I don't need fog lights (it's foggy like 1 day a year) so I installed low brightness LED fog lights so they act as Daytime running lights, they are the same brightness as the stock DRL's.
The fog lights already come on when the DRL LED light strip comes on by enabling Bit 3 in Byte 2.
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
But the problem is the fog lights turn OFF when the light sensing headlights come on at night or when overcast. I need to press the fog button to turn them back on.
How do I make the Fog lights automatically come on when the Low-beam Headlights come on in VCDS?
I tried looking for this Land Selection option so I could set it to Canada mode, but I cant find it in my car.
http://www.audiworld.com/forums/a8-...program-vcds-have-your-drl-foglights-2854619/ (Audi A8 2003-2009)
The Car is an Audi A5 (8T) Coupe 2011. Should be the same as the A4 (B8).
Saturday,18,July,2015,23:27:08:58148
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ8TXBA0xxxxx License Plate: xxxxxx
Mileage: 67330km-41836mi Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F
VIN: WAUZZZ8TXBA0xxxxx Mileage: 67330km-41836miles
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0009
Revision: E1H19---
Coding: 0114000C240F0160
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TFS8K2907115P A01011
ROD: EV_ECM20TFS0118K2907115AJ.rod
VCID: 3C777E5CB78883C1727-8069
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K1 927 156 G HW: 0B5 927 156 F
Component: 0B5 20TFSIRdW H05 0008
Revision: --H05--- Serial number: 0000000151
Coding: 000001
ROD: EV_TCMDL501.rod
VCID: 39796748B8BAB6E9691-806C
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
Component: ESP8 quattro H04 0020
Coding: 090500
VCID: 7F0D4950EE1E58D9175-802A
Part No SW: 8K0 907 064 CT HW: 8K0 907 064 CT
Component: BCM2 2.0 H05 0435
Coding: 051000
VCID: 0407C6BC87F83B014A7-8051
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001002301555
Coding: 08217025002400001000
VCID: 438505A0C276FC3933D-8016
Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
Component: KLIMA 3 ZONEN H08 0180
Revision: D0000000 Serial number: 01040220110280
Coding: 64166000
VCID: 76E3AC74C1241991443-8023
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial number: 00000000787767
Coding: 260058114034AF211609000000005D5D0F9D438802010141000000
Shop #: WSC 06325 123 12345
VCID: 3A7B7844B5BCBDF160B-806F
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 210111 H12 0070
Coding: 00FD11
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Fault Status: 00101100
Reset counter: 146
Mileage: 67278 km
Date: 2015.07.17
Time: 19:05:00
03207 - Charisma Switch Module
Reset counter: 106
Mileage: 67278 km
Date: 2015.07.17
Time: 19:12:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891104017555
Coding: 000101
VCID: 4A9B2884E55C2D71F0B-801F
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD092HPO
Coding: 30533433363030303030554A305238543053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 46831CB4F944C911143-8013
Serial number: 6334MSME590512241
Serial number: 6344MSME5C250B43G
Serial number: 6352QSME27080A68I
Serial number: 6362QSME470143546
Serial number: 63732SME5B043042S
Serial number: 63832SME5B041666$
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H07 0156
Revision: 00000000 Serial number: 20110204000998
Coding: 000036
VCID: 49991788E05A2669F91-801C
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 L HW: 8T0 920 931 L
Component: KOMBIINSTR. H40 0258
Revision: 00200000 Serial number: EHT23322C
Coding: AF07010002000008010000
VCID: 408F0AACD360E7212EF-8015
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E111200180
Coding: 00C303
VCID: 0305C5A082F63C3973D-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002302018
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C12224101120102
VCID: 53A535E032166CB983D-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0140762215
Coding: 01000E8000B904018030003280000000
Reset counter: 142
Mileage: 67182 km
Date: 2015.07.16
Time: 12:19:40
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: 52AB30E40D0C65B188B-8007
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000856537
VCID: 3467567C97D84B81BA7-8061
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
VCID: 3979674870BAB6E9691-806C
Part No SW: 4G0 035 056 HW: 4G0 035 056
Component: Radio U STD H52 0051
Revision: AB001007 Serial number: 469B+0B7667602
Coding: 040003020100000001
VCID: 5EB3D4D449D4B1D13C3-800B
03029 - Subwoofer (R157)
Fault Status: 00101011
Reset counter: 124
Voltage: 12.20 V
Part No SW: 8T2 035 754 G HW: 8T2 035 754 D
Component: H-BN-RW H51 0146
Revision: -------- Serial number: 485B00B7528088
Coding: 010A0102000681ED45000B0E000000030000
VCID: 3D717358A4928AC9459-8068
Subsystem 1 - Part No: 8R0 060 884 Q
Component: ROW 2010 0207
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Component: CD-Database 2712
Reset counter: 40
Mileage: 65327 km
Date: 2015.06.12
Time: 12:17:56
Voltage: 14.70 V
End-------------------------(Elapsed Time: 02:39)--------------------------
