- Joined
- Nov 23, 2014
- Messages
- 154
- Reaction score
- 45
- Location
- Los Angeles CA.
- VCDS Serial number
- C?ID=242342
Hello again, in this car... we replaced the cooling fans and now cooling system is running fine no issues. but, after replacements you now I am trying to use VCDS as much as possible so I can be trained by myself in planet VCDS.. so, I tried output test 08 Hvac /03 output... 1 out 2 cooling fan runs for a few seconds only fan for HVAC start up. every other component runs just fine. my question: are they supported (both the fans). why both fans didn't come on? is it something in VCDS or is just not supported. thanks again, and please focus only in my question. the car is fine now.
03 AUDI TT 1.8L
03 AUDI TT 1.8L
Tuesday,23,June,2015,14:15:59:33623
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: TRUTC28N231007939 License Plate: JSFUNCR
Mileage: 51717 Repair Order: 03AUDI TT1.8 AWP
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 8N0 906 018 BD
Component: 1.8L R4/5VT G 0003
Coding: 07570
Shop #: WSC 01236
VCID: 74E7E067443878817A7-515E
TRUTC28N231007939 AUZ5Z0B9145163
P1570 - 35-10 - - Intermittent
18613 - Performance Malfunction in Cooling System
P2181 - 35-10 - - Intermittent
Part No: 09G 927 750 L
Component: AQ 250 6F 0301
Coding: 0008201
Shop #: WSC 01236 785 00200
VCID: 3A7B0E5F76DCCEF160B-5140
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-F.lbl
Part No: 8N0 907 379 J
Coding: 0019473
VCID: 438573BB01168F3933D-5140
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 285FC417C8704C6106F-2580
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 B
Component: Airbag Front+Seite 6000
Coding: 01103
Shop #: WSC 01236
VCID: 3F8D7F4B3DFEEBD9575-515E
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 980 E
Component: KOMBI+WEGFAHRS. M73 D14
Coding: 06244
Shop #: WSC 22567
VCID: 387F145718D0DCE196F-4B00
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267 F
Component: Central Lock/Alarm D09
Coding: 15900
Shop #: WSC 01236
VCID: 438573BB51168F3933D-4EEA
35-00 - -
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00009
Shop #: WSC 01236
VCID: 65C18D23FFE29109FD9-519A
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 186 H
Component: concert II NP2 0009
Coding: 00202
Shop #: WSC 22161
VCID: 2541CD23BF6251093D9-4E96
End-------------------------(Elapsed Time: 02:55)--------------------------
Tuesday,23,June,2015,14:50:54:33623
Address 01: Engine (8N0 906 018 BD)
14:48:56
87.0°C Coolant Temperature
2.83 g/s Intake Air Mass
49.0°C Intake Air Temperature
0.2 % Lambda (Idle) Self-Adaptation
-2.3 % Lambda (Partial) Self-Adaptation
990.0 mbar Boost Pressure (specified)
1010.0 mbar Boost Pressure (actual)
0.0 % Wastegate (N75) Duty Cycle
