P0011/p0012
MiamiBourne
C?ID=252494
So I've been getting both the P0011 and P0012 CEL's for a while. After I clear these codes they seem to only come back a day or two later and only during a cold start. Not sure if that information helps. I've very new to VCDS, so bare with me. Here are the last few maintenance items that I've done that might help with these codes:
Timing Belt (changed twice) last changed at 146,317 miles
Cam Chain Tensioner changed at 160,011 miles
Cam Position Sensor changed at 174,161 miles
Current Mileage = 174,633
Based on what I have read, it looks like I need to check the following?
Oil pickup tube
Cam chain off by tooth
Timing chain off by tooth
Timing
Fuel pump relay
Are there any measuring tests that I can do with VCDS to help with this problem? Hope I'm posting this stuff correctly. Below is my latest scan
I also posted this on the ross-tech forum within www.vwvortex.com, but haven't gotten much direction yet.
Thanks in advance!
Tuesday,21,July,2015,19:40:56:00449
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: 3VWSE69M92M068099   License Plate:
Mileage: 281210km-174735mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
          75 76
VIN: 3VWSE69M92M068099   Mileage: 281210km-174735miles
Address 01: Engine        Labels: 06A-906-032-AWP.lbl
   Part No: 06A 906 032 HS
   Component: 1.8L R4/5VT     G   0008
   Coding: 07500
   Shop #: WSC 79153
   VCID: 76E3AAC852C6FC91443-5142
   3VWSE69M92M068099     VWZ7Z0A4051449
16395 - Bank 1: Camshaft A (Intake)
            P0011 - 35-10 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
            P1136 - 35-10 - System too Lean - Intermittent
Readiness: 0000 1001
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 00066 000 00000
   VCID: 326B56D8AE2EA0B1A8B-5124
   Part No: 6Q0 909 605 F
   Component: 04 AIRBAG VW6  0202 0004
   Coding: 12340
   Shop #: WSC 00066
   VCID: 3A7B7EF8265E58F160B-4B02
   Part No: 1J5 920 926 H
   Component: KOMBI+WEGFAHRSP VDO V57
   Coding: 15230
   VCID: 346750C0043AAE81BA7-5124
            49-00 - No Communications
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EF9CD030A2D2A19EF-5124
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO  003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 377D67CC154C45999F5-4B02
   Component: 1H Tõrsteuer.FS KLO 0002
   Component: 1H Tõrsteuer.BF KLO 0004
   Component: 1H Tõrsteuer.HL KLO 0002
   Component: 1H Tõrsteuer.HR KLO 0002
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 05:26)--------------------------
MiamiBourne
C?ID=252494
From the info I've gathered it seems I should next check the oil pickup tube/screen. I'm not sure if the fuel pump relay could contribute to this. I mean, the car doesn't have problems starting, but the fuel pump doesn't prime anymore when I open the door.
Coreyj
C?ID=42955
go to basic settings 94. it is the basic settings for the cam adjuster. VCDS lists the procedure incorrectly in basic settings. but you need to hold your foot on brake and push gas pedal to 2000 RPM that will activate the basic settings. if it fails there is an issue with either the timing of the cam chain or a broken guide on the adjuster tensioner.
Also seems dumb but when is the last time you changed your engine oil and are you using anything lighter than 5w-40? there is a tech bulletin related to a similar issue with low/dirty engine oil.
How long has this been occurring?
MiamiBourne
C?ID=252494
Coreyj, thanks for the response. I've normally used 5w-30 as that's only what I've been able to find locally. I recently got the oil changed about 100 miles ago and with 5w-30 Liqui Moly. This CEL has been on for months...maybe 8 months or so.
I'll run the VCDS check and report back.
MiamiBourne
C?ID=252494
Basic Settings Group 94
So I'm not sure if I was doing this correctly. I held the brake and I'm not able to press the gas...it's like the gas is disabled for block 94, but I can rev the engine for block 91 which I have also posted. Am I doing something wrong? I'm sorry, but I'm very new to VCDS so if I'm not doing this correctly then you'll have to explain it step by step. I searched on Google, but I couldn't find any instructions on how to test this.
So I'm not sure how to 'Test On'?
[/url] by Alex Perez, on Flickr[/IMG]
MiamiBourne
C?ID=252494
Ok...I must have done something wrong, but it looks like I was able to get a test result...
System Not okay
[/url]Untitled by Alex Perez, on Flickr[/IMG]
Coreyj
C?ID=42955
System Not okay
When you push the gas pedal down you have to put it to the floor then the rpms raise automatically to 2000rpm.
now that you have ran 94 and we see that you have a problem.
the next step is to do the output tests on the advanced functions on the 01-engine controller. scroll through until you get to the cam adjuster solenoid. you should hear it click on and off. if no noise is heard then the solenoid is not activating and it needs to be replaced. (most may not agree with the following but its free to try: i have had some luck in the past by tapping the solenoid with a light hammer while simultaneously putting 12v on the connector of the solenoid and it has made the solenoid start working.)
If you do hear/feel it clicking then the next step is to blip the engine up to around 4000rpm then fully release the pedal and if you hear a rattling sound that is the cam chain with slack in it as a result of broken guides on the adjuster. if no noise is heard its still a good idea to remove the valve cover and physically look with a flash light at the chain guides upper and lower to assure they are intact.
If nothing seems out of the ordinary put the timing belt in TDC and inspect the cam timing marks.
hope this helps. good luck
Corey
MiamiBourne
C?ID=252494
Ok, I ran the output tests and I heard the solenoid clicking. It sounded like a loud clock...tic tock? I revved the engine to 4k and let off the gas and didn't hear a rattle. But it's hard to hear for that with my downpipe and intake. Also in regards to a rattle after revving the engine. I do here something that sounds like a rattle after the engine warms up from a cold start. I was told though that the sound might be the secondary air pump shutting off.
I'm not able to myself pull the valve cover, check the guides or the timing belt, so I'll have my mechanic check that out.
Below are the videos.
solenoid click: https://youtu.be/VvxiwnM9k0A
revving to 4k: https://youtu.be/xjj1WNveXJQ
engine idle: https://youtu.be/wLtaJh6U4vw
Thanks again!
Coreyj
C?ID=42955
some other "rare" possibilities is the screen on the cam adjuster is clogged with debris. or oil is leaking into the cam position sensor housing and messing up the readings..?
MiamiBourne
C?ID=252494
Thanks CoreyJ. I'll look into what you suggested as well.
Saturday I had my oil changed to the proper 5w-40 (Rotella T6) to see if that helps. The car runs a little smoother and quieter but this morning my CEL came back on. So I ran the auto scan on VCDS and the P0011 is back. I also ran the camshaft adjustment test again (basic settings, group 94), but this time it said 'System Ok'. I did notice during this test as I let go of my rev's to 2k rpm I heard a rattle. I posted a video of my revs and the rattle. Could this be my cam chain being loose?
https://youtu.be/ZaIWwB6HxyA
Here is the test of the camshaft adjustment I ran:
