Results 1 to 10 of 11
Thread: P0011/p0012
    Jul 2015
    P0011/p0012
    So I've been getting both the P0011 and P0012 CEL's for a while. After I clear these codes they seem to only come back a day or two later and only during a cold start. Not sure if that information helps. I've very new to VCDS, so bare with me. Here are the last few maintenance items that I've done that might help with these codes:
    Timing Belt (changed twice) last changed at 146,317 miles
    Cam Chain Tensioner changed at 160,011 miles
    Cam Position Sensor changed at 174,161 miles
    Current Mileage = 174,633
    Based on what I have read, it looks like I need to check the following?
    Oil pickup tube
    Cam chain off by tooth
    Timing chain off by tooth
    Timing
    Fuel pump relay
    Are there any measuring tests that I can do with VCDS to help with this problem? Hope I'm posting this stuff correctly. Below is my latest scan
    I also posted this on the ross-tech forum within www.vwvortex.com, but haven't gotten much direction yet.
    Thanks in advance!
    Tuesday,21,July,2015,19:40:56:00449
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: 3VWSE69M92M068099   License Plate:
    Mileage: 281210km-174735mi   Repair Order:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWSE69M92M068099   Mileage: 281210km-174735miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 HS
       Component: 1.8L R4/5VT     G   0008
       Coding: 07500
       Shop #: WSC 79153
       VCID: 76E3AAC852C6FC91443-5142
       3VWSE69M92M068099     VWZ7Z0A4051449
    16395 - Bank 1: Camshaft A (Intake)
                P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
    17544 - Fuel Trim: Bank 1 (Add)
                P1136 - 35-10 - System too Lean - Intermittent
    Readiness: 0000 1001
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 K
       Component: ASR FRONT MK60      0103
       Coding: 0018945
       VCID: 326B56D8AE2EA0B1A8B-5124
       Part No: 6Q0 909 605 F
       Component: 04 AIRBAG VW6  0202 0004
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A7B7EF8265E58F160B-4B02
       Part No: 1J5 920 926 H
       Component: KOMBI+WEGFAHRSP VDO V57
       Coding: 15230
       VCID: 346750C0043AAE81BA7-5124
                49-00 - No Communications
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EF9CD030A2D2A19EF-5124
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO  003
       Coding: 00258
       Shop #: WSC 00066
       VCID: 377D67CC154C45999F5-4B02
       Component: 1H Tőrsteuer.FS KLO 0002
       Component: 1H Tőrsteuer.BF KLO 0004
       Component: 1H Tőrsteuer.HL KLO 0002
       Component: 1H Tőrsteuer.HR KLO 0002
                27-00 - Implausible Signal
    End-------------------------(Elapsed Time: 05:26)--------------------------
    Jul 2015
    From the info I've gathered it seems I should next check the oil pickup tube/screen. I'm not sure if the fuel pump relay could contribute to this. I mean, the car doesn't have problems starting, but the fuel pump doesn't prime anymore when I open the door.
    Jul 2015
    go to basic settings 94. it is the basic settings for the cam adjuster. VCDS lists the procedure incorrectly in basic settings. but you need to hold your foot on brake and push gas pedal to 2000 RPM that will activate the basic settings. if it fails there is an issue with either the timing of the cam chain or a broken guide on the adjuster tensioner.
    Also seems dumb but when is the last time you changed your engine oil and are you using anything lighter than 5w-40? there is a tech bulletin related to a similar issue with low/dirty engine oil.
    How long has this been occurring?
    Jul 2015
    Coreyj, thanks for the response. I've normally used 5w-30 as that's only what I've been able to find locally. I recently got the oil changed about 100 miles ago and with 5w-30 Liqui Moly. This CEL has been on for months...maybe 8 months or so.
    I'll run the VCDS check and report back.
    Jul 2015
    Basic Settings Group 94
    So I'm not sure if I was doing this correctly. I held the brake and I'm not able to press the gas...it's like the gas is disabled for block 94, but I can rev the engine for block 91 which I have also posted. Am I doing something wrong? I'm sorry, but I'm very new to VCDS so if I'm not doing this correctly then you'll have to explain it step by step. I searched on Google, but I couldn't find any instructions on how to test this.
    So I'm not sure how to 'Test On'?
    [IMG] by Alex Perez, on Flickr[/IMG]
    Jul 2015
    Ok...I must have done something wrong, but it looks like I was able to get a test result...
    System Not okay
    [IMG]Untitled by Alex Perez, on Flickr[/IMG]
  7. #7
    Jul 2015
    Quote Originally Posted by MiamiBourne View Post
    System Not okay
    When you push the gas pedal down you have to put it to the floor then the rpms raise automatically to 2000rpm.
    now that you have ran 94 and we see that you have a problem.
    the next step is to do the output tests on the advanced functions on the 01-engine controller. scroll through until you get to the cam adjuster solenoid. you should hear it click on and off. if no noise is heard then the solenoid is not activating and it needs to be replaced. (most may not agree with the following but its free to try: i have had some luck in the past by tapping the solenoid with a light hammer while simultaneously putting 12v on the connector of the solenoid and it has made the solenoid start working.)
    If you do hear/feel it clicking then the next step is to blip the engine up to around 4000rpm then fully release the pedal and if you hear a rattling sound that is the cam chain with slack in it as a result of broken guides on the adjuster. if no noise is heard its still a good idea to remove the valve cover and physically look with a flash light at the chain guides upper and lower to assure they are intact.
    If nothing seems out of the ordinary put the timing belt in TDC and inspect the cam timing marks.
    hope this helps. good luck
    Corey
  8. Likes jyoung8607, Uwe liked this post
  9. #8
    Jul 2015
    Ok, I ran the output tests and I heard the solenoid clicking. It sounded like a loud clock...tic tock? I revved the engine to 4k and let off the gas and didn't hear a rattle. But it's hard to hear for that with my downpipe and intake. Also in regards to a rattle after revving the engine. I do here something that sounds like a rattle after the engine warms up from a cold start. I was told though that the sound might be the secondary air pump shutting off.
    I'm not able to myself pull the valve cover, check the guides or the timing belt, so I'll have my mechanic check that out.
    Below are the videos.
    solenoid click: https://youtu.be/VvxiwnM9k0A
    revving to 4k: https://youtu.be/xjj1WNveXJQ
    engine idle: https://youtu.be/wLtaJh6U4vw
    Thanks again!
  10. #9
    Jul 2015
    Not sure that it helps but here is a vid of my cold start: https://youtu.be/G9bGA0POf2E
    Thanks.
  11. #10
    Jul 2015
    some other "rare" possibilities is the screen on the cam adjuster is clogged with debris. or oil is leaking into the cam position sensor housing and messing up the readings..?
