Results 1 to 10 of 18
Thread: caliper and brake parts lubricant
    Alexandria/fairfax county VA
    for lubing up the caliper pins and associated metal to metal parts, what do you recommend?
    I tried some disk brake Wheel Bearing grease I had laying around the garage, and was not happy with the outcome.
    Considering the following:
    http://www.permatex.com/products-2/p...bricant-detail
    http://multimedia.3m.com/mws/media/8...08946-8-oz.pdf
    Last edited by mikeme; 07-17-2015 at 09:15 AM. Reason: correct grease description (bearing grease, for disk brakes)
    16.4905 S, 151.7375 W
    As an ex- Volkswagen/Audi/Porsche dealer tech, I never use any lubricants when working with the brakes on these vehicles.
    - I always cleaned the parts and replaced any damaged parts.
    The Factory Repair Manuals do not mention the use of any lubricants, that I recall seeing. They do recommend to "Use only appropriate solvents for cleaning brake caliper".
    The fact is when your brakes get real HOT, you do not want to have any foreign substance that could drip or seep on to the pads and influence the stopping power of these parts.
    Correct me if I am wrong, last time I checked, a lubricant is designed to reduce friction, I prefer my brakes to have friction
    My choice for big brake kits..
    Oh .. wait, . . I forgot, yes I did use lubricant on these cars in the days of brake drums.... That is a different story
    Hope that helps, be safe!
    drpeter
  3. Likes Zenerdiode liked this post
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    Silicone base lubricant is what I like for caliper pins.
    Dr. Peter you use no lubricant for the caliper pins?
    What do you do leave them dry?
    lubricant caliper pins only because they are free floating. Dr. Peter is right about the rotors and pads there should be nothing on them!
    I do recommend using a brake cleaner to clean the rotor to remove anything like finger prints or grease marks from your hands.
    Dr. Peter must have read your post wrong? You have to lubricant guide pins!
    Good Luck
    HQ
    OE pads don't need anything added to them, or at least not for the last 15 years. I would clean the off the caliper "locator pins" and put just a tiny dab of silicon on them.
    Jef
    Mar 2014
    Wilkes-Barre, PA
    Op wrote "I tried some disk brake grease" really there is no such thing!
    There is no grease for disk rotors! Nothing goes on rotors!!!!! Just the guides!
    Good Luck
    Not VCDS-related; moved to General VW/Audi Repair.
    To clarify, (I really should read twice before posting in the morning) the container in my garage contains Disk Brake wheel bearing grease. (probably purchased for use on my then-a-few-years-old 1981 Plymouth.)
    Last year I replaced the front pads and disks. cleaned off the caliper pins and used a dab of the wheel bearing grease on the pins. this spring the grease and whatever it turned into made the brakes grabby, shaking the steering wheel.
    so I am on a path to replace the disks and pads, as well as the caliper pin boots, and am looking for advice on how to properly provide whatever lubricant is required.
    when I did the rear pads a couple years ago, I left the caliper pins intact, with whatever lube was installed in Mexico when the car was put together. (changing rear pads does not require pulling the pins out, just mounting bolts that secure the pins.)
    I did see that VW sells a brake pin lubricant, but wonder what it is made of,
  9. #8
    - I do leave them dry, when I had worked on the new vehicles... less than 100 miles, I never noticed any assembly lubrication on these parts, so I never thought of using anything.
    - Personally I have never run into a problem, so it may not hurt to add something on the pins ... a little is better I would imagine
    drpeter
  10. #9
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    I lost a rear inboard pad on my 2001 Jetta GLX due to a stuck caliper slide pin... 16,000 miles from factory new and I heard grinding metal. The other three rear pads were in excellent shape.
    I can't recall off the top of my head what Bentley says on the topic, but I have always carefully inspected, cleaned, and lubricated slide pins after that. There are sticky high-temperature rated greases just for this purpose.
    Jason
  11. #10
    Administrator Andy's Avatar
    Sector 7G
    Isn't this stuff pretty much made for this purpose?
  12. Likes Eric liked this post
