Results 1 to 10 of 15
Thread: How to code XM Radio Module
    Mar 2014
    I am attempting to install an Audi OEM XM Radio module that I bought off eBay. I get the error code "0144 Control Module Incorrectly Coded 000— —". Also, "Fault Status 01100000. Priority 5". And "No Internal Module Malfunction".
    This has happened with 2 separate modules. I can find no reference for recoding an XM module. Nor a VCDS Equipment number for the XM module. So I don't know how address the module directly.
    Can someone help me recode? I am using a Hex-Net.
    Thank you,
    James
    PS I saw an Audi factory bulletin about 6 weeks ago online for installing an XM module. It did say something about recoding and I remember the number "99", I think. However I cannot find this bulletin now.
    We're gonna need to see a full scan from your car with the XM radio installed in order to have much chance of giving you the help you need.
    Mar 2014
    Really? Hmm, apparently that can't be done with a Mac, right? I don't know anyone who has a Windows machine anymore. I'll ask around.
    VCDS Mobile has an Auto-Scan function.
    Mar 2014
    Just as I posted my previous comment I realized I was an idiot. Duh, I didn't think to use my MacBook instead of the iPhone. I am auto scanning as i write this. Hmm found a new error. "Bank 1: Camshaft A (Intake)
    P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) - Intermittent"
    What the heck is that?
    I'll post the whole auto scan in a few. Why did you mention in another thread that you wanted 2 scans?
    I asked for two scans from people with Windows PCs who could run the 'classic' version of VCDS for Windows -- we've been having some issues with that.
    Edit/PS: Since you're installing an XM radio in a car that didn't have one to begin with, this belongs in the retrofits section, not "Car Repair", so I'm moving it.
  7. #7
    Mar 2014
    Well the auto scan seems to be stuck "trying Address 65". It's spent about 10 minutes at it.
    This is what I have so far:
    VCDS-Mobile
    Auto-Scan
    Progress: 75%
    Trying address 65...
    Chassis Type:8E
    Scan:
    	 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    	 69 75 76 77
    VIN: WAUKF78E77A208152
    Address 01: Engine	Labels:06F-907-115-AXX.lbl
    	Part Number SW: 8E1-910-115	HW: 8E0907115D
    	Component: 2.0l R4/4V TFSI      0030
    	Revision: 5EH15---	Serial Number:
    	Coding: 010C010A180F0120
    	Shop #: WSC 06335 000 00000
    	VCID: DF81B07F5F340CEDDC90-808A
    001090 - EVAP Emission Control Sys
    	P0442 - 001 - Small Leak - MIL ON
    001109 - EVAP System
    	P0455 - 001 - Large Leak Detected - MIL ON
    000017 - Bank 1: Camshaft A (Intake)
    Address 03: ABS Brakes	Labels:8E0-910-517.lbl
    	Part Number SW: 8E0-910-517-J	HW: 8E0614517BH
    	Component: ESP8 quattro    H06  0140
    	Revision: 00000000	Serial Number: 00000000000000
    	Coding: 0004526
    	VCID: 2E1F9DBBE81E5565A7E6-807B
    No fault codes found.
    Address 09: Cent. Elect.	Labels:8E0-907-279-8EC.lbl
    	Part Number SW: 8E0-907-279-N
    	Component: int. Lastmodul  USA 0907
    	Coding: 11023
    	Shop #: WSC 65536 000
    	VCID: 3D3DAAF73578AFFD2E4C-4B3C
    Address 0F: Digital Radio	Labels:8E0-035-593-XM.lbl
    	Part Number SW: 8E0-035-593-A	HW: 8E0035593A
    	Component: SDAR XM              0010
    	Serial Number: AUZ4Z7C5016183
    	VCID: 2711689FC7E4062D64A0-5184
    02633 - Antenna for Satellite Tuner
    Address 15: Airbags	Labels:8E0-959-655-94.lbl
    	Part Number SW: 8E0-959-655-H	HW: 8E0959339B
    	Component:    Airbag 9.41  H13  4240
    	Revision: 91H13424	Serial Number: 0036N0G0VUL1
    	Coding: 0032607
    	VCID: 3C3BA7F32E62B7F51972-8069
    	Subsystem 1 - 	Part Number: 8E0-910-339-B
    	Component: BF-Gewichtsens. 002  0070
    	Serial Number: 3J0BG
    	Subsystem 2 - 	Serial Number: 6332DRB40462C730H
    	Subsystem 3 - 	Serial Number: 6342DRB4049C9025P
    	Subsystem 4 - 	Serial Number: 6352ARB401F35C82S
    	Subsystem 5 - 	Serial Number: 6362ARB401F36FAA0
    Address 17: Instruments	Labels:8E0-920-9xx-8EC.lbl
    	Part Number SW: 8E0-920-951-N	HW: 8E0920951N
    	Component: KOMBI+WFS 4     H14  0200
    	Revision: 0200    	Serial Number: 00000000000000
    	Coding: 0023268
    	Shop #: WSC 09108 444 83949
    	VCID: 352DB2D70D4867BDE63C-5184
    Address 55: Xenon Range	Labels:4F0-910-357.lbl
    	Part Number SW: 4F0-910-357-F	HW: 4F0907357F
    	Component: AFS 1           H01  0020
    	Revision: 00000001	Serial Number:
    	Coding: 0000019
    	VCID: 29156EA7D1F0325D72B4-807C
    	Subsystem 1 - 	Part Number: 8E0-941-329-A
    	Component: AFS-Modul links H04  0020
    	Subsystem 2 - 	Part Number: 8E0-941-329-A
    	Component: AFS-Modul rechtsH04  0020
    Address 56: Radio	Labels:8J0-035-1xx-56.clb
    	Part Number SW: 8E0-035-195-AC	HW: 8E0035195AC
    	Component: R Symphony2+    H06  0221
    	Revision: 00H06000	Serial Number: AUZ1Z4G4446579
    	Coding: 0610122
    	Shop #: WSC 09108 444 58755
    	VCID: 68932BA30A7AC955AD3A-5184
    Last edited by Uwe; 04-18-2014 at 10:39 PM. Reason: Wrapped CODE tags around Auto-Scan
  8. #8
    10 minutes is too WAY too long. The above should be enough to figure out coding for your radio.
    What CodeBlock version are you running? It would be shown in the results if it had finished, but you can see it on the About screen.
    Mar 2014
    CodeBlock V0.41
    FW version: 0.176
    Dataset: 00000026
    LSN: 000100-000109-64BDD2-C00000-DECC03-2F7A26-64
    VSN: 000029-00B004-010000-002600-180008-0100FF-FF0000-6954
  10. Likes Uwe liked this post
  11. #10
    Mar 2014
    anyone have any thoughts?
