: ESP8 quattro    H06  0140
	Revision: 00000000	Serial Number: 00000000000000
	Coding: 0004526
	VCID: 2E1F9DBBE81E5565A7E6-807B
No fault codes found.
Address 09: Cent. Elect.	Labels:8E0-907-279-8EC.lbl
	Part Number SW: 8E0-907-279-N
	Component: int. Lastmodul  USA 0907
	Coding: 11023
	Shop #: WSC 65536 000
	VCID: 3D3DAAF73578AFFD2E4C-4B3C
Address 0F: Digital Radio	Labels:8E0-035-593-XM.lbl
	Part Number SW: 8E0-035-593-A	HW: 8E0035593A
	Component: SDAR XM              0010
	Serial Number: AUZ4Z7C5016183
	VCID: 2711689FC7E4062D64A0-5184
02633 - Antenna for Satellite Tuner
Address 15: Airbags	Labels:8E0-959-655-94.lbl
	Part Number SW: 8E0-959-655-H	HW: 8E0959339B
	Component:    Airbag 9.41  H13  4240
	Revision: 91H13424	Serial Number: 0036N0G0VUL1
	Coding: 0032607
	VCID: 3C3BA7F32E62B7F51972-8069
	Subsystem 1 - 	Part Number: 8E0-910-339-B
	Component: BF-Gewichtsens. 002  0070
	Serial Number: 3J0BG
	Subsystem 2 - 	Serial Number: 6332DRB40462C730H
	Subsystem 3 - 	Serial Number: 6342DRB4049C9025P
	Subsystem 4 - 	Serial Number: 6352ARB401F35C82S
	Subsystem 5 - 	Serial Number: 6362ARB401F36FAA0
Address 17: Instruments	Labels:8E0-920-9xx-8EC.lbl
	Part Number SW: 8E0-920-951-N	HW: 8E0920951N
	Component: KOMBI+WFS 4     H14  0200
	Revision: 0200    	Serial Number: 00000000000000
	Coding: 0023268
	Shop #: WSC 09108 444 83949
	VCID: 352DB2D70D4867BDE63C-5184
Address 55: Xenon Range	Labels:4F0-910-357.lbl
	Part Number SW: 4F0-910-357-F	HW: 4F0907357F
	Component: AFS 1           H01  0020
	Revision: 00000001	Serial Number:
	Coding: 0000019
	VCID: 29156EA7D1F0325D72B4-807C
	Subsystem 1 - 	Part Number: 8E0-941-329-A
	Component: AFS-Modul links H04  0020
	Subsystem 2 - 	Part Number: 8E0-941-329-A
	Component: AFS-Modul rechtsH04  0020
Address 56: Radio	Labels:8J0-035-1xx-56.clb
	Part Number SW: 8E0-035-195-AC	HW: 8E0035195AC
	Component: R Symphony2+    H06  0221
	Revision: 00H06000	Serial Number: AUZ1Z4G4446579
	Coding: 0610122
	Shop #: WSC 09108 444 58755
	VCID: 68932BA30A7AC955AD3A-5184
10 minutes is too WAY too long. The above should be enough to figure out coding for your radio.
What CodeBlock version are you running? It would be shown in the results if it had finished, but you can see it on the About screen.
JamesNYC
C?ID=208762
CodeBlock V0.41
FW version: 0.176
Dataset: 00000026
LSN: 000100-000109-64BDD2-C00000-DECC03-2F7A26-64
VSN: 000029-00B004-010000-002600-180008-0100FF-FF0000-6954
JamesNYC
C?ID=208762
anyone have any thoughts?
Andy
Sector 7G
HC424490
Try changing the Coding in 56-Radio from:
0610122
to:
0614122
... and let us know the results. That should tell it that it has Satellite radio. The 0F module itself doesn't seem to need or support Coding.
JamesNYC
C?ID=208762
Thanks Andy. I'll give it a try later or tomorrow.
Meanwhile, I removed the XM module and I got the same error code. Or, in other words, there was no change. So that supports your suggestion.
However, the Symphony head unit acknowledges the SAT radio, and I can get the preview channel. When I have tried to activate the module (through SiriusXM) it attempts to load the channels, but then goes back to the preview. So would the head unit keep the XM module from activating? I would have thought that was something that had something to do with the XM module or Sirius XM alone.
Anyway, I'll give it a try.
Dana
Western PA, USA
Coding: 0610122
0610122
0x?0xxx: Options 2
+1 = Digital Sound System
+2 = CD-Changer
+4 = Satellite Radio
That 56-Radio isn't coded for Satellite Radio. Did you try changing the coding to 0650122 yet?
JamesNYC
C?ID=208762
So wait, do I want to change it to 0614122 as Andy suggests. Or 0650122 as Dana suggests?
(the real problem with testing this that I have to call SiriusXM to try and get them to activate it. They are in the Philippines).
Also, I am still puzzled as to how coding the head will allow the XM module to fully activate with SiriusXM. But, again, I'll test it and see.
I'm with Dana. I think Andy got dyslexic on which digit needs the 4 added to its present value.
Don't you need to read off some code from the radio's display to give to Sirius/XM to activate the received?
