Security Access - ABS Module
veeeight
C?ID=162411
Hello
Trying to code TPMS on A3 8V - but the ABS module requires the Security Access number?
Dana
Western PA, USA
The only SA code I'm aware of is 40168 but that is usually a Basic Setting prerequisite rather than Coding. The A3 8V isn't sold here but please let us know what the repair history is and post an Auto-Scan so we can see what this car is made of.
veeeight
C?ID=162411
Hello, sorry for the delay :(
40168 appears to be accepted initially, but then if you try and do any Adaptations, it doesn't work.
So I'm trying to adapt TPMS active, not successful.
Also - Will there eventually be English Translations for the 09 module Adaptations?
Thanks in advance :)
Here's the scan. MQB car:
Friday,18,April,2014,19:42:16:42635
VCDS Version: 14.4.0.3
Data version: 20140411
VIN: WAUZZZ8V1EAnnnnnn   License Plate: nnxxnnn
Mileage: 531km-329mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WAUZZZ8V1EAnnnnnn   Mileage: 531km-329miles
Address 01: Engine (J623-CJXC)       Labels: None
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0006
   Revision: --H09---
   Coding: 0A1D00322466010B2004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0218V0906259 001008
   ROD: EV_ECM20TFS021_AU37.rod
   VCID: 7DF7C4F6EC57E5D32B-8028
Readiness: 1110 0001
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4319
   Revision: 05852204    Serial number: TFK01402042564
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 2441D1922F7D741B04-8071
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6052400000005C
   Coding: 30F193A254252A75017C070641C5690CC92A5480E08296F6F84150080608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 7CF1C9F2F74DECDB1C-8029
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Revision: 20026000    Serial number: 00000000259244
   Coding: 00100004000000011000000000001100
   VCID: 336322CE9A93E3A38D-8066
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011406202231
   Coding: 07041A46C20122F503044004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7BF3CAEEF243EBE315-802E
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119
   Component: WWS370 140210  041 0580
   Serial number:         140212235052
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 22318800
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 18 11 2013  00000408
   Serial number: 000000000ZY140230CY2
   Serial number: 00000000000059007530
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831406500051
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 387915E283F500FBB8-806D
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 J
   Component: ACC3          H09 0395
   Serial number: 13011403030020
   Coding: 003E1301FE0309
   ASAM Dataset: EV_ACCBoschMQB 001022
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 428D770AD5295A2B16-8017
   Serial number: 003M2R05KFHP
   VCID: 4B935A2EE2639B63E5-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 702 14
   Serial number: 35767000000B88D00F0/
   Subsystem 2 - Part No SW: -----------    HW: 480 002 702 14
   Serial number: 35867000000E78D00F00
   Subsystem 3 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3516502B512F6291C044
   Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3526502C112F629411B2
   Subsystem 5 - Part No SW: -----------    HW: 480 400 901 14
   Serial number: 3556502C312FAE33E19R
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 002 14
   Serial number: 2286502AF14D3E73B09T
   Pedestrian protection crash sensor; passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 002 14
   Serial number: 2296502AF14D3E71A11K
   Center pedestrian protection crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 801 14
   Serial number: 23065029F13013E4E354
   Part No SW: 8V0 953 521 BR    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 25021408490456
   Coding: E418
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0B139A2EA2E3DB6325-805E
   Part No SW: 8V0 920 970 R    HW: 8V0 920 970 R
   Component: KOMBI         H03 2220
   Coding: 278D000A2E8046000181EA00100000
   Revision: --------    Serial number: 0001680707
   Coding: 030100042B085A005B0002781C0B00000001000000000000000000000000
   ROD: EV_GatewLear_AU37.rod
   VCID: 3F8B7EFEA6DB37C379-806A
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 24 02 2014  E0349861
   Serial number: 7961602603
   Serial number: 21021404081306
   Coding: 001C0E205C01040100001003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40897D02DB25483B00-8015
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 35671CD694E7FD93A3-8060
   Serial number: 22021406071282
   Coding: 001C06205E01040100001003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 01AE000001000000
   VCID: 75E7DCD6D467BD9363-8020
   Part No SW: 8V0 035 020 C    HW: 8V0 035 020
   Component: MU-H-ND-EU    H42 0281
   Serial number: A305B0E7508560
   Coding: 01730001FF0A000021111101000A00002F00020701000100DE
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 2B533AAE42A3BB63C5-807E
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 PR    HW: -----------
   Component: ECE 2014  --- 0078
   Seat Adjustment Driver Side:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9DY200C77
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 R    HW: 8V0 919 614 D
   Component: ControlUnit_H  H64 0766
   Serial number: C1000025121300020007
   Door Electronics Rear Left:
   Component: Gracenote  --- 1008
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140129200348
Angel
Navarra-Spain
C?ID=98003
In the A4 B8, code 61378 is valid for modifying TPMS in module 3. If you want test it... :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Angel - NOT cool! First off the B8 A4 uses a completely different supplier for the ESP which almost always means there is a different security access code used and second you should never suggest codes blind unless you are willing to take the risk and pay for a new module if need be. Especially with the recent ESP systems there are some codes which are one-way unless you know the proper counter-code and we have had cases where customers played with random codes and never got things back to the way they were...
veeeigh - TPMS coding should be possible w/o the need for any security access code - please use
30F193A254252A75017C070641C5690CC92A5480E08296F6F84150388608
as new coding and let us know if that worked for you.
veeeight
C?ID=162411
Hi Sebastian,
Many thanks for the reply - before I try this on the ABS module, I will also have to code the 09 Module to get the display in the DIS or MMI ?
Is this correct?
Many thanks :)
veeeight
C?ID=162411
Hi guys/gals
The supplied code from Sebastian:
Seems to have worked, and enabled TPMS in the ABS module.
However - I still had to find our how to enable the functions (storing pressure etc.) in the MMI, and maybe code the DIS. So I had a look around......
I ensured all the following adaptations were set to "active" or already "active" in the 5F module:
And also Byte 4 Bit 0 in 17 Instruments was ticked
This then gave the TMPS menu in the MMI
My questions are these:
1. What Bytes and Bits tick box do you have to tick, to get TPMS enabled in the 03 ABS module? This is for someone else with the same car.
2. Do I actually need to enable Byte 4 Bit 0 on the 17 Instruments module? I'm guessing there might be a message in the DIS when the TPMS alarms, but I don't know.
3. Have I missed anything?
Many thanks in advance.
Here is the scan of my car, after these modifications.
Tuesday,29,April,2014,17:36:48:42635
VCDS Version: 14.4.2.0
Mileage: 1025km-636mi   Repair Order:
VIN: WAUZZZ8V1EAnnnnnn   Mileage: 1025km-636miles
   Revision: --H09---
   VCID: 7DF7C4F6EC57E5D33C-8028
   VCID: 2441D1922F7D741B13-8071
          P1734 00 [002] - -
                    Fault Status: 00000010
                    Fault Frequency: 0
                    Reset counter: 0
                    Time: 00:00:00
   Coding: 30F193A254252A75017C070641C5690CC92A5480E08296F6F84150388608
   VCID: 7CF1C9F2F74DECDB0B-8029
   VCID: 336322CE9A93E3A39A-8066
   VCID: 7BF3CAEEF243EBE302-802E
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0000050011
   VCID: 387915E283F500FBAF-806D
   VCID: 428D770AD5295A2B01-8017
   VCID: 4B935A2EE2639B63F2-801E
   Coding: E418
   VCID: 0B139A2EA2E3DB6332-805E
   Coding: 278D000A2F8046000181EA00100000
   VCID: 3F8B7EFEA6DB37C36E-806A
   VCID: 40897D02DB25483B17-8015
   Coding: 8103
   VCID: 35671CD694E7FD93B4-8060
   VCID: 75E7DCD6D467BD9374-8020
   VCID: 2B533AAE42A3BB63D2-807E
   Sound System:
lukappaseidue
Italy
C?ID=211520
Hi Sebastian,
coul you help me to find the right coding to activate TPMS on my A3 8VA?
here my data:
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Coding: 12F162A220270A740180060401C82548460450806080A4F20259000405
VCID: 7DF78817ECCB6FD204-8028
THANK YOU VERY MUCH
