Results 1 to 10 of 18
Thread: Coding injectors CAYC engine 1.6TDi
    Northern ireland
    Hi guys, I was wondering if anyone knows the security access to adapt the injector codings for idle controlon these engines?? I already tried the suggested 27971 from the pop up box but all I get is a "refused to send seed" error and I cant reprogramme the new injectors.
    Thursday,02,July,2015,10:33:09:06416
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    VIN: TMBCT21Z1B2029348   License Plate: JIG9674
    Mileage: 114200km-70960mi   Repair Order: SBTAXIS
    Chassis Type: 1Z (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: TMBCT21Z1B2029348   Mileage: 114200km-70960miles
    Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 AG    HW: 03L 906 023 AG
       Component: 1,6l R4 CR td H23 9971
       Revision: --H23---    Serial number:
       Coding: 00114014030500080000
       Shop #: WSC 73430 031 00999
       ASAM Dataset: EV_ECM16TDI02103L906023AG 003010
       ROD: EV_ECM16TDI02103L906023A_VW32.rod
       VCID: 6BDED784829CE079AB2-803E
    Readiness: 0110 1000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
       Component: MK70 M MASR         0105
       Revision: 00H35001
       Coding: 0017665
       Shop #: WSC 73430 790 00999
       VCID: 7BFEE7C43AFC70F93B2-802E
       Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
       Component: Climatic      150 0303
       Revision: 00006001
       Coding: 0000000002
       ROD: EV_ClimaBasis_SK35.rod
       VCID: 39723DCCB84082E969E-806C
    9481200 - Coolant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 8
                        Mileage: 114024 km
                        Date: 2015.04.04
                        Time: 11:42:51
       Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
       Component: BCM PQ35  B   103 0615
       Revision: 00103 AD
       Coding: 48180AB8A05BB1C04010008011000024420000AE524D81605C4440000040
       VCID: 2F6603947E045C59C7A-807A
       Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 05081  26  0601
       Coding: 00D7B7
       Subsystem 2 - Part No: 1Z0 951 171
       Component: Innenraumuebe  008 5101
       Subsystem 3 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    02391 - Terminal 30 Reference
                        Reset counter: 3
                        Mileage: 113885 km
                        Date: 2015.03.30
                        Time: 15:04:05
                        Voltage: 12.25 V
                            Term 50 Off
                        Reset counter: 48
                        Mileage: 114019 km
                        Date: 2015.04.04
                        Time: 10:55:06
                        Voltage: 14.20 V
                            Term 50 Off
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC1Z8WTO
       Coding: 0020788
       VCID: 3D7A29DC6468BEC9456-8068
       Subsystem 1 - Serial number: 6332MSME5575182DH
       Subsystem 2 - Serial number: 6342MSME557534236
    00532 - Supply Voltage B+
       Part No SW: 5K0 953 521 BJ    HW: 5K0 953 569 C
       Component: LENKS.MODUL   009 0136
       Revision: FF010038    Serial number: 20100820300363
       Coding: 5080040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 75EAF1FCD4D826894D6-8020
       Part No SW: 1Z0 920 903 M    HW: 1Z0 920 903 M
       Component: KOMBI         H04 0405
       Coding: 410B00
       VCID: 3F8653D4A664ACD957A-806A
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 020810F2002005
       Coding: E9807F0600020200001303
       VCID: 6DDAD99C7488EE49B56-8038
       Component: IMMO          H04 0405
       VCID: 6AD0D2808D66F971D04-803F
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2120
       Coding: 0000756
       VCID: 489448083BAAEB61E60-801D
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 316205ECA8304AA9D1E-8064
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000756
       VCID: 47964B3436B4E419EFA-8012
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        010 0054
       Revision: 0A001001    Serial number: SKZ1Z3K8456899
       Coding: 000004000001
       VCID: 356A31FC9C5866898D6-8060
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: 32600AE0AD3671B1A84-8067
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0008336
       VCID: 336E0FE4522C78B9A32-8066
    End-------------------------(Elapsed Time: 02:04)--------------------------
  2. Likes Uwe liked this post
  3. #2
    What happens when you try to code it with new injector number ?
    If secure access is needed, try: 12233
    I have had one, where the 27971 was not accepted the first try.
  5. #3
    Northern ireland
    It won't accept it, it comes up with security access required. I tried it a few times but didn't work. I'll try 12233 but I'm not sure it's applicable to the 1.6 tdi.
  6. #4
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello, I'm not sure, but please look for Injector Calibration (Cylinder 1) in Adaption channels without access,
    After Replacing an Injector the new Part has to be calibrated to avoid drivability issues.
    Once the new Injector is installed save "0" as new Value and switch the Ignition OFF for about 30 Seconds.
    -Wolfgang
    Drive more talk less
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    Northern ireland
    Ok I will give that a go. I tried again with the codes but to no avail. I even had another one in and tried the 27971 and it worked no problem. Maybe it's a difference in software??
  9. #6
    Northern ireland
    Nope, still no success with this one. Has anyone else experienced the same difficulty with security access?? Works perfect on other models of the 1.6tdi?!
  10. #7
    Is there any chance that the ECU has been tuned/mapped?
  11. #8
    Northern ireland
    No the car is completely stock. I found this same issue on a vehicle before but I then sent it to a friends garage who had ODIS to code them for me. I'm just intrigued as to why it doesn't work with this particular ecu?
  12. Likes Uwe liked this post
  13. #9
    You don't happen to have a scan of the other vehicle you had this same issue with, do you?
  14. #10
    Sep 2014
    some ideas. If the mounted injectors are build by DELPHI, there will be a very different procedure to get the codes into ECU.
    For excample:
    FPFNCB82N6ZEL8D5YCZ - correction value on injector
    test step : evaluate exchange direction
    test step : disassemble string
    test step : convert the values
    test step : catenate
    Adjustment Injector
    0F170F160C0B080216061F0E14080D051E0C1F02
    That was performed by ODIS, don't know anything how to do it with VCDS
    -Wolfgang
