Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: AFS retrofit problem
    Jun 2015
    Ohhh thanks, i shall give it a shot! I didn't get a manual with my afs kit, so i thought you would leave it as 0
  2. #12
    Jun 2015
    I have tried doing as you requested, but it still does not let me code the right hand side headlight, it keeps saying "request out of range" and if i remove a zero it says error 31. I don't know what's wrong, i have entered the security number and all, left the car to sleep for 20 minutes locked. What else could be wrong with the afs?
  3. #13
    You can't code one headlight or the other. The output subsystems should be coded automatically by the AFS module when you code the main AFS module.
    I wonder of the mismatch in software levels between the two output stages has anything to do with this?
  4. #14
    Jun 2015
    So would i need a new output stage for the right headlight? I got the output stages built on with headlight when i bought it from carsystems.
  5. #15
    I don't know; at this point, I'm speculating.
  6. #16
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Just one more try
    I would disconnect the output stage > cycle ignition > read fault codes > ignition off >
    connect output stage > ignition > one more coding > 55 with last code (overwrite it / save)
    Ignition off > wait > test it
    -Wolfgang
    Drive more talk less
  7. Likes Uwe, Dana liked this post
  8. #17
    United States
    Yeah, we had a few examples of that in the mk6 xenon retrofit thread. I suspect the right side is the issue:
    Subsystem 1 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul l 0004
    Coding: 00000022
    Subsystem 2 - Part No: 7L6 941 329 B
    Component: AFS-Lst.-Modul r X008
    Coding: 00000020
    0004 would be a common SWL per the conversation nearby this post.
  9. Likes Uwe liked this post
  10. #18
    Jun 2015
    I contacted my seller, and they are sending me a new slave module for the right headlight with sw 0004, so hopefully that should do the trick. I will let you guys know how it goes, hopefully by the end of the week!
  11. Likes Uwe, Dana liked this post
  12. #19
    Jun 2015
    Hi guys i got my slave module for the right hand side headlight, and fitted in, it's the same software coding as the left handside headlight. I managed to code it, and also do basic settings. But i keep getting 3 faults; 01312 powertrain data bus - 004- no signal/communication- intermittent, 02233 - left headlight power stage output stage (j667) 004 - no signal/communication - intermittent and also 02234 - right headlight power stage output stage (j668) 004 - no signal/communication - intermittent. Due to these fault codes the headlight stays down, but when i clear the faults the headlights work perfectly fine, going up, down, left and right. But when i restart the car after 30 seconds, the fault codes come back up and the headlights do not work as it should be.
  13. #20
    Tartu, Estonia
    You problably have terminal 15 and 30 mixed up in progress of install.
    The world is my oyster...
