How to automatically turn on Fog lights when the headlights turn on (Audi B8/8T)
A5Tronic
Australia
C?ID=248341
I don't need fog lights (it's foggy like 1 day a year) so I installed low brightness LED fog lights so they act as Daytime running lights, they are the same brightness as the stock DRL's.
The fog lights already come on when the DRL LED light strip comes on by enabling Bit 3 in Byte 2.
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
But the problem is the fog lights turn OFF when the light sensing headlights come on at night or when overcast. I need to press the fog button to turn them back on.
How do I make the Fog lights automatically come on when the Low-beam Headlights come on in VCDS?
I tried looking for this Land Selection option so I could set it to Canada mode, but I cant find it in my car.
http://www.audiworld.com/forums/a8-...program-vcds-have-your-drl-foglights-2854619/ (Audi A8 2003-2009)
The Car is an Audi A5 (8T) Coupe 2011. Should be the same as the A4 (B8).
Saturday,18,July,2015,23:27:08:58148
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ8TXBA0xxxxx   License Plate: xxxxxx
Mileage: 67330km-41836mi   Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F
VIN: WAUZZZ8TXBA0xxxxx   Mileage: 67330km-41836miles
Address 01: Engine (CL0MA-CDNC)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0009
   Revision: E1H19---
   Coding: 0114000C240F0160
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115P A01011
   ROD: EV_ECM20TFS0118K2907115AJ.rod
   VCID: 3C777E5CB78883C1727-8069
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K1 927 156 G    HW: 0B5 927 156 F
   Component: 0B5 20TFSIRdW H05 0008
   Revision: --H05---    Serial number: 0000000151
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 39796748B8BAB6E9691-806C
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
   Component: ESP8 quattro  H04 0020
   Coding: 090500
   VCID: 7F0D4950EE1E58D9175-802A
   Part No SW: 8K0 907 064 CT    HW: 8K0 907 064 CT
   Component: BCM2 2.0      H05 0435
   Coding: 051000
   VCID: 0407C6BC87F83B014A7-8051
   Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001002301555
   Coding: 08217025002400001000
   VCID: 438505A0C276FC3933D-8016
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0180
   Revision: D0000000    Serial number: 01040220110280
   Coding: 64166000
   VCID: 76E3AC74C1241991443-8023
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H30 0392
   Revision: 09030001    Serial number: 00000000787767
   Coding: 260058114034AF211609000000005D5D0F9D438802010141000000
   Shop #: WSC 06325 123 12345
   VCID: 3A7B7844B5BCBDF160B-806F
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 210111  H12 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 02532C
   Component: E1 - LDS  H03 0031
                    Fault Status: 00101100
                    Reset counter: 146
                    Mileage: 67278 km
                    Date: 2015.07.17
                    Time: 19:05:00
03207 - Charisma Switch Module
                    Reset counter: 106
                    Mileage: 67278 km
                    Date: 2015.07.17
                    Time: 19:12:00
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0080
   Revision: 11001001    Serial number: 36891104017555
   Coding: 000101
   VCID: 4A9B2884E55C2D71F0B-801F
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003JMD092HPO
   Coding: 30533433363030303030554A305238543053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 46831CB4F944C911143-8013
   Serial number: 6334MSME590512241
   Serial number: 6344MSME5C250B43G
   Serial number: 6352QSME27080A68I
   Serial number: 6362QSME470143546
   Serial number: 63732SME5B043042S
   Serial number: 63832SME5B041666$
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
   Component: Lenks.Modul   H07 0156
   Revision: 00000000    Serial number: 20110204000998
   Coding: 000036
   VCID: 49991788E05A2669F91-801C
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 931 L    HW: 8T0 920 931 L
   Component: KOMBIINSTR.   H40 0258
   Revision: 00200000    Serial number: EHT23322C
   Coding: AF07010002000008010000
   VCID: 408F0AACD360E7212EF-8015
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E111200180
   Coding: 00C303
   VCID: 0305C5A082F63C3973D-8056
   Component: J367-BDM  H07 0170
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001002302018
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C12224101120102
   VCID: 53A535E032166CB983D-8006
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0140762215
   Coding: 01000E8000B904018030003280000000
                    Reset counter: 142
                    Mileage: 67182 km
                    Date: 2015.07.16
                    Time: 12:19:40
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52AB30E40D0C65B188B-8007
   Revision: 00000003    Serial number: 00000000856537
   VCID: 3467567C97D84B81BA7-8061
   Part No: 8K5 907 357 B
   Component: Dynamische LWR  H02 0010
   VCID: 3979674870BAB6E9691-806C
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H52 0051
   Revision: AB001007    Serial number: 469B+0B7667602
   Coding: 040003020100000001
   VCID: 5EB3D4D449D4B1D13C3-800B
03029 - Subwoofer (R157)
                    Fault Status: 00101011
                    Reset counter: 124
                    Voltage: 12.20 V
   Part No SW: 8T2 035 754 G    HW: 8T2 035 754 D
   Component: H-BN-RW       H51 0146
   Revision: --------    Serial number: 485B00B7528088
   Coding: 010A0102000681ED45000B0E000000030000
   VCID: 3D717358A4928AC9459-8068
   Subsystem 1 - Part No: 8R0 060 884 Q
   Component: ROW 2010  0207
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Component: E0380 Bedient  H08 0100
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
            000 -  -
                    Reset counter: 40
                    Mileage: 65327 km
                    Date: 2015.06.12
                    Time: 12:17:56
                    Voltage: 14.70 V
End-------------------------(Elapsed Time: 02:39)--------------------------
rlarsen
Copenhagen, Denmark
C?ID=78998
Front Fog Lights stay on with High-beams
[09 – Cent. Elect.]
[Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 1 - Change 1 to 0
Rear Fog Lights stay on with High-beams
[09 – Cent. Elect.]
Bit 2 - Change 1 to 0
A5Tronic
Australia
C?ID=248341
I seen those codes before but aren't they for high beams only?
I don't think they affect the low beams (dipped beams).
Correct me if I'm wrong.
rlarsen
Copenhagen, Denmark
C?ID=78998
They are the only coding I can come up with - what happen if you use the coding ??
The Fogs doesn't turn off when low and/or high beams are on here in Europe - so a coding exist.
Gizmo
S.E.Kent UK
C?ID=49193
The problem arises when you have any LED DRL lit in the dark, they are so bright they blind oncoming traffic, which is why OE LED DRL’s automatically dim to an acceptable level when the dip beam is turned on.
A5Tronic
Australia
C?ID=248341
Have doubts but I'll give it a try anyway.
A5Tronic
Australia
C?ID=248341
The brightness of the fogs are the same as the stock DRL's so I'm not worried about dazzling other drivers.
As rlarsen said the fogs dont turn off in Europe so there must be a way, most likely a Land selection option hidden away somewhere or an unknown byte in 09: Cent. Elect.
Gizmo
S.E.Kent UK
C?ID=49193
I think riarsen is referring to that fact that the fogs can be coded to stay on once they have been physically turned on,
I assume your headlight switch is the same as we get in Europe... i.e. you pull the switch out to turn the foglight on.
If your foglights are the same brightness as your OE DRL’s with the headlights off then surely they will be brighter than the OE DRL’s when you have the headlights on? (as the OE ones will dim down)
rlarsen
Copenhagen, Denmark
C?ID=78998
On the North Americas models the fogs switches off when high beams are on - but not with low beams on.
Here in Europe the fogs doesn't switch off with low- or high beam on.
Gizmo
S.E.Kent UK
C?ID=49193
But when you physically turn the lightswitch to off the foglight position of the switch springs back in (to the off position) so when you turn the lights on again you would need to physically pull the switch back out to turn the foglights back on?
rlarsen
Copenhagen, Denmark
C?ID=78998
Yes, that's right - and I can't see any problems with that.
On my cars I normally have an AUTO position, where I just leave it on - the lights then switches on/off automatically, and if I want the fogs on (if the need is there because of fog), then I just pull the switch, and push it in again when I want to turn it off.
In some countries it is illegal to have the fogs on together with low- or high beams (unless the need is there because of fog - then is is OK), and it is illegal to have the fogs switching on automatically as DRLs - but it is not illegal to use them as DRLs - just not as automatically.
Gizmo
S.E.Kent UK
C?ID=49193
Likewise, thats how I use mine (apart from I go from off to Auto as I don’t want them to come on Automatically... personal reasons)
It’s illegal in the UK to use foglights unless there is serious fog around also.
The OP however is after them to come on automatically when the low beams are turned on, this I imagine will not be possible due to how the lightswitch works (unless it is physically wired differently)
A5Tronic
Australia
C?ID=248341
The A5 has a simple button next to the headlight dial on the dash, it doesn't spring out or anything.
If I press the fog button when the headlights are on, the fog lights turn on, and stay on.
I just need to stop the fog lights from turning off when the headlights turn on.
As for the brightness, the LED fogs are really not bright at all. They don't dazzle others during daytime or night time.
rlarsen
Copenhagen, Denmark
C?ID=78998
Yeah, on the A4/A5 B8 it is a button for both front and rear - but on some models it is pulling and pushing the light switch.
Could your problem be that you have coded the fogs as DRLs ??
What happens if you disable them again - does the fogs then stay on with low beams ??
A5Tronic
Australia
C?ID=248341
With 'Fogs as DRL' disabled, I dont know if the Fogs turn off when the headlights turn on. I didnt check it before doing the coding. I suppose I could check it tomorrow.
The thing is the stock DRL's in the headlight stay on when the headlights turn on, so anything else coded as DRL should also stay on.
It seems there is an override that turns off the fogs when the headlights go on. I suspect it is a country-specific thing. For example when it is set to Canada or Europe, the fogs stay on. If set to ROW, UK, Nth America, the fogs turn off.
Similar to how it is done in the A8 http://www.audiworld.com/forums/a8-...program-vcds-have-your-drl-foglights-2854619/
I'm guessing this country-specific option is actually in VCDS somewhere, but no one has found which bite/bytes they are yet. I see a lot of unknown entries in VCDS.
Would this info be in the workshop manual?
I do have a copy but I can't recall seeing this kinds of lighting related settings in there. I'll have another look anyway.
Gizmo
S.E.Kent UK
C?ID=49193
Have you tried changing the country code?
(17 - Instruments, Coding)
A5Tronic
Australia
C?ID=248341
A5Tronic
Australia
C?ID=248341
No luck. :(
[17 - Instruments] Country selection in Byte 9
- It was originally set to [00 = Germany or Not Specified]
- I tried Canada, Japan, Australia, ROW. These didn't affect the lighting at all.
[09 – Cent. Elect.] "Front Fog Lights stay on with High-beams"
- I tried toggling this option, but it made no difference with the low beams.
[09 – Cent. Elect.] "Fogs as DRL"
- When disabled: Headlights are OFF: I can't turn on the fogs at all.
- When disabled: Headlights are ON: The fogs are off by default but they still turn on when I press the button.
- When enabled: Headlights are OFF: Fogs turn on automatically.
- When enabled: Headlights are ON: The fogs are off by default but they still turn on when I press the button.
