Results 1 to 3 of 3
Thread: TT RS 8J A/C blower not working. Code 01273
    Jun 2015
    Australia
    Question TT RS 8J A/C blower not working. Code 01273
    I'm new to the forum & VCDS so please forgive any dumb questions.
    I did try searching but I couldn't find anything relevant to my problem.
    2010 TT RS 8J. It's an Australia delivered car.
    My A/c stopped working. The blower fan does not come on.
    In Ross-tech VCDS it shows code 01273.
    I checked all the fuses in the engine bay, in the cabin and in the rear trunk area. All fuses are good.
    I haven't checked any relays (don't know what to check).
    I have checked at the blower motor and there is no short to earth and there is no power at the plug on the harness.
    At the control panel the LED's on each control knob are on but the blower motor does not run.
    What should I check next?
    Is there a relay that I should check?
    I did an Auto-scan. Here are the results:
    Windows Based VAG/VAS Emulator
    VCDS Version: Release 14.10.2(x64) Data version: 20150311
    Dealer/Shop Name:
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Monday,29,June,2015,18:24:21:35289
    VIN: TRUZZZ8J0B1900043 License Plate:
    Mileage: 24470km-15204mi Repair Order:
    Chassis Type: 8J (8P0)
    Scan: 01 03 08 09 10 14 15 16 17 19 20 22 25 2E 37 42 44 46 47 4C
    52 55 56 61 77
    VIN: TRUZZZ8J0B1900043 Mileage: 24470km-15204miles
    Self-Diagnosis Log
    Page 2
    Address 01: Engine (CEP) Labels: 07K-907-404-CEP.clb
    Part No SW: 8J0 907 404 F HW: 8J0 907 404
    Component: 2.5l R5/4V TFSI 0010
    Revision: F4H05--- Serial number: AUX7Z0J4FNH067
    Coding: 0113000C180F0160
    Shop #: WSC 01236 785 00200
    VCID: 306F2ED8A3AA8AA1DEF-8065
    001089 - EVAP Emission Control Sys
    P0441 - 002 - Incorrect Flow - Intermittent
    Mileage: 23992 km
    Date: 2015.06.15
    Time: 09:39:26
    RPM: 741 /min
    Load: 14.9 %
    Temperature: 98.0C
    Temperature: 50.0C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.351 V
    Temperature: -40.0C
    Temperature: -40.0C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    Readiness: 0010 0000
    Self-Diagnosis Log
    Page 3
    Address 03: ABS Brakes Labels: 8J0-614-517.clb
    Part No SW: 8J0 910 517 HW: 8J0 614 517 C
    Component: ESP MK60E1 0010
    Revision: 00H60001
    Coding: 0618391
    VCID: 69D983BC40F03B69D91-803C
    Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
    Component: J255 Klima 1 Zone 0110
    Revision: 00H09006 Serial number: 00000001152826
    Coding: 1573957
    VCID: 66C3888051EE1411F43-8033
    01273 - Fresh Air Blower (V2)
    010 - Open or Short to Plus
    Fault Status: 01101010
    Reset counter: 138
    Mileage: 24476 km
    Date: 2015.06.26
    Time: 13:35:56
    Temperature: 26.0C
    (no units): 55.0
    (no units): 224.0
    Self-Diagnosis Log
    Page 4
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 H HW: 8P0 907 063 H
    Component: BCM PQ35 H 106 0615
    Revision: 00106 AD
    Coding: 4E000B2FA0051A202070C0E82180084C507658AA3120D928DC080E440045
    Shop #: WSC 01236 758 00200
    VCID: 397913FCB0D04BE9691-806C
    Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer AU354 H08 0070
    Coding: 00FD10
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 02492C
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
    Part No SW: 8P0 919 475 G HW: 8P0 919 475
    Component: PARKHILFE 4K H06 0120
    Revision: 11001001 Serial number: 93641013419135
    Coding: 00000B
    VCID: 428B7410DD06083138B-8017
    Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
    Part No SW: 8J0 910 376 E HW: 8J0 907 376 E
    Component: J250 Raddaempfung 0110
    Revision: --H22--- Serial number: 190DPH 0110378
    Coding: 0000072
    VCID: 31692BDCA8A083A9D11-8064
    Self-Diagnosis Log
    Page 5
    Address 15: Airbags Labels: 8J0-959-655.lbl
    Part No SW: 8J0 959 655 HW: 8J0 959 655
    Component: -r Airbag 9.43 H03 0020
    Revision: 93H03002 Serial number: 0036K004FE2L
    Coding: 0011634
    VCID: 79F9D3FC30508BE9291-802C
    Subsystem 1 - Serial number: 6332DRB40B6E0CB1
    Subsystem 2 - Serial number: 6342DRB40B6E0BA3$
    Subsystem 3 - Serial number: 63747RB4058B1309K
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0004041
    VCID: 46836800312E3411143-8013
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
    Part No SW: 8J0 920 930 S HW: 8J0 920 930 S
    Component: KOMBIINSTR. VDO H01 0580
    Revision: D0H01002 Serial number: 2244J002000023
    Coding: 0117728
    Shop #: WSC 20460 822 999999
    VCID: 3C770AE87FE27EC1727-8069
    Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
    Part No SW: 8P0 907 530 A HW: 1K0 907 951
    Component: J533 Gateway H33 0302
    Revision: H33 Serial number: 210510F2000185
    Coding: E9BB1F0650065204004101
    Self-Diagnosis Log
    Page 6
    Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
    Part No SW: 8J0 857 511 G HW: 8J0 857 511 G
    Component: FLA H03 0004
    Revision: AA002001
    Coding: 02028D64747464545425363E
    VCID: 346722C897B2B681BA7-8061
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 2K0 907 554 HW: 2K0 907 554
    Component: Haldex 4Motion 5003
    Coding: 0000005
    VCID: 6BD5F9B44A0C2979ABD-803E
    Revision: D0H01002 Serial number: AUX7Z0J4FNH067
    Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
    Part No SW: 8P0 035 785 HW: 8P0 035 785
    Component: SG ext.Player H08 0100
    Revision: 00000000
    Coding: 020202
    VCID: 74E7E2C8D732F6817A7-8021
    Self-Diagnosis Log
    Page 7
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
    Component: RNS-E PU EU H04 0200
    Revision: 0000010S Serial number: AUZBZ7KD400450
    Coding: 0610725
    Shop #: WSC 20460 822 173925
    VCID: 2B5539B48A8CE979EBD-807E
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
    Component: Tuer-SG H04 0101
    Coding: 0000605
    Shop #: WSC 20460 822 13273
    VCID: 44877208071206010A7-8011
    Part No: 8J0 909 144 J
    Component: EPS_ZFLS Kl. 239 3001
    Revision: 00H17000
    VCID: 377D15C446C45D999F5-8062
    Address 47: Sound System (J525) Labels: 8J0-035-223.lbl
    Part No SW: 8J0 035 223 F HW: 8J0 035 223 F
    Component: Audi TT Amp5K H05 0170
    Revision: -------- Serial number: BP208309190387
    Coding: 070101060002
    ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
    ROD: EV_AudioAmpli5ChannBNO1.rod
    VCID: 275DC5845E64CD190F5-8072
    Self-Diagnosis Log
    Page 8
    Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
    Part No SW: 8J0 907 274 C HW: 4F0 907 274
    Component: J793 RKA+ H02 0190
    Revision: 00000813 Serial number: 00008130113299
    Coding: 0604100
    VCID: 326B24D0ADA6B8B1A8B-8067
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8J8 959 802 H HW: 8J8 959 802 H
    Coding: 0000605
    VCID: 43857114021C013933D-8016
    Part No SW: 4L0 910 357 HW: 4L0 907 357
    Component: AFS 1 H01 0060
    Coding: 0000025
    Subsystem 1 - Part No: 8E0 941 329 A
    Component: AFS-Modul links H05 0030
    Subsystem 2 - Part No: 8E0 941 329 A
    Component: AFS-Modul rechtsH05 0030
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0610725
    Self-Diagnosis Log
    Page 9
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 8P0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H33 0302
    Coding: 0302015A
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Part No SW: 8P1 862 335 HW: 8P1 862 335
    Component: FSE_256x BT H41 0650
    Revision: 00000000 Serial number: 00000005205469
    Coding: 0011422
    VCID: 74E7E2C81732F6817A7-8021
    End-------------------------(Elapsed Time: 06:55)--------------------------
    Been here?
    http://wiki.ross-tech.com/wiki/index.php/01273
    Also, please use [Copy] or [Save] to get scan results to post here, using [PRINT] formats them in less than optimal manner for this medium.
    Jun 2015
    Australia
    Thanks for the fast response Uwe.
    Problem fixed. Stupid mistake.
    I found I had all the wiring & fuse info so I worked my way through that. I started at the fuse box in the engine bay and read the fuse locations. Oops I had pulled fuse 1-12 Fresh Air Blower control unit out to look at it and put it back into location 1-11 (which should be vacant)
    Blower now works fine.
    I note your suggesting on posting autoscans using copy rather than print. I'll do that in future.
    Thanks, Greg
  4. Likes Uwe liked this post
