Having difficulty configuring the TPMS (Option 65). Have been reading the details in the Ross-Tech Wiki section and understand how to configure the car for the inflation pressures within the fuel door. 38 PSI Front and 33 PSI Rear.
The code string I am trying to get uploaded is as follows; 0462623. I receive an error after attempting to select Advanced Features, Option 7, type in the code string and click DoIt!.
There are values that were already within the Option 7 tab and I did not change anything except the first field as described above. The fields labeled; Workshop Code, Importer Number and Equipment Code were pre-populated. There was an Equipment Number in the last field, 579529. The range to the left of that field lists as; 0-262143 in order to be valid.
Received a popup that stated;
Re-code Invalid
This Equipment Code is invalid. Equipment Number must be 5-6 digits: 00000-262143. I heeded the warning on that page that states; Incorrect Coding can make a Control Module non-functional.
I do not want to create a problem so after having a pop up error, I stopped and am awaiting advice on if and how I should proceed.
Paul
Re-code Invalid
Paul
