Results 1 to 10 of 19
Thread: Need Steering Column Access Code
    Jul 2015
    This 2013 Passat was involved in a crash. The body shop replaced the Air Bag module and the Clock Spring/Steering Column module. I was able to successfully code the Air Bag module but I can't code the Steering Column module with a valid Access Code. When I hover over the code box there is no pop-up with a valid Access Code. I am currently using the beta version 15.6.1 and I have also tried the older version 14.10. I have attached an auto scan. Can you provide me with a valid Access Code?
    VCDS Version: Beta 15.6.1
    Data version: 20150612
    Sunday,19,July,2015,19:16:32:61215
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 46 4F 52 56 62 72 77
    VIN: 1VWAH7A35DC144384   Mileage: 48660km-30235miles
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
       Component: 2,5l R5/4V      G01 4735
       Revision: T6H02---    Serial number:
       Coding: 0000075
       Shop #: WSC 09003 957 00200
       VCID: 73EFA456125A37A7F4-8026
    005699 - Please check DTC Memory of Electric Load Controller
                   P1643 - 000 -
                        Fault Frequency: 6
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 02:10:45
                        Load: 0.0 %
                        Temperature: 81.0C
                        Temperature: 50.0C
                        Absolute Pres.: 1010.0 mbar
    001384 - Cruise Control Switch (E45)
                   P0568 - 000 - Implausible Signal - Intermittent
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:08:09
                        Load: 0.0 %
                        Temperature: 63.0C
                        Temperature: 45.0C
    Readiness: 1010 0101
       Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
       Component: AQ 250 6F           2251
       Revision: 00H97000    Serial number:
       Coding: 0000840
       VCID: 0201F1925DE00E2FEF-8056
       Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
       Revision: 00H31001
       Coding: C54BC0F5492608FEA30E03EC921D1061A61000
       VCID: 7CFD8F6AFF0478DFA5-8028
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 561 907 426 A    HW: 561 907 426 A
       Component: AC Manuell    H02 0101
       Revision: 00001K07
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1933B6FE1876ADF71E-804C
       Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
       Component: BCM PQ35 B+   021 0068
       Revision: BH021001
       Coding: 6F200E18902B08D408800001160004480071008640801D60648060000C70
       VCID: 438F3496C27AC727A4-8016
                        Fault Status: 00101010
                        Reset counter: 218
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 04:05:58
                            Term 15 On
                        Voltage: 14.05 V
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM02SGJF
       Coding: 00005033
       Shop #: WSC 12345 123 12345
       VCID: 75EB9A4ED42E2997DA-8020
       Serial number: 6940000Y130000TWJP0X
       Coding: 303044
       Serial number: 3572MSME630B217AZZZX
       Serial number: 3582MSME020A217AZZZQ
       Serial number: 3516KSME5C5D2C23ZZZ0
       Serial number: 3526KSME0F146E23ZZZZ
       Serial number: 3556LSME36126D21ZZZS
       Serial number: 3566LSME25276721ZZZR
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Component: LENKS.MODUL   016 0162
       Revision: --X01---    Serial number: 20150313200567
       Coding: 7982A00000
       Shop #: WSC 01286 386 08256
       VCID: 0201F19295E00E2FEF-8056
       Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
       Component: E221__MFL-YVJ  H07 0022
       Serial number: 00000000000000881159
       Coding: 620000
    226827 - Turn Signal Switch
              B1144 13 [008] - Open Circuit
                        Reset counter: 217
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:08:46
    226839 - Turn Signal Switch
              B1144 11 [008] - Short to Ground
                        Reset counter: 217
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:08:45
    229127 - Cruise Control Switch
              B1154 11 [009] - Short to Ground
                        Reset counter: 177
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:06:28
    229147 - Cruise Control Switch
              B1154 13 [009] - Open Circuit
                        Reset counter: 177
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:06:28
       Part No SW: 561 920 960 C    HW: 561 920 960 C
       Component: KOMBI         H06 0705
       Coding: 230E01
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 17051303290218
       Coding: 461000
       VCID: 76E99D42C128228FD3-8022
       Component: IMMO          H06 0705
       VCID: 6AD1B9328D90F66F47-803E
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664696027
       Coding: 010100
       VCID: 2A5179324510366F87-807E
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0006668839
       Coding: 0404D5
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BBFECF652CA9FE7CC-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630130508065430
       Coding: 800000
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 00000008
       VCID: 6FE7A826BE72134710-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0006670831
       Coding: 0404D4
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CBDEFEA57C498DFC5-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
       Component: J389__TSG_HR  006 5470
       Serial number: 14102631130506175600
       Coding: 800000
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H03 0005
       Revision: -----07S    Serial number: VWZ4Z6N3574059
       Coding: 0100040002000B
       VCID: 254B8A0E2C0E1917AA-8070
                000 -  -
                        Reset counter: 177
                        Mileage: 48664 km
                        Date: 2015.07.17
                        Time: 03:05:22
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664482586
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A714972BDB086EFF7-806E
    End-------------------------(Elapsed Time: 03:05)--------------------------
    I don't see faults for security.........or CP.
    What about the faults at hand in 0x16 & 0x09 .......
    Why do you think you need a login?
    Jul 2015
    The fault is not for the vehicle security system. It is for the fault with the Cruise Control System which is due to the new Clock Spring/Steering Column module which is not coded for the correct vehicle installation. Looking at the long code data there is an option for "Cruise Control controlled via Turn Signal Lever". [IMG]2013 VW Passat - Steering Column Coding.png[/IMG] The Cruise Control does not operate and the body shop has already replaced the Turn Signal Switch Assy. prior to delivering the vehicle to me.
  4. Likes Uwe liked this post
    Use coding helper if application available, get old module install and get coding, or SVM at dealer.
    Jul 2015
    I have already used the coding helper. That is how I determined that the coding needs to be changed for this installation. After I selected the coding changes and clicked "Do It" the box displays: "Coding rejected. Error 31: Request out of range". I believe that the reason for this rejection is because I have not been able to log-in to Security Access without a valid Access Code. When I coded the Air Bag Module a valid Security Access Code was displayed in a pop-up box, but there is NO pop-up box in the Steering Column Module. Do you know of a valid Access Code for this module?
    Maybe contact paid tech support in the AM at RT.
    Have you verified the part # is correct for the attributes of PR-codes?
    "Error 31: Request out of range" is not generally indicative of needing a security access code. IMO, something else is wrong here, but I'm not exactly sure what.
  9. Likes Jack@European_Parts liked this post
  10. #8
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Correct - you get this popup error if the control unit doesn't support the operation - because the unit need to have another firmware or just need to be newer. Normally the last index of the units part number tells you which unit you have, and what's supports of functionality.
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  11. Likes Jack@European_Parts, Dana liked this post
  12. #9
    United States
    Providing PartsLink24 is correct that vehicle should have been born with HW# 5K0 953 569 H. The complete Auto-Scan prior to repairs would include both the SW and HW numbers in addition to the original coding so it couldn't hurt to plug the old one in at some point if you can't get it to accept reasonable coding.
    5K0 953 569 H (assuming that's correct) does supersede to 5K0 953 569 AL so I would try to paste this into the new coding: 098A140000
    If 098A140000 is accepted make sure all functions (horn, turn signals, high beam, CCS, etc) work and test drive it to see if the ABS/ESP is happy.
    If 098A140000 is rejected I would reinstall (or plug in) the old controller to rule out incorrect coding in addition to the incorrect new part.
    Edit: I originally missed the fact that this car does not have a electromechanical steering rack (#44) so I edited my original suggestion from 088A140000 -to- the current version of 098A140000
  13. Likes Jack@European_Parts, Uwe, jyoung8607 liked this post
  14. #10
    Jul 2015
    I have verified with the VW dealership the VIN to Clock Spring/Module part number to be correct which is the same as shown in the auto scan. The dealership tells me that there is no other index numbers for this part. When I checked ElsaWin for replacement instructions of the Clock Spring/Module (Steering Column Switch Module) it states that: "If a new steering column electronics control unit - J527- is installed, it muse be coded". I believe that the faults for the Cruise Control Switch are due to the new module not yet coded to this vehicle. Before I send this vehicle to the dealership I wanted to code the module myself which is why I am requesting the Security Access code. Please note that last year I had a different 2013 VW in which the Clock Spring/Module was also replaced and since I couldn't code that vehicle either I sent it to the dealership for programming. After the dealership completed the programing all of the fault DTCs were resolved. Is there any available Security Access Code for this module?
