Results 1 to 2 of 2
Thread: 2015 VW Sportwagen S TDI, 2.0, manual
    Jun 2015
    Windows Based VAG/VAS Emulator
    VCDS Version: Release 14.10.2(x64) Data version: 20150311
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Monday,25,May,2015,12:02:16:05815
    VIN: 3VWFA7AU6FM501317 License Plate: 3329
    Mileage: 3749km-2329mi Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
    VIN: 3VWFA7AU6FM501317 Mileage: 3749km-2329miles
    Address 01: Engine (J623-CRUA) Labels: None
    Part No SW: 04L 906 021 C HW: 04L 907 309
    Component: R4 2,0L EDC H23 8412
    Revision: 85H23---
    Coding: 01190012032410081000
    Shop #: WSC 61626 001 1048576
    ASAM Dataset: EV_ECM20TDI01104L906021C 001012
    ROD: EV_ECM20TDI01104L906021C.rod
    VCID: 2541B1AD24F7B1093D9-8070
    Self-Diagnosis Log
    Page 2
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
    Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
    Component: ESC H32 0385
    Revision: 00000000 Serial number: 53644000000328
    Coding: 04FA6AA12420096D007A020181CA2520562490004081A4B200630050C002
    Shop #: WSC 01383 790 50316
    ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
    VCID: 479D1B25FEBB4319EF5-8012
    Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
    Revision: 00021000 Serial number: 0355865222
    Coding: 030C0C
    ROD: EV_KessyHellaMQBAB_AU37.rod
    VCID: 3A7B72D1BD492EF160B-806F
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 5GM 907 426 HW: 5GM 907 426
    Component: AC Manuell H02 1001
    Revision: 00001K01
    Coding: 02020104200100000000000000000000
    ROD: EV_ACManueBHBVW37X_SE37.rod
    VCID: 0501D12D843791095D9-8050
    Self-Diagnosis Log
    Page 3
    Address 09: Cent. Elect. (J519) Labels: None
    Part No SW: 5Q0 937 087 Q HW: 5Q0 937 087 Q
    Component: BCM PQ37BOSCH 028 0145
    Revision: -------- Serial number: 86581701151602
    Coding: 000108424041804169E44000000403001800000000000000000000000000
    Shop #: WSC 00066 790 00195
    ROD: EV_BCMBOSCH_VW37.rod
    VCID: 49991D1DE8AFB569F91-801C
    Slave 1:
    Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119
    Component: WWS 141110 043 0581
    Serial number: 150130165441
    Self-Diagnosis Log
    Page 4
    Component: AirbagVW20 009 0825
    Serial number: 003GCR010K5+
    Seat occupant detection; front passenger side:
    Component: BF-Gewichtss. H10 0021
    Serial number: IBH0000J1400025TWB0K
    Coding: 303138
    Subsystem 2 - Part No SW: ----------- HW: 480 001 411 14
    Serial number: 35700000000FE9F8E116
    Subsystem 3 - Part No SW: ----------- HW: 480 001 312 14
    Serial number: 35800000000AF02D321J
    Subsystem 4 - Part No SW: ----------- HW: 480 400 512 14
    Serial number: 3510002A31811B94B24X
    Subsystem 5 - Part No SW: ----------- HW: 480 400 512 14
    Serial number: 3520002A31811B92934V
    Subsystem 6 - Part No SW: ----------- HW: 480 400 212 14
    Serial number: 3550002C518B3AB303D9
    Subsystem 7 - Part No SW: ----------- HW: 480 400 212 14
    Serial number: 3560002C518B3AB4B2EM
    Self-Diagnosis Log
    Page 5
    Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
    Component: Lenks.Modul 075 0175
    Revision: FF032032 Serial number: 20141215500778
    Coding: 0400
    Shop #: WSC 66564 385 16448
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 0407CC298F0DA8014A7-8051
    Part No SW: 5G1 920 841 HW: 5G1 920 841
    Component: KOMBI 243 4270
    Coding: 0BA412122180CF0502086A001000000000000000
    Shop #: WSC 07455 444 00000
    VCID: 65C1F1AD64777109FD9-8030
    Self-Diagnosis Log
    Page 6
    Address 19: CAN Gateway (J533) Labels: Redir Fail!
    Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 L
    Component: GW MQB Mid 211 2203
    Revision: -------- Serial number: 25121410000059
    Coding: 0901000800087300EF000008080F00000001050000000000000000000000
    Shop #: WSC 00066 790 07025
    ROD: EV_GatewConti_VW37.rod
    VCID: 71E995FDA0BFADA9911-8024
    Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
    Component: E221__MFL-DC1 H16 0101
    Serial number: 27150000094300075036
    Coding: 28FFFF
    Inverter power receptacle:
    Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
    Component: WECHSELRICHTE H53 0041
    Serial number: 0019276
    Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
    Component: ELV-MQBA H01 0120
    Revision: 00000000 Serial number: 14000354426004
    Coding: 5500000000000000
    ROD: EV_ELVMarquMQB_AU37.rod
    VCID: 34675CE99F2DD881BA7-8061
    Self-Diagnosis Log
    Page 7
    Part No SW: 5Q0 959 393 B HW: 5Q0 959 393 B
    Component: TSG FS 020 0025
    Serial number: 110115060502ON
    Coding: 003013200000040000000000
    VCID: 3E737EC1A16102D15C3-806B
    Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
    Serial number: 00000000000000512573
    Coding: 011000
    Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
    Component: EPS_MQB_ZFLS 126 1061
    Coding: 0102
    Shop #: WSC 00066 790 00202
    ROD: EV_SteerAssisMQB.rod
    VCID: 43850F35CA836F3933D-8016
    Part No SW: 5Q0 959 392 B HW: 5Q0 959 392 B
    Component: TSG BFS 020 0025
    Serial number: 1701150605023P
    VCID: 3D7179CDAC6719C9459-8068
    Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
    Serial number: 00000000000000514430
    Coding: 091000
    Self-Diagnosis Log
    Page 8
    Part No SW: 5G0 035 844 HW: 5G0 035 844
    Component: MU-S-S-US 014 0645
    Serial number: V7B00812141510
    Coding: 02730200FF00000021220001001800001F0100140100010002
    ROD: EV_MUStd4CPASE_VW37.rod
    VCID: 64C7ECA96F4D0801EA7-8031
    Media Player Position 1:
    Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
    Component: ABT_Std_Plus H60 0030
    Serial number: VWZ8Z9PS50112Z
    Address 75: Telematics (J949) Labels: 5QE-035-285.clb
    Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
    Component: OCULowMQBUS 007 0564
    Shop #: WSC 00066 790 00122
    ROD: EV_OCULowMQB.rod
    End-------------------------(Elapsed Time: 03:36)--------------------------
    2015 TDI Sportwagen
    2008 Z4 3.0is
    1999 Z3 M coupe
    1996 Z3 1.9
    Nice, thanks!
    But please use [Copy] or [Save] rather than [Print] to post data here; Print is formatted for a printer and produces less than optimal results for the forum.
