Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: B8 A4 led tail lamp euro coding
    May 2015
    Okay thanks i will check out the coding later on and let you know if it matches.
  2. #12
    May 2015
    Hey guy's thanks a lot for your help the coding was correct and now it works properly.
  3. Likes Uwe, Dana liked this post
  4. #13
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by Tonymk6 View Post
    You are welcome
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  5. Likes Dana liked this post
  6. #14
    Nov 2015
    Canada
    Does anybody know what the coding is for the non-LED tail lights? or if it's even possible on our north american spec cars? Much appreciated
  7. #15
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by A4_Alan View Post
    Which coding do you want ?? NA model with the RoW coding - or the NA coding as it is OEM ??
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  8. #16
    Nov 2015
    Canada
    Quote Originally Posted by rlarsen View Post
    I believe it's RoW coding, where the turn signals are separate from the brake lights.
    Here's a link to show the tail light behavior:
    https://www.youtube.com/watch?v=ifJ5Zlv_Ay0
  9. #17
    May 2015
    Copenhagen, Denmark
    If you take the codings from the RoW section below - Channel 197 and 198 - you should have the RoW's way of using the signal lights.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  10. Likes Uwe, issac1993 liked this post
  11. #18
    Mar 2015
    Hello, are there similar codes that can be used on a 2010 A6 Avant? I am looking to code mine tail lights so the turn signals are separate from the brake lights.
    Dan
    2010 Audi A6 3.0T Avant
    2009 Audi A8 L
  12. #19
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by dan0412 View Post
    Dan
    I don't know if it can be done on your model - the face lift model of 4F (C6) - I've seen codings for the current model the 4G (C7) - and they look similar to the A4/A5/Q5 (B8).
    But if you post your current channel values we can see if it is possible or not.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  13. #20
    Nov 2015
    Canada
    I tried to access channel 197 and 198 last time and the fields had "NA" in them, couldn't make the changes because the fields were not editable. Going to give it another shot and if it works out, I'll finally be happy with the tail light behavior!
