Results 1 to 2 of 2
Thread: 2010 GTI TSI (Signal Line for Fuel Pump Electronics 012425)
    Feb 2015
    Central FL
    2010 GTI in excellent shape with 63k on the clock. CEL is on for the 012425 code. Any pointers on how to determine if the fuel pump control module or the lift pump is causing this code? I cleared it the other day but it came back. The 050217 code did not. The car is running fine and hasn't shown any symptoms of a failing module or pump. When I go to group 106 in MB the actual and requested pressures seem to be fine. The code comes back after a day or so of driving. The duty cycle of the pump was 69-70% at idle when the car first came in. I replaced the fuel filter and the duty cycle dropped to an acceptable 53%. Before I replace the pump and control module I was wondering if anyone has any pointers. I called the dealer to get a price on the pump and ask if there were any TSBs associated with it and was told no. I don't think the parts guy even looked into it.
    Thanks in advance,
    Josh
    Chassis Type: AJ (1K0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 65 77
    VIN: WVWEV7AJ0AW424994   Mileage: 101760km-63230miles
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
       Revision: AAH17---    Serial number:
       Coding: 0403010A18070160
       VCID: 71E3CD8D68D8AFA9911-8024
    012425 - Signal Line for Fuel Pump Electronics
                   P3089 - 000 - Electrical Malfunction - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 9
                        Mileage: 101669 km
                        Date: 2015.06.20
                        Time: 04:10:42
                        RPM: 697 /min
                        Load: 36.5 %
                        Speed: 5.0 km/h
                        Temperature: 57.0C
                        Temperature: 36.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.589 V
    050217 - Implausible Data Received from Steering Column Control Module
                   U0429 - 000 -  - Intermittent
                        Mileage: 101567 km
                        Date: 2015.06.16
                        Time: 19:56:43
                        Load: 0.0 %
                        Temperature: 90.0C
                        Temperature: 51.0C
                        Voltage: 12.319 V
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 114B600C492400FE881406ED921D0041300800
       VCID: 78F5F0A9CBA2FEE156F-802D
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       ROD: EV_ClimaBasis_VW32.rod
       VCID: 75EBF99DD4B083894D9-8020
       Part No SW: 1K0 937 087 G    HW: 1K0 937 087 G
       Component: BCM PQ35  H+  103 0576
       Revision: 00103 AF
       Coding: 6D180A1A90272A0480080081600005C441010086534D8D60648020200000
       Shop #: WSC 05232 444 54327
       VCID: 356B399D9C30C3898D9-8060
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 06051  23  0512
       Coding: 009795
                        Fault Status: 00101010
                        Fault Frequency: 81
                        Reset counter: 108
                        Mileage: 98437 km
                        Date: 2015.04.15
                        Time: 17:15:14
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R009RPL
       Coding: 00003031
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: 397335ADB82827E9691-806C
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--000558DU00
       Serial number: 3572MSME13313153ZZZD
       Serial number: 3582MSME78351353ZZZT
       Serial number: 3512QSME1C4C5D19ZZZ5
       Serial number: 3522QSME06575C01ZZZS
       Serial number: 35527SME0F0A0822ZZZD
       Serial number: 35627SME401A0822ZZZ4
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000532
       VCID: 78F5F0A90BA2FEE156F-802D
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5K6 920 970 H    HW: 5K6 920 970 H
       Component: KOMBI         H03 0305
       Coding: 270F00
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 050510F1003792
       Coding: E9801F07001612000000
       VCID: 69D3A5ED40085769D91-803C
       Revision: 00001000    Serial number: 1225223R8XFG06
       VCID: 7EF9E6B12986C0D11C3-802B
       Component: IMMO          H03 0305
       VCID: 6AD1DAE18D0E5C71D0B-803F
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7668050191
       VCID: 2649EED15196B811343-8073
       Component: Tuer-SG         009 2111
       Coding: 0001076
       VCID: 31630D8DA858EFA9D11-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       Coding: 0001076
       VCID: 32610281AD5ED4B1A8B-8067
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H13 0044
       Revision: -----26S    Serial number: VWZ4Z7K3113738
       Coding: 0100040004
       Shop #: WSC 05232 444 100092
       VCID: 61C3BDCD78381F29011-8034
                000 -  -
                        Reset counter: 54
                        Mileage: 62222 km
                        Date: 2013.04.10
                        Time: 12:46:04
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           103 0521
       Coding: 018705
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 000 000 000 00
       Component: Telefon       H00 6900
       Revision: 00000000    Serial number: 000000AA000000
       Coding: 003420
       VCID: 2A511AE1458E9C7110B-807F
    01524 - Antenna for Telephone
                        Fault Status: 01101011
                        Reset counter: 234
                        Mileage: 62222 km
                        Date: 2013.04.10
                        Time: 12:46:55
    02791 - Telephone baseplate (R126)
                        Reset counter: 234
                        Mileage: 62222 km
                        Date: 2013.04.10
                        Time: 12:46:55
    Feb 2015
    Central FL
    Update....I cleared the code and did a few test runs up the street. The code came back after a few miles of spirited driving. I forgot I had a spare control module on the shelf so I plugged it in, cleared the codes, and went for another test run. The code did not return. It looks like the pump control module caused the code. So far all of the fuel pump control modules I have replaced have either totally failed outright or acted up where they stop sending power to the lift pump after running for a short amount of time. I guess this one was on its way out.
  3. Likes Uwe liked this post
