Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: AFS retrofit problem
    Jun 2015
    Hi all,
    I have just finished installing bi-xenons, and have managed to code the bi-xenons, getting rid of the bulb out symbol on the dash. I also fitted the AFS system too. I have managed to follow DIY's online, and fitted the sensor, and connected the can cable to the canbus pin 6 and 16, wired up to the fuse box and grounded it. The AFS system seems to be working only to level the headlights, because i can hear and see the headlight motors moving up and down. But when i use vagcom to code the afs module, it says "no response to the controller". I'm confused to why it keeps saying that message, and not letting me access the module and code it?
    Autoscan from car in its current state, please?
    Jun 2015
    Hi Uwe,
    This is an autoscan of my car in it's current state;
    Sunday,28,June,2015,16:09:50:01483
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WVWZZZ1KZ9W511078   License Plate: DE09 HNJ
    Mileage: 88480km-54978mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZ9W511078   Mileage: 88480km-54978miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
       Part No SW: 03C 906 016     HW: 03C 906 016
       Component: MED17.5.5       G   3546
       Revision: L3H04---    Serial number:
       Coding: 0000072
       VCID: 5C9964F59F2E4CC1527-8009
    Readiness: 0010 0001
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       Coding: 163B400D092300FB680B02EB902100803000
       VCID: 74C92C55D7BEE4817A7-8021
       Part No SW: 3C8 907 336     HW: 3C8 907 336
       Component: Climatic      120 0102
       Revision: 00004001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW32.rod
       VCID: 6AF5322D8D7A2271D0B-803F
       Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
       Component: BCM PQ35  H+  103 0575
       Revision: 00103 AG
       Coding: 46180A3A9025F1C044000080140008EC45550488536D8960E48408040000
       VCID: 334BEF499230A3B9A3D-8066
       Component: Wischer 13020  21  0501
       Coding: 009795
       Component: RLS 230209 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2D0960CE
       Coding: 00003136
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       VCID: 77D31B59CEC88F995F5-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 33304044ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 22254145ZZZZZZZZZZZZ
       Serial number: 18471A3FZZZZZZZZZZZZ
       Serial number: 163E1827ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 032B7F894210D33973D-8056
       Part No SW: 5K0 920 960 F    HW: 5K0 920 960 F
       Component: KOMBI         H21 0029
       Coding: 470B00
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 3041E0456B2698A1DEF-8065
    13639168 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 226
                        Mileage: 88486 km
                        Date: 2015.06.28
                        Time: 20:35:19
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Revision:   H07 01    Serial number: 110209F2001148
       Coding: E9817F06000212000003
       VCID: 3753DB5946484F999F5-8062
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 226
                        Mileage: 88486 km
                        Date: 2009.11.18
                        Time: 20:35:43
    03272 - Control Module for Audio Interface
                        Reset counter: 226
                        Mileage: 88486 km
                        Date: 2009.11.18
                        Time: 20:35:47
       Component: IMMO          H21 0029
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
    Address 2E: Media Player 3
       Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
       Component: Tuer-SG         008 2042
       Coding: 0000756
       VCID: 79D71D6130DC99E9291-802C
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 69     2501
       Revision: 00H15000
       VCID: 2C79F4358F0EFC41E27-8079
       Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
       Coding: 0000756
       VCID: 7AD5026D35DA92F120B-802F
    Address 55: Headlight Range
    Address 56: Radio
       Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
       Component: Tuer-SG         007 2009
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
       Coding: 0000144
       VCID: 7BDB07693AE0ABF93BD-802E
    End-------------------------(Elapsed Time: 01:31)--------------------------
    Since neither your car's Gateway or VCDS can talk to your 55- Headlight Range control module, but the module sorta/kinda works (indicating it's getting power), you need to check your CAN bus wiring to that module.
    Jan 2015
    Lithuania
    i think problem is:you must connect afs module to external can,than active it in gateway
    Jun 2015
    Problem coding AFS control module
    Hi guys, I cannot seem to be able to code my afs control module properly, I keep getting a few errors
    Here is an autoscan of my car;
    Monday,06,July,2015,14:58:10:01483
    Mileage: 88680km-55103mi   Repair Order:
    VIN: WVWZZZ1KZ9W511078   Mileage: 88680km-55103miles
    55-Headlight Range -- Status: Malfunction 1010
       Coding: 0000072
       Revision: 00H35001
       Revision: 00004001
       Coding: 0000000000
       Revision: 00103 AG
       Coding: 009795
       Coding: 0330AD
       Coding: 00003136
       Coding: 0000034
       Coding: 470B00
              U1111 00 [008] - -
                        Fault Frequency: 98
                        Reset counter: 32
                        Mileage: 88486 km
                        Date: 2015.06.28
                        Time: 20:35:19
                        Fault Status: 00110100
                        Fault Frequency: 20
                        Reset counter: 31
                        Mileage: 88486 km
                        Date: 2009.11.18
                        Time: 20:35:43
                        Reset counter: 226
                        Mileage: 88486 km
                        Date: 2009.11.18
                        Time: 20:35:47
       Coding: 0000756
       Revision: 00H15000
       Coding: 0000756
       Coding: 1446940
       VCID: 3449EC55573EA481BA7-8061
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Subsystem 2 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul r    X008
       Coding: 00000020
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 247
                            Invalid
                            Invalid
                            Invalid
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
                000 -  -  - MIL ON
                        Reset counter: 247
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 11100101
                        Reset counter: 247
                            Invalid
                            Invalid
                            Invalid
    Address 56: Radio
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:33)--------------------------
    Could you guys help me please, thanks a lot!
  7. #7
    Jun 2015
    Bump! Can someone please help
  8. #8
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hi
    Coding 1446940 seems to be for US. Try 1442908. Then switch off ignition, lock the car, wait 15 minutes to let the CAN-BUS go to sleep ( please help me for the right term ),
    then testing for right funktion and coding of subsystems AFS-Lst.-Modul r 00000020 > to each one > 00000022.
    Hope this helps.
    -Wolfgang
    Drive more talk less
  9. Likes Uwe liked this post
  10. #9
    Jun 2015
    Thanks for replying wolfgang! So i have to switch and lock the car before recoding the slave module? Also would i need to change the workshop number, importer number and equipment number? Because currently it's set to 0
  11. #10
    Sep 2014
    change workshop number, importer number and equipment number? Because currently it's set to 0
    Yes, better for further adaptions and codings. 12345 123 12345 as the manual suggested if you don't have a number of your own.
    -Wolfgang
  12. Likes Uwe liked this post
