B8 A4 led tail lamp euro coding
   #41
Taintted
Verified VCDS-Lite User
United States
C?ID=164743
Yeah, it looks to me that it isn't possible to change on the Facelift A4 Sedan NA model - it looks to me that it is only on the Avant that it is possible (see post #36 above).
So after testing the coding I fear you may be correct in that they combined the lines for the brake and signal and used the line that would be normally used for the outer signal and used it for the damn side marker. so unless i can move some wiring around this may not be possible. I wonder were I can get the wiring diagrams to compare the euro taillights to the na taillights because then maybe i can see if it would be easy to rewire the taillights, though I have a feeling a new wire would need to be ran to the bcm to make these behave like the euro ones.
Seems in order to make these taillights act like they are from Europe I would need to completely swap them out for the European version. The circuit for the blinkers in Europe they turned into the side markers here in the US and then changed the circuitry in the taillights to tie the brake and blinker together. There is absolutely no way to circumvent this through coding. I already priced out taillights and for a used set it will be like 400, which isn't bad.
   #42
cinek2004
Poland
C?ID=326815
Is there any way to adjust brightness of rear LED turn signals on B8 Avant FL? I changed LEDs from red to yellow and they seem to be to dark.
   #43
LukasAudiB8
Poland
C?ID=281022
Could someone give me good coding for a4 b8 2013 led year? I had led form NA and now i need to change for ROW
   #45
LukasAudiB8
Poland
C?ID=281022
Thursday,19,December,2019,10:39:46:00566
VCDS Version: 19.6.2.0 (x64)
VIN: WAUBFAFL8DN041285   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUBFAFL8DN041285   Mileage: 133120km-82716miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0007
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 27306 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001008
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: 35615E3D944340E744-8060
18062 - Coolant Pump 2
          P261A 00 [039] - Open circuit
                    Mileage: 133124 km
                    Date: 2019.12.17
                    Time: 17:00:48
                    Coolant temperature: 10 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.473 V
Readiness: 1110 0101
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 479D24F5FEAFC27726-8012
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Coding: 2D1D18
   VCID: 0407F3F98719296F83-8050
   Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
   Component: BCM2 2.0      H12 0633
   Coding: 09814000000000000000
   VCID: 000FFFE99301354FA7-8054
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0813000020099020
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2313000016426003
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01170220130400
   Coding: 6480208000
   VCID: 377D5435864FB2F756-8062
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 161
                    Mileage: 133121 km
                    Date: 2019.03.12
                    Time: 15:57:07
                    Temperature: 21.0°C
                    Temperature: 124.0°C
                    Absolute Pres.: 1.6 bar
                    RPM: 760 /min
                    Current: 0.000 A
                    Temperature: 28.0°C
                    Fault Status: 00101101
                    Reset counter: 201
                    Mileage: 133122 km
                    Date: 2019.10.29
                    Time: 00:07:12
                    Reset counter: 201
                    Mileage: 133122 km
                    Date: 2019.10.29
                    Time: 00:07:14
                    Temperature: 12.0°C
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000552611302
   Coding: 26000091863CAFC00000480300003D0D0F1C520822090221000004004000030100000000000000
   VCID: 76E39931C1C50BFF8D-8022
   Component: WWS 130213  H07 0080
   Serial number: SWF13020135606
   Coding: 00FD11
   Serial number: 20988864
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000602131739
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4V5W02
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 64680496000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD91ET5R
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 56633 001 1048576
   VCID: 4A9B1DC1EDBD3F1F39-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R130000DG5G
   Serial number: 6334MSME780314602
   Serial number: 6344MSME77730F65O
   Serial number: 6352QSME58281172B
   Serial number: 6362QSME742B3454I
   Serial number: 63732SME06132F52X
   Serial number: 63832SME3F2C286EJ
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372MBD000QO
   Coding: 000016
   VCID: 438530E5C297EE57FA-8016
   Part No SW: 8K0 920 950 R    HW: 8K0 920 950 R
   Component: KOMBIINSTR.   H09 0556
   Revision: 00500000    Serial number: UVE74VJ2E
   Coding: 8B9609000301D705020000
   VCID: 3E734111A97583BF95-806A
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0055
   Revision: 1V070026    Serial number: 2641V132098373
   Coding: 80C303FF00
   VCID: 489F27C9FBB1CD0F2F-801C
   Serial number: 8608799101
                    Fault Frequency: 55
                    Reset counter: 163
                    Mileage: 133122 km
                    Date: 2019.10.31
                    Time: 09:57:05
                    Bin. Bits:    00000
                    Voltage: 11.60 V
                    Count: 7
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 3979520DB05BA487A0-806C
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C03204000410001
   VCID: 56A3F9B121056BFFAD-8002
   Revision: 00001000    Serial number: 0028227612
   Coding: 100000000001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 346763399F3959EF73-8060
   Revision: 00002001    Serial number: 0301479988
   Coding: 0106023A00FA400480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000636336
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B5578454A07061722-807E
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55A1FEBD3C0360E7A4-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000170561
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 387F57098351BD8F5F-806C
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000002    Serial number: AUZ5Z6M1855847
   Coding: 04020002010185004159070800
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Fault Frequency: 11
                    Reset counter: 203
                    Mileage: 133121 km
                    Date: 2019.03.12
                    Time: 16:21:41
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C03204000210001
   VCID: 59B9F28D501B448780-800C
   Component: TSG HR        H07 0304
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005300658
   Coding: 0010370
   VCID: 3E734111697583BF95-806A
End-------------------------(Elapsed Time: 03:48)--------------------------
hadez16
C?ID=289891
Hi polish guy, the easiest way is to load EU parameters to unit 46 with that special other tool that comes from your country...
If not possible, please make an adaptation map of unit 46 with login 16017.
   #47
LukasAudiB8
Poland
C?ID=281022
195 - 5251
196 - 5283
197 - 5124
198 - 5156
199 - 0
200 - 32
201 - 51202
202 - 32
203 - 73
204 - 105
205 - 13
206 - 45
207 - 12
208 - 44
209 - 12
210 - 44
   #48
hadez16
C?ID=289891
Following values could work: take them with a grain of salt...
195,4100,n.v.,n.v.,n.v.,n.v.,
196,4132,n.v.,n.v.,n.v.,n.v.,
197,4100,n.v.,n.v.,n.v.,n.v.,
198,4132,n.v.,n.v.,n.v.,n.v.,
199,0,n.v.,n.v.,n.v.,n.v.,
200,10281,n.v.,n.v.,n.v.,n.v.,
201,10281,n.v.,n.v.,n.v.,n.v.,
202,0,n.v.,n.v.,n.v.,n.v.,
203,13829,n.v.,n.v.,n.v.,n.v.,
204,13861,n.v.,n.v.,n.v.,n.v.,
205,13,n.v.,n.v.,n.v.,n.v.,
206,45,n.v.,n.v.,n.v.,n.v.,
207,12,n.v.,n.v.,n.v.,n.v.,
208,44,n.v.,n.v.,n.v.,n.v.,
209,0,n.v.,n.v.,n.v.,n.v.,
210,0,n.v.,n.v.,n.v.,n.v.,
211,51214,n.v.,n.v.,n.v.,n.v.,
212,51215,n.v.,n.v.,n.v.,n.v.,
LukasAudiB8
Poland
C?ID=281022
The direction indicators flash red and there is no position in the flap
   #50
Kryhawrc2
C?ID=369633
Hello!
Do you have the correct coding for the taillights for Avant / Allroad 2013 with LED?
Will be changed from USA -> EU.
   #51
rlarsen
Copenhagen, Denmark
C?ID=78998
I think it will work just to use the RoW coding on the NA A4 FL Avant/Allroad :)
The mapping of the last 5 bit (bit 0 to 4) is (the bits with the blue color in the tables above):
Fixed links to pictures from request on PM....
   #52
bkendall0286
C?ID=389121
Do you happen to have this same chart with the correct coding for halogen tails on the A4 Avant?
I just had some water damage fixed and swapped the BCM2 from a Q7...surprisingly we were able to get everything except the right outer turn signal coding is not correct. Can’t find the stock chart for halogen for Avant
   #53
rlarsen
Copenhagen, Denmark
C?ID=78998
I didn't have the OEM codes from NA, but I have modified the ones from RoW to fit the one for NA
   #54
bkendall0286
C?ID=389121
THANK YOU!! I will give this a try this afternoon!
   #55
Jusstassss
Lithuania
C?ID=375119
  Tuesday,16,June,2020,18:33:01:60527
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUFFAFLXDN007656   License Plate: MANO ZIBINTAI
Mileage: 200380km-124510mi   Repair Order:
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
          72
VIN: WAUFFAFLXDN007656   Mileage: 200380km-124510miles
   Component: 2.0l R4/4V TF X09 0007
   Revision: ECX09---
   Shop #: WSC 92521 052 00000
   VCID: B522845014AD992E61-80E0
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: C7DEFE987E411BBE03-8092
   Coding: 2D5D18
   Shop #: WSC 02391 823 56573
   VCID: 8444299407F7F0A6A6-80D0
   Part No SW: 8K0 907 064 FM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H10 0602
   Coding: 0D810000000000000000
   Shop #: WSC 02399 823 56573
   VCID: 804C258413EFEC8682-80D4
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0816000077919007
   Serial number: 2312000094214007
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Revision: C1000000    Serial number: 01070520120951
   Coding: 6480208000
   VCID: B326BA4812D9871E4F-80E6
                    Fault Status: 01101101
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:39
                    Temperature: 23.0°C
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:41
                    Temperature: 23.0°C
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:44
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000030099401
   Coding: 26000095863CAF600001400300003D0D0F1C5208A2090221000008000000030100000030000000
   Shop #: WSC 08353 444 103400
   VCID: F8BC4D644B3FA446BA-80AC
   Component: WWS 080512  H07 0070
   Serial number: SWF12050085692
   Coding: 00FD11
   Serial number: 20264835
   Coding: 02005D
   Serial number: 00000000002704124816
03020 - Local databus 2
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:39
   Serial number: 003KJD90683
   Shop #: WSC 04134 002 1048576
   VCID: CAD8C7AC6D53E6D61C-809E
   Serial number: 5810000R1200008TNR
   Serial number: 6334MSME6E514A69S
   Serial number: 6344MSME6F220B3AN
   Serial number: 6352QSME4D131C54K
   Serial number: 6362QSME3D1422407
   Serial number: 63732SME38140578Z
   Serial number: 63832SME07173C56+
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LE2000K5
   Coding: 000016
   VCID: C3C6EA884279379EDF-8096
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTC51V25D
   Coding: 0F3F090002000009020001
   VCID: B228BF4CEDC38E1644-80E6
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y125030203
   Coding: 00C303FF00
   VCID: BFCEE6782E91537EBB-80EA
   Serial number: 1677937401
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000029147174
   Coding: 00000000000000000000
   VCID: BB3692683A894F5E97-80EE
16347 - Control Module - EEPROM Error
                    Fault Status: 00101110
                    Fault Frequency: 10
03330 - Motor for Fore/Aft Adjustment
                    Fault Status: 01100101
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
03332 - Motor for Height Adjustment
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
03333 - Motor for Cushion Angle Adjustment
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C13204E00410001
   VCID: CDD2CCB0943DF1EE39-8098
   Revision: 00001000    Serial number: 0026914087
   Shop #: WSC 02145 785 00200
   VCID: B424B9541FD7802656-80E0
   Revision: 00002001    Serial number: 0176189978
   Coding: 01061F3A00FA400580B0013200000000
   Serial number: 00000000000000520106
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   Coding: 011C13205E00410001
   VCID: CCD4C1B46F27F8E62E-8098
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 00000000057798
   VCID: B620835C09AB923668-80E2
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0112
   Revision: AB001007    Serial number: 236E/0C7538274
   Coding: 020007020100000001
   VCID: A10A4000B825058EAD-80F4
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0552
   Revision: --------    Serial number: 096EX0C7510273
   Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
   VCID: B620835C01AB923668-80E2
   Component: NAR 2011  0505
   Component: DU7 High  H41 0104
   Serial number: A130DB0CS148638
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001146792
   Component: CD-Database  3371
   Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
   Component: TSG HL        H07 0302
   Coding: 010C13204000210001
   VCID: D0ECD5C4830FDC0652-8084
   Revision: --H07---    Serial number: 525PA8-J24920L
   Coding: 1000006
   VCID: B83C8D64CBBF64467A-80EC
   Component: TSG HR        H07 0302
End----------(Elapsed Time: 02:01, VBatt start/end: 14.7V/14.8V)-----------
hi, can you help me with rear lights coding from USA to EU? A4b8,5 2013 sedan Channels values are:
195 51201
196 51233
197 6
198 38
199 0
200 32
201 51201
202 51233
203 73
204 105
205 13
206 45
207 134
208 166
209 51219
210 51251
rlarsen
Copenhagen, Denmark
C?ID=78998
Are you going to install RoW taillights too, or do you expect to reuse the current one from NA ??
The issue is that you'll not be able to code the NA taillights, so they will work as RoW - signal and brake lights can't be split up on the facelift model of a Sedan.
And if you change the taillights to RoW, then you need to do some rewiring, because on RoW more channels are in use, and channels are not used 1:1 on the rest of the tail - which was the case on the pre-facelift.
Below are the coding for both RoW and NA - then you can try them out your self.
   #57
Jusstassss
Lithuania
C?ID=375119
thanks, I will reuse old taillights, i know about rewiring, need extra wire, the only ploblem was,I expected to separate turn signal and brake light
   #58
afeyeguy1
C?ID=238423
          72
   Revision: ECX09---
   Revision: --H16---
   Coding: 000002
   Coding: 2D5D18
   Coding: 6480208000
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:39
                    Temperature: 23.0°C
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:41
                    Temperature: 23.0°C
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:44
   Coding: 00FD11
   Coding: 02005D
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:39
   Coding: 000016
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
   Coding: 00C303FF00
                    Fault Frequency: 10
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
                    Reset counter: 224
                    Mileage: 200383 km
                    Date: 2020.06.16
                    Time: 17:29:36
   Coding: 1000006
195 51201
196 51233
197 6
198 38
199 0
200 32
201 51201
202 51233
203 73
204 105
205 13
206 45
207 134
208 166
209 51219
210 51251
I've struggled for ages to find these codes and they're exactly correct!
Thanks!!
kantusjack
Spain
C?ID=69091
Hi All
I have a problem with an Audi 2009 A4 B8 Avant. I'm trying to upgrade from Halogen tail lamp to Facelift Tail Lamp
This is the original Autoscan of the car
Monday,31,May,2021,20:23:33:23521
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
VIN: WAUZZZ8K2AA005068   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K2AA005068   Mileage: 265720km-165110miles
Address 01: Engine (J623-CAGB)       Labels:| 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 MM    HW: 03L 906 022 B
   Component: R4 2,0L EDC   X01 4377
   Revision: 11X01---
   Coding: 0104002C02072118
   ASAM Dataset: EV_ECM20TDI03L906022MM A01004
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7CFDC987F7B0866B9F-8028
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
   Component: 0AW 20TDI RdW H04 0005
   Revision: --H04---    Serial number: 0000000221
   Coding: 000002
   Shop #: WSC 01064 202 82280
   ASAM Dataset: EV_TCMVL381 A01015
   ROD: EV_TCMVL381_A01.rod
   VCID: 77F7D6ABCE96A533F2-8022
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Coding: 170500
   Shop #: WSC 06325 000 00000
   VCID: 0201B77F9D54F09BD5-8056
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0321
   Coding: 012200
   Shop #: WSC 06325 123 12345
   VCID: 0103B8739852EB83CC-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000024362016
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000031822009
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0160
   Revision: C1000000    Serial number: 01040620091062
   Coding: 36100000
   VCID: 0005BD779358E28BC3-8054
12 Faults Found:
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:03
                    Temperature: 33.0°C
                    Voltage: 12.10 V
                    Output: 194 W
                    Output: 137 W
                    Temperature: 36.0°C
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:03
                    Temperature: 33.0°C
00360 - Front Right Upper Body Outlet Temperature Sensor (G386)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:03
                    Temperature: 33.0°C
                    Voltage: 12.10 V
01231 - Right Footwell Vent Temperature Sensor (G262)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:03
                    Temperature: 33.0°C
                    Voltage: 12.10 V
03037 - Rear Temperature Selection Potentiometer (G538)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:03
                    Voltage: 12.10 V
                    Voltage: 4.90 V
00712 - Right Footwell Flap Positioning Motor (V109)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:04
                    Voltage: 12.10 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 14346
                    Count: 14346
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Bin. Bits: 10000001
00713 - Centre Left Vent Positioning Motor (V110)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:04
                    Voltage: 12.10 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 11480
                    Count: 11480
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Bin. Bits: 10000001
00711 - Left Footwell Flap Positioning Motor (V108)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:06
                    Voltage: 12.00 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
01187 - Rear Temperature Flap Positioning Motor (V137)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:06
                    Voltage: 12.00 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:06
                    Voltage: 12.00 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
00714 - Centre Right Vent Positioning Motor (V111)
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:06
                    Voltage: 12.00 V
                    Temperature: 36.0°C
                    Temperature: 33.0°C
                    Count: 10000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 7
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:30:18
                    Voltage: 13.20 V
                    Temperature: 35.0°C
                    Temperature: 33.0°C
                    Count: 12100
                    Count: 11487
                    Bin. Bits: 01000000
                    Bin. Bits: 10000001
                    Time: 62.00 s
   Part No SW: 8K0 907 063 M    HW: 8K0 907 063 M
   Component: BCM1 1.0      H25 0372
   Revision: 08025001    Serial number: 00000000264556
   Coding: 690040B1033CB7201E01000300005F5F409C460800000101000000
   VCID: 39731093B0027343C4-806C
   Component: WWS 140509  H06 0070
   Serial number: SWF09050145193
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10474083
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000605091584
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:00
03207 - Charisma Switch Module
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H48 0050
   Revision: 00000014
   VCID: 2143D8F338920B83EC-8074
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940912800428
   Coding: 100103
   VCID: 3E79038FA92C547BF1-806A
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EFD02MY5M
   Coding: 30343435363030303030554A304C384B3053
   VCID: 41837873D0D22B838C-8014
   Serial number: 6334MSME46502E2EK
   Serial number: 6344MSME48002E63B
   Serial number: 6352QSME422B4416B
   Serial number: 6362QSME2F273030A
   Serial number: 63732SME39294B284
   Serial number: 63832SME5B2909340
   Revision: --------    Serial number: 90315IED0000M
   Coding: 000017
   VCID: 3D7B0483A42A4F63E8-8068
   Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
   Component: KOMBIINSTR.   H19 0253
   Revision: 00000000    Serial number: BXP55WM59
   Coding: 130F100002000008010200
   VCID: 2E5933CF794CA4FB61-807A
00003 - Control Module
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:04
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0101
   Revision: EB700052    Serial number: 5200E095038005
   Coding: 00C303
   VCID: 52A1473F0DB4A01B25-8006
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0160
   Serial number: 19078B44230409
   Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000101047955
   Coding: 011402204000410001
   VCID: 4797666BF6F615B342-8012
   Revision: 00002001    Serial number: 0118312395
   Coding: 013E0620203900800320020400000007
03389 - Data Set Implausible
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:02
03156 - Sensor for Anti-Theft System (G578)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:07
01134 - Alarm Horn (H12)
                    Fault Frequency: 13
                    Reset counter: 148
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:20:27
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 145
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:25:54
   Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000101054207
   Coding: 011402204C00410001
   VCID: 46896B6FF1FC0CBBB9-8012
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000373806
   VCID: 346D21A797608E2B17-8060
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0052
   Revision: AB001007    Serial number: 342EG097603200
   Coding: 010003020100000001
   VCID: 1F47DE0B0EE63D73DA-804A
   Part No SW: 8T1 035 666 M    HW: 8T1 035 666 D
   Component: H-BN-EU       H41 0143
   Revision: --------    Serial number: 483E/097506972
   Coding: 010101000206EFFFC7081F0D000002030000
   VCID: 448D7167C7C03EABA7-8010
   Subsystem 1 - Part No: 8R0 060 884 GH
   Component: EUR 2019/2020  2901
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356ES091101859
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000285043
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:06
                    Voltage: 12.20 V
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:15
                    Bin. Bits: 00001000 10100000
                    Bin. Bits: 01000000 00000001
                    Bin. Bits: 00000000 00000000
02453 - Multimedia Display Unit Rear Right (Y23)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:09
                    Voltage: 12.20 V
01043 - Control Module; Incorrect Software Version
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:17
                    Bin. Bits: 00000000 00100000
02169 - Front Right Microphone (R141)
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:19:07
                    Voltage: 12.20 V
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101057026
   Coding: 010402204000210001
   VCID: 4281777FDDD4309B95-8016
                    Reset counter: 108
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:20:39
02123 - Door Warning Light / Entry Light
                    Reset counter: 107
                    Mileage: 265682 km
                    Date: 2009.04.29
                    Time: 07:33:04
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101056904
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:20:39
                    Reset counter: 105
                    Mileage: 265358 km
                    Date: 2009.04.28
                    Time: 06:27:30
End-------------------------(Elapsed Time: 03:29)--------------------------
The original values of the adaptation channels were
181,65535,N/A,N/A,N/A,N/A,
182,255,N/A,N/A,N/A,N/A,
183,16383,N/A,N/A,N/A,N/A,
184,255,N/A,N/A,N/A,N/A,
185,65535,N/A,N/A,N/A,N/A,
186,255,N/A,N/A,N/A,N/A,
187,16383,N/A,N/A,N/A,N/A,
188,1,N/A,N/A,N/A,N/A,
189,16383,N/A,N/A,N/A,N/A,
190,1021,N/A,N/A,N/A,N/A,
191,65535,N/A,N/A,N/A,N/A,
192,3,N/A,N/A,N/A,N/A,
193,6,N/A,N/A,N/A,N/A,
194,7,N/A,N/A,N/A,N/A,
195,14849,N/A,N/A,N/A,N/A,
196,14881,N/A,N/A,N/A,N/A,
197,14882,N/A,N/A,N/A,N/A,
198,14882,N/A,N/A,N/A,N/A,
199,0,N/A,N/A,N/A,N/A,
200,73,N/A,N/A,N/A,N/A,
201,105,N/A,N/A,N/A,N/A,
202,0,N/A,N/A,N/A,N/A,
203,14853,N/A,N/A,N/A,N/A,
204,14885,N/A,N/A,N/A,N/A,
205,13,N/A,N/A,N/A,N/A,
206,45,N/A,N/A,N/A,N/A,
207,0,N/A,N/A,N/A,N/A,
208,0,N/A,N/A,N/A,N/A,
209,0,N/A,N/A,N/A,N/A,
210,0,N/A,N/A,N/A,N/A,
211,51214,N/A,N/A,N/A,N/A,
212,15,N/A,N/A,N/A,N/A,
213,12336,N/A,N/A,N/A,N/A,
214,1,N/A,N/A,N/A,N/A,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,51400,N/A,N/A,N/A,N/A,
222,51400,N/A,N/A,N/A,N/A,
223,51400,N/A,N/A,N/A,N/A,
224,51400,N/A,N/A,N/A,N/A,
225,51400,N/A,N/A,N/A,N/A,
226,51400,N/A,N/A,N/A,N/A,
227,51400,N/A,N/A,N/A,N/A,
228,51400,N/A,N/A,N/A,N/A,
229,51400,N/A,N/A,N/A,N/A,
230,2771,N/A,N/A,N/A,N/A,
231,2772,N/A,N/A,N/A,N/A,
232,2901,N/A,N/A,N/A,N/A,
233,2902,N/A,N/A,N/A,N/A,
234,3532,N/A,N/A,N/A,N/A,
235,3533,N/A,N/A,N/A,N/A,
236,3554,N/A,N/A,N/A,N/A,
237,3555,N/A,N/A,N/A,N/A,
238,0,N/A,N/A,N/A,N/A,
239,0,N/A,N/A,N/A,N/A,
240,0,N/A,N/A,N/A,N/A,
241,0,N/A,N/A,N/A,N/A,
242,0,N/A,N/A,N/A,N/A,
243,0,N/A,N/A,N/A,N/A,
244,0,N/A,N/A,N/A,N/A,
245,0,N/A,N/A,N/A,N/A,
246,1504,N/A,N/A,N/A,N/A,
247,1503,N/A,N/A,N/A,N/A,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
   #60
kantusjack
Spain
C?ID=69091
After some changes I've found in internet, with this configuration
181,0,N/A,N/A,N/A,N/A,
191,16239,N/A,N/A,N/A,N/A,
207,12,N/A,N/A,N/A,N/A,
208,44,N/A,N/A,N/A,N/A,
212,51215,N/A,N/A,N/A,N/A,
I have the next result ..
Turn Lights -------------------------------- Works Well
Reversing Lights ------------------------- Only works the right one, the left one doesn't work
Parking Lights ---------------------------- Works well, but when we turn them on, the exterior brake lights works 8and this not should happen)
Brake Lights ------------------------------ Only works the interior brake lights, the brake light from the tailgate
Fog lights --------------------------------- Not working
Any suggestion???
