Results 1 to 7 of 7
Thread: 10763 - Starter Enable from Selector Lever Sensor System
    Jul 2015
    Australia
    Audi S3 - Transmission fault
    Anyone know what this '10763 - Starter Enable from Selector Lever Sensor System' fault is? If I clear it is returns immediately the car is started.
    VCDS Version: 15.6.1.0 (x64)
    Data version: 20150612
    VIN: WAUZZZ8V7F1066210   License Plate:
    Mileage: 2776km-1724mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F 6C
              A9
    VIN: WAUZZZ8V7F1066210   Mileage: 2776km-1724miles
    Address 01: Engine (J623-CJXF)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1D00322426010B3004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
       ROD: EV_ECM20TFS0208V0906259A.rod
       VCID: 3E5DCC60A1C53CCFCB-806A
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4517
       Revision: 05853104    Serial number: TFK01408301182
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 1F6311E4060F55C7E0-804A
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 62634000003039
       Coding: 31F193A254262A720179030141C3698CC92A5480C08296F6024150B88608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 45AFA38CC4136F178A-8010
       Revision: 00021000    Serial number: 0347138261
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A55C070BDED10EFF7-806E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Revision: 20026000    Serial number: 00000000442259
       Coding: 03100014110000011000000000001500
       VCID: 334BED549A87E1A734-8066
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011425503786
       Coding: 07151C46C24106FD03804004B10807A80800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 002172989BB18A3FF9-8054
       Slave 1:
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A
       Component: WWS371 140906  041 0585
       Serial number:         140922103007
       Coding: 0A47F7
       Slave 2:
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 23188426
       Coding: 00006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
       Serial number: 16 07 2014  00000964
       Serial number: 000000000ZY14211163U
       Serial number: 00000000000030601259
       Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO3286189B
       Coding: 901E00
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 G    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0051
       Revision: --------    Serial number: 39411424702132
       Coding: 0130160051
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_AU37.rod
       VCID: 43ABBD94CA275127A4-8016
       Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
       Component: DAEMPFUNGS-SG H08 0066
       Serial number:       100414013
       ASAM Dataset: EV_AudiMagneRide 002003
       ROD: EV_AudiMagneRide_AU37.rod
       VCID: 41A7B79CD03B4337B6-8014
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR024MU3
       Coding: 98CCC000000000005C54000000C800000065
       Subsystem 1 - Part No SW: -----------    HW: 480 002 209 14
       Serial number: 35767000000FD4E0211Z
       Subsystem 2 - Part No SW: -----------    HW: 480 002 209 14
       Serial number: 35867000000D77B0211S
       Subsystem 3 - Part No SW: -----------    HW: 480 401 209 14
       Serial number: 3516502B7176A6C5B1BO
       Subsystem 4 - Part No SW: -----------    HW: 480 401 209 14
       Serial number: 3526502B7176A6C411FI
       Subsystem 5 - Part No SW: -----------    HW: 480 400 808 14
       Serial number: 35565029D16FC222914G
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 25091404401008
       Coding: A018
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 0A3550B0AD8DC06FA7-805E
       Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
       Component: KOMBI         H02 4291
       Coding: 23AD181A3B9000080101EA001000000000000000
       VCID: 3D5FCB6CACC327D7D2-8068
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2186
       Revision: --------    Serial number: 19091410801337
       Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
       ROD: EV_GatewConti.rod
       VCID: 42A5B890D53D582FAF-8016
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 04 09 2014  D0009098
       Serial number: 0654124403
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Component: Haldex4Motion H52 7076
       Serial number: HA1-00011.08.14
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_AU21.rod
       VCID: 46ADA480F915640F83-8012
       Revision: 00000000    Serial number: 14000254147001
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3449EE489F89E69F2D-8060
       Serial number: 30081406070208
       Coding: 005D1E204101040000001002
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 40A1B298DB314A3FB9-8014
       Coding: 8303
       ROD: EV_SteerAssisMQB.rod
       VCID: 354FD34C94F3FF971A-8060
       Serial number: 14091402090331
       Coding: 005D16204D01040000001002
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 3FA3B164A6CF35C7C0-806A
       Component: AFS-ECU       H01 0091
       Coding: 01A600002B200200
       ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
       Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J
       Coding: E00100
       Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
       Component: LED LeiMo re.  H07 7540
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo rechts  H01 7040
       Coding: E00100
       Part No SW: 8V0 035 045 C    HW: 8V0 035 045 C
       Component: MU-H-N-RW     H43 0357
       Serial number: A307I0EB004045
       Coding: 017301080000000021510002000A00002F000226010001005E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       VCID: 3245E850659DE8AF3F-8066
       Engine Control Module 2:
       Subsystem 1 - Part No SW: V03 959 800 TE    HW: -----------
       Component: ROW 2015/2016  --- 0049
       Seat Adjustment Driver Side:
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201MP2
       Sound System:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000001081400040288
       Door Electronics Rear Left:
       Component: Gracenote  --- 4006
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 3041E2586B91DABF49-8064
       Part No SW: 8V0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0012
       Serial number: 140904201221
       VCID: 7DDF0B6CEC43E7D792-8028
    End-------------------------(Elapsed Time: 03:54)--------------------------
    HQ
    Ugh.. UDS modules
    First thing I'd want to look at is that data from the Gear Selector is matching up to what gear you have selected. In Advance Measuring Values, look for something like "Selector lever position - Shift Position" and this should show data based on the Gear Selector. Does the data match up?
    Jef
    Jul 2015
    Australia
    Ugh.. UDS modules
    Yes, if I log I can see the position values changes from P, R, N, D.
    Seems that if the vehicle engine is turned on the fault code appears once the gear selector is moved, but they then they auto clear when the ignition is turned off and I rescan for faults. See below 3 faults, then clears after ignition cycled.
    Monday,02,February,2015,19:57:13:45705
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    UDS Adaptation Channel: (1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln
    Stored value not active
    Friday,24,July,2015,13:03:58:45705
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
                    Address 02: Auto Trans       Labels: 0D9-927-770.clb
    Control Module Part Number: 0D9 300 012 L    HW: 02E 927 770 AQ
      Component and/or Version: DQ250-6A MQB  H53 4517
               Software Coding: 0014
                Work Shop Code: WSC 04742 780 00200
                  ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                           ROD: EV_TCMDQ250021.rod
                          VCID: 1F6311E4060F55D9775-804A
              P1734 00 [002] - -
    21153 - Gear 1
              P072C 00 [002] - Not Selectable
    21159 - Gear R
              P072B 00 [002] - Not Selectable
    10731 - Valve 3 in Transmission Part 1
              P174A 00 [002] - Electrical malfunction
    Friday,24,July,2015,13:11:54:45705
    Is there an actual performance/problem issue you are exhibiting or just is this data that is being displayed in VCDS while making observations?
    Jul 2015
    Australia
    No problem or dash warning. The car self clears the faults when the ignition is off for a minute or so, and only re-appears when started.
    I think you maybe picking up the shadow in UDS on network.
    VCDS seems to dig deeper I have seen in UDS controllers, that the VAS scanner seems to ignore.
    I see that the 0x19 Gateway is reporting everything OK in the installation list, so I would ignore this behavior.
    If there was an imperative issue you would see faults elsewhere I believe in other controllers.
  7. #7
    Jul 2015
    Australia
    Thanks for you help
