I retrofitted Park Assist System into 2012 Audi A7 3.0 TFSI Prestige USA. Added J791, G568, G569, G203, G204, K241, E581. VCDS scan does not show any fault codes. However, the Park Assist when the PA button is pressed shows as "unavailable" on DIS. How it needs to be coded/adapted? Any help appreciated.
84-Night Vision -- Status: OK 0000
Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07---
Coding: 1A2A0034056600060000
ASAM Dataset: EV_ECM30TFS0214G0907551A 003008
ROD: EV_ECM30TFS0214G0907551A.rod
VCID: 271E32BD5EC314190F5-8072
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 P HW: 0BK 927 156 AJ
Component: 0BK 30TFSIUSA H16 1004
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_AU48.rod
VCID: 3B36FECDB24BA0F97BD-806E
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 44A70F0322E5F0C04B00
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 383CE1C1837D8BE196F-806D
Part No SW: 4H0 907 064 BR HW: 4H0 907 064 BR
Component: BCM2 2.0 H31 0333
Coding: 0D8A2000000000000000
VCID: 7AB83BC9F5F159F120B-802F
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0064
Serial number: 27031200040876
Coding: 6603207A5C
ROD: EV_AirCondiComfoUDS.rod
VCID: 281C318153DD1B6106F-807D
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BP HW: 4H0 907 063
Component: BCM1 2.0 H12 0111
Revision: 11012002 Serial number: 00000001270877
Coding: 0D072091073E9FE281010084A0003820CF9CD308A2090125800308453B00
VCID: 77BE22FDC6E344995F5-8022
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 120228 H35 0080
Coding: 0045F7
Component: RLS H04 0003
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0001
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0001
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0001
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0001
Address 10: Park/Steer Assist (J791) Labels: 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 R HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0045
Revision: -------- Serial number: 56261204201679
Coding: B80904
ASAM Dataset: EV_EPHVA2CAU57X0000 002011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 41CA8C25D0A7CA29211-8014
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X.rod
Address 15: Airbags (J234) Labels: None
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H32 0032
Revision: -------- Serial number: 003D8001Z8M4
Coding: 303145313131303030324A55304C34473853
VCID: 3326D6ED9A1B68B9A3D-8066
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000CK3D0I
Serial number: 3575HRB406317UE42GJ9
Serial number: 3585HRB40611872O99L$
Serial number: 3515JRB40104UHL88OO/
Serial number: 3525JRB400Q4UHGCEQ7D
Serial number: 3554VRB40084UEN2I0DU
Serial number: 3564VRB40084UEN2AH5W
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MDO0018D
Coding: 00003C
VCID: 373EE2FD866384999F5-8062
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 983 HW: 4G8 920 983
Component: TBenUsaAccNv H79 0416
Revision: 28460177 Serial number: 658280312596028
Coding: 03CE01064F031008020100
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 72A813E9A58121B168B-8027
ROD: EV_RBD4K.rod
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000462229
Coding: 00C1033000
ASAM Dataset: EV_GatewPkoUDS 001013
ROD: EV_GatewPkoUDS_AU57.rod
VCID: 70AC19E1AB8D13A19EF-8025
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790783076
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 05041200040013
Coding: 00
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 2F2EDA9D76334C59C75-807A
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000026251688
Coding: C0581B008F002001000001010101102030303232203232
VCID: 383CE1C18B7D8BE196F-806D
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4204F24P0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA.rod
VCID: 2D12C0957C3F3E49F59-8078
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 3620EFF941697D91843-8063
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F27.03.1200H020003CZ24095ˇ
Subsystem 4 - Serial number: Z24095ˇ
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F57225E00628002000413
VCID: 41CA8C25D8A7CA29211-8014
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0019453573
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 3228D3E9650161B1A8B-8067
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0174480947
Coding: 0126063A20FAF48582B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0028
Part No SW: 4G0 035 465 A HW: 4G0 035 465 A
Component: BO G3 C7 H08 0130
Revision: 11S00000 Serial number: 0014027
VCID: 230626AD22FBF83953D-8076
Subsystem 1 - Part No SW: 4G0 035 466 HW: 4G0 035 466
Component: BO C7 SLAVE H51 0100
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F57225E00628002000402
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000296559
ROD: EV_ParkiBrake_AU48.rod
VCID: 2A18CB894DD1297110B-807F
Address 55: Headlight Range (J431) Labels: None
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 120404-0004-057
Coding: 1223A6601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2C14CD9147253741E27-8079
Part No SW: 4G0 035 082 C HW: 4G0 035 082
Component: Radio U SIRIU H53 0101
Revision: AB001007 Serial number: 236D 0C7528184
Coding: 010007010000000001
VCID: 200C29A133EDE3214EF-8075
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 J HW: 4G0 035 670 H
Component: H-BNT-EU H51 0798
Revision: -------- Serial number: 190G 0D7544642
Coding: 090100040003EDEF75169F3E00000003100001000100000000
VCID: 2A18CB8945D1297110B-807F
Subsystem 1 - Part No: 8R0 060 884 CH
Component: EUR 2014 2004
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Component: CD-Database 2712
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F17224000628002000002
VCID: 44C48531C7B5DF010A7-8011
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J23G36J
Coding: 1080013
VCID: 26003FB991C90D11343-8073
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G8 959 107 P HW: 4G8 959 107 G
Component: HDSG-Modul H13 0039
Revision: 12013001 Serial number: 089201158
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 42C88329D5A1D13138B-8017
Component: TSG HR H04 0212
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 4G8 919 604 G HW: 4G8 919 604 G
Component: HeadUpDisplay 009 0106
Coding: DA0000
ASAM Dataset: EV_HUDContiC7 001020
ROD: EV_HUDContiC7.rod
VCID: 373EE2FD8E6384999F5-8062
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0028
Serial number: 0K84AE40066785
Coding: 1411
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
VCID: 312ADCE560075AA9D11-8064
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H08 0007
Serial number: 00000000001205900632
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Revision: -------- Serial number: 262130025421000
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 26003FB959C90D11343-8073
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851) Labels: 4G0-907-107.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052703127
Coding: 038198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7_AU57.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 04:09)--------------------------
