Hi Guys; I've just joined the forum, which I'm sure will help me with my UK MY2005 D3 A8. I've owned this car, originally owned by Audi UK, since April 2008, when it only had 64,000 miles on the 'clock'.
I'm hoping to get a personal VCDS when I'm employed again but my friend Mike scanned my car with VCDS for the first time yesterday, so I thought you'd like to see the results. By the way, the car's been scanned before over the years by my local non-franchised dealer [thus no VAS; I think he uses Autologic]; the scans only represent what's gone on since about November last year when it was scanned to try and work out why I get battery drain. No luck though, that still happens
So here's two scans, the first one with Hex-Net and the second [its fifth] one with HEX-USB. The first scan was done 'key on' only, which we now realise why we couldn't see all the ECUs. After various attempts, including a battery recode, the second scan was done 'engine on' after a proper 'jump start' to overcome the by then flat battery!
Comments on this scan:
1) Has less header detail than a USB scan - no VIN etc.
2) Freeze frame data is not printed - particularly relevant to my Battery Manager faults which were cleared before a USB scan!
1) Good reasonably clear scan, but I'm not sure why the 02 - Auto Trans shows "Malfunction 0010" but there's no fault described in the 'Address 02: Auto Trans' report!
2) My "00192 - Left door handle ..." is shown against both "05 Acc/Start Auth" and the "25 Immobilizer" ECUs.
We also ran the optical Bus scan but that was OK / OK for all ring devices so we thought there was little value in showing that!
Regards - Julian
VCDS Mobile 0.4123.0.4
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1D 1E 25 34 36 37
38 42 46 47 4F 52 53 56 57 61 62 72 76 77
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
1D-Driver Ident. -- Status: OK 0000
34-Level Control -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
Address 01: Failed to respond
Address 02: Failed to respond
Address 03: Failed to respond
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0909131C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial Number: AUX3Z0D9353518
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: D8F39B633312FBA73B6350-808D
Subsystem 1 - Part No SW: 4E0-905-852-D
Component: ELV 1834
00192 - Left Rear Door Handle Touch Sensor (G417)
007 - Short to Ground
Part No SW: 4E0 910 760 C HW: 4E0959760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial Number: 5DS 008 795-03
Coding: 3670112
Shop #: WSC 02313 785 00200
VCID: 23097C8FBAD4E87F9E719F-8076
No fault codes found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E2919610B
Component: Interfacebox H43 5570
Revision: 00000000 Serial Number: 300KS047541498
Shop #: WSC 00045 210 90242
VCID: 3A37A1EB2D5E89B7AD579A-806F
Subsystem 1 - Part No SW: 4E0-910-609-A
Component: Bedienteil MMI H42 0020
Serial Number: 318IE047510004
Part No SW: 4E0 910 043 A HW: 4E0820043A
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial Number: 00000000057290
Coding: 1067041
VCID: 1B79446F82A4D0BF560137-804E
Address 09: Failed to respond
Part No SW: 4E0 910 111 F HW: 4E0035111A
Component: CD-Changer H44 0470
Revision: 00000000 Serial Number: AUZ5ZBD6029817
VCID: 1C7B477387AAD7875F0B2C-8049
Address 15: Failed to respond
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0953549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: E58DA2977460564FB0E5C1-80B0
Subsystem 1 - Part No SW: XXX-XXX-XXX-XX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0920950F
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial Number: AUDID3DN000886
Coding: 0000418
Shop #: WSC 00028 210 01865
VCID: 2711689FCEEC045FC299AB-8072
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0815069E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial Number: 00000009006406
Coding: 0000001
VCID: 1A77416B8D9EA9B74D173A-804F
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0907468A
Component: Gateway H07 0070
Revision: 07 Serial Number: 160030482517A7
Coding: FCFF5BDE3B3504
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2905218
Component: FPI_1 H07 0060
Revision: 06000107 Serial Number: 23092004154705
VCID: DEFF8D7B5136059771BF96-808B
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Component: SG ext.Player H20 0850
VCID: 2B1994AFD204A03F26A1C7-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV 1834
Address 34: Failed to respond
Component: Sitzmemory FS H08 0060
Coding: 3670126
Part No SW: 4E0 910 888 P HW: 4E0919887C
Component: MNS ECE H43 1060
Revision: 00000000 Serial Number: 353K0047589079
VCID: 3B39A4EF2264B0BFB64197-806E
Address 38: Failed to respond
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2959802B
Component: Türsteuer.FS BRM002 0060
Coding: 0026914
VCID: 20037383ABC2F367835378-8075
Address 46: Failed to respond
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0035223A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial Number: 00000000008586
Coding: 0000013
VCID: 2A1791ABDDFE3937DDB7CA-807F
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0907280A
Component: ILM Beifahrer H09 0040
Revision: Serial Number: 00000000051553
Coding: 0010001
VCID: 1E7F4D7B91B6C597B13F56-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2959801B
Component: Türsteuer.BF BRM002 0060
Coding: 0026914
Address 53: Failed to respond
Part No SW: 4E0 910 541 T HW: 4E0035541B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial Number: 304KJ047604701
Coding: 0000001
VCID: 312586C7F0284AEF1CFD05-8064
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0919146A
Component: TV analog TUNER H13 0300
Revision: 00000024 Serial Number: 00000000008454
Coding: 0000003
VCID: 250D6297B4E0164FF06581-8070
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0915181C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial Number: 00000000014066
Coding: 0000000
Shop #: WSC 00011 888 06946
Subsystem 1 - Part No SW: 4E0-915-105
Component: von VA0 590122072
02273 - Quiescent Current Stage 2
02276 - Quiescent Current Stage 5
02274 - Quiescent Current Stage 3
02277 - Quiescent Current Stage 6
02256 - Quiescent Current
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0959801C
Component: Türsteuer.HL BRM002 0060
Coding: 0026914
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0959802C
Component: Türsteuer.HR BRM002 0060
Coding: 0026914
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0919283B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial Number: 08720430201074
Coding: 0101008
VCID: 21057687A0C8FA6F8C5D75-8074
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0862333C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial Number: T2AUDR0310H7KW
Coding: 0000004
VCID: 2207798BA5CEE177954762-8077
Tuesday,07,July,2015,13:56:21:22041
VCDS Version: 15.6.1.0
Data version: 20150612
VIN: WAUZZZ4E35N011492 License Plate:
Mileage: 340760km-211738mi Repair Order: Running - initial
Chassis Type: 4E (4E0)
VIN: WAUZZZ4E35N011492 Mileage: 340760km-211738miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 J HW: 4E0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number: AUX3Z0D9353518
Coding: 0011973
VCID: 22405F7FFD99E82FCF-8076
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
RPM: 756 /min
Torque: 97.5 Nm
Voltage: 13.68 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 45.9°C
18276 - Transmission Mount Valve 1 (N262)
P1868 - 001 - Short to Plus
RPM: 756 /min
Torque: 97.5 Nm
Duty Cycle: 1.0 %
Voltage: 13.60 V
Bin. Bits: 00101111
Torque: 171.6 Nm
Temperature: 45.9°C
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0070
Revision: --H01--- Serial number: 0070658
Coding: 0000001
VCID: 254A4463ECB71F17AA-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Revision: 01404004 Serial number: AUX3Z0D9353518
Coding: 0412672
VCID: 58B43D97EB4572FFE1-800C
Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 1834
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 01100111
Fault Frequency: 14
Reset counter: 176
Mileage: 333472 km
Date: 2014.11.20
Time: 14:24:12
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
VCID: 234E5A7BE283E127C4-8076
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Revision: 00000000 Serial number: 300KS047541498
VCID: 3A70871F750980EFF7-806E
Subsystem 1 - Part No: 4E0 910 609 A
Subsystem 2 - Serial number: 318IE047510004
Subsystem 3 - Serial number: 7409.09.0400000000218B0053ÿ
Subsystem 4 - Serial number: 8B0053ÿ
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Revision: 00000029 Serial number: 00000000057290
Coding: 1067041
VCID: 1B3E629BDAF3D9E70C-804E
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0000001
VCID: 3162A033A87F43B746-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Revision: 00000000 Serial number: AUZ5ZBD6029817
VCID: 1C3C6187DFFDDEDF05-8048
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63CE1A7BA203A12784-8036
Part No SW: 4E0 910 549 HW: 4E0 953 549
Coding: 0112141
VCID: 65CA0463AC37DF176A-8030
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Revision: D03 Serial number: AUDID3DN000886
Coding: 0000418
VCID: 27564E6B96BB0D0798-8072
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
VCID: 1A30679FD5C9A0EF17-804E
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Revision: 07 Serial number: 160030482517A7
Part No SW: 4E0 910 218 HW: 4E2 905 218
Revision: 06000107 Serial number: 23092004154705
VCID: 5EB82B8F89618CCFAB-800A
Revision: 00000000
VCID: 2B5EB25B4A5329677C-807E
Coding: 0412672
Component: ELV 1834
4E0905852D ELV 1834
Fault Frequency: 14
Reset counter: 176
Mileage: 333472 km
Date: 2014.11.20
Time: 14:24:12
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 28544D579BA5027F91-807C
Coding: 3670126
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Revision: 00000000 Serial number: 353K0047589079
VCID: 3B7E821B7A33B9E7EC-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000430200115
Coding: 0035904
VCID: 1D3A6C83C4E7D7D7F2-8048
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Coding: 0026914
VCID: 20445577F395FA3FD9-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040411110043
Coding: 0000249
Component: Heckdeckel P14H06 0070
Component: Neigungssensor H03 0020
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Revision: PROD_01 Serial number: 00000000008586
Coding: 0000013
VCID: 2A50B75F85A9306F87-807E
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Revision: Serial number: 00000000051553
Coding: 0010001
VCID: 1E386B8FC9E1CCCFEB-804A
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Coding: 0026914
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000221
Shop #: WSC 13765 210 01865
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Revision: 00000000 Serial number: 304KJ047604701
Coding: 0000001
Part No SW: 4E0 910 146 G HW: 4E0 919 146 A
Revision: 00000024 Serial number: 00000000008454
Coding: 0000003
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Revision: 00000000 Serial number: 00000000014066
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 310314E04G
Coding: 303030393135313035444C56413033313033313445303447
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Coding: 0026914
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Coding: 0026914
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Revision: --.--.-- Serial number: 08720430201074
Coding: 0101008
VCID: 21425073F89FF337D6-8074
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Revision: 00000006 Serial number: T2AUDR0310H7KW
Coding: 0000004
End-------------------------(Elapsed Time: 03:58)--------------------------
Regards - Julian
