Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: B8 A4 led tail lamp euro coding
    May 2015
    I have a 2012 Audi b8 A4 with the led tail lights i know davidb8 was able to code it so that the turn signals are separate from the brake lamps. Anyone know how to code it to be amber instead of red and not blink with the brake light.
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    It's no secret how the LEDs are Coded - David just kept it for himself.
    Which model do you have - Sedan or Avant ??
    About the amber instead of red - well - that will be a problem - unless you want to change both tail lights to the Euro model, because the LEDs are red on the US model.
    And I will suggest that this thread is moved into the Tweaks forum, so that it's only valid VCDS users who can see the coding.
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
    If the tail lights are stock, then indeed, this belongs in tweaks, not retrofits. If Tony has changed out the tails, then it belongs here in retrofits.
    Both forum sections have equal restrictions; one must be a verified user to post in those sections, but they can be read by anyone.
    May 2015
    Quote Originally Posted by rlarsen View Post
    Ok i have the Sedan. And yeah he was charging people to get it coded to work. I figured you need to change the tail lamps but i did it on a mkv jetta i coded it to have amber turn signals instead of red for the hella oem leds. I'm fine for now to just have the brake light separate from the turn signal if that is possible.
    May 2015
    Yes ill move this thread to tweaks because they are oem tail lamps.
  6. #6
    May 2015
    I have a 2012 B8 A4 with oem led tail lamps that came with the car i want to code them to work separate from the brake lamps. If you guys can help me out with the coding that would be great.
  7. #7
    Starting a new thread is not the same as moving a thread. I've merged them.
  8. #8
    May 2015
    Copenhagen, Denmark
    Quote Originally Posted by Tonymk6 View Post
    I think a MY2012 is not the Facelift in US right ?? - in the rest of the world the MY2012 is the first Facelift year.
    But if I'm right then you should be able to use the Coding below - use the RoW one (the left side):
    Login code to unit 46 is: 16017
    Please check that your current coding is the same as the right side of the table - otherwise I (or we) need to calculate the new coding for you.
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  9. Likes Uwe, Dana, ts21941, matteo.panciroli liked this post
  10. #9
    May 2015
    Yeah it isn't a facelift. Where do i go to check if my coding matches? In the U.S.A 2013 was the facelift year.
  11. #10
    May 2015
    Copenhagen, Denmark
    [46 - Comfort System]
    [Security Access - 16] -> Enter login-code: 16017
    [Adaptation - 10]
    Channel 195 to 208
    Rene Larsen
    VCDS 19.6.2
    (HEX-V2)
  12. Likes Uwe liked this post
