Results 1 to 7 of 7
Thread: Hi form the UK
    Hi form the UK
    Just joined the forum, i sent a message to Andy Smith , he suggested posting it here....i wondered if anyone can advise :-
    >>> Hi,
    >>> Can you help :-
    >>> I am enquiringly to see if there are any updates on the latest software
    >>> to incl the Engine Management Output Tests on Skoda Fabia 2004myr 1.2
    >>> 12Valve.
    >>> Any help would be much appreciated.
    >>> Kind Regards
    >>> Derrick
    >>> DFW Auto Electrical Services Ltd.
    > Hi Andy,
    > Thank you for response, please find enclosed AutoScan.
    > I am unsure as to the possible content of the Output Tests, but in the
    > past i have found this function very useful for example with remote
    > cylinder cut for detecting misfires etc.
    > Kind Regards
    > Derrick
    Log-KX04 UCD-TMBPY46Y533867733-59401.txt
    Sunday,13,April,2014,12:50:34:30340
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: TMBPY46Y533867733   License Plate: KX04 UCD
    Mileage: 59401   Repair Order: ERNIE
                      Address 01: Engine       Labels: Redir Fail!
     Control Module Part Number: 03E 906 033 A
        Component and/or Version: 1.2l/4V SIMOS3  00HS4672
                 Software Coding: 00031
                  Work Shop Code: WSC 13765
                 Additional Info: TMBPY46Y533867733     SKZ7Z0C2060243
                            VCID: 1E37A6949AC151EE89B-5102
    16685 - Cylinder 1
                 P0301 - 35-10 - Misfire Detected - Intermittent
    Readiness: 1010 0101
    Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
    VIN: TMBPY46Y533867733   Mileage: 95590km/59396miles
        Part No: 03E 906 033 A
        Component: 1.2l/4V SIMOS3  00HS4672
        Coding: 00031
        Shop #: WSC 13765
        VCID: 1E37A6949AC151EE89B-5120
    16685 - Cylinder 1
                 P0301 - 35-00 - Misfire Detected
    Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS.lbl
        Part No: 6Q0 907 379 G
        Component: ABS 5.7     FRONT   V30
        Coding: 00044
        Shop #: WSC 13765
        VCID: 418D3DE84BFF4E16D49-5120
                 79-10 - Please Check Fault Codes - Intermittent
    Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
        Part No: 6Q1 937 049 C
        Component: 00 BN-SG.           1S33
        Coding: 25610
        Shop #: WSC 13765
        VCID: 3B714F00291324C68E5-5120
        Part No: 1C0 909 601 A
        Component: 11 AIRBAG VW51      0008
        Coding: 12593
        Shop #: WSC 13765
    Address 17: Instruments        Labels: 6Y0-920-xx0-17.lbl
        Part No: 6Y0 920 960 M
        Component: KOMBI+WEGFAHRSP VDO V07
        Coding: 00401
        Shop #: WSC 24066
        VCID: 46872EF462D1692EE1B-5120
        Part No: 6N0 909 901
        Component: 31 GATEWAY  CAN    1S33
        Coding: 00014
        Shop #: WSC 13765
        VCID: F0EB282CB0D5179EEB7-5120
        Part No: 6Q0 423 156 S
        Component: LenkhilfeTRW        V260
        Coding: 10140
        Shop #: WSC 13765
        VCID: 3F893B103D0B38E6A2D-5102
    Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
        Part No: 6Q0 959 433 E
        Component: 31 Komfortgerát     0002
        Coding: 00067
        Shop #: WSC 13765
        VCID: 3D75411837072AF6B01-4AE6
        Subsystem 1 - Part No: 6Q2959802A
        Component: 31 Tőrsteuer.FS TFK 0004
        Subsystem 2 - Part No: 6Q2959801A
        Component: 31 Tőrsteuer.BF TFK 0004
    Address 56: Radio        Labels: 1U0-035-156.lbl
        Part No: 6Y0 035 156 D
        Component:  Radio YD5          0010
        Coding: 00400
        VCID: 37795330153B00A66AD-49D8
    Also is it possible to attach a file/picture form my pc, e.g a browse select and attach button, newbie so i might have missed something obvious ?
    cheers
    Derrick
    Last edited by Uwe; 04-15-2014 at 03:20 PM. Reason: Wrapped CODE tags around Auto-Scan
    I'm not sure I understand what you're asking with:
    if there are any updates on the latest software to incl the Engine Management Output Tests on Skoda Fabia 2004myr 1.2 12Valve
    Are you asking whether Skoda has published any newer software for this ECU?
    Or are you asking whether VCDS support something for this ECU that you think is missing?
    As for attachments on this forum, no, there's no mechanism in place for that. If you want to post a picture, go to http://imgur.com/, use the Upload function there, and then post the picture here by using IMG tags, like this:
    Hi Uwe,
    Thank you for your response.
    The second one
    "Or are you asking whether VCDS support something for this ECU that you think is missing?"
    I was looking through the Output Tests option on VCDS, just seeing if there were some output tests in the Engine section that were available ..e.g a remote cyl cut for diagnostics of misfires etc or ?.
    please see screenshot below for the screen that came up when i selected Output Tests.
    Derrick
    Your image doesn't show. The link you posted is to your "folder" on imgur.com rather than one particular image.
    oop's newbie with this ........try this
    OK, "Function Not Available" when attempting Output Tests on an engine is usually due to the ECU objecting to the current conditions. On gasoline engines, the ECU will generally refuse to run Output Tests while the engine is running. It will also generally only run Output Tests once per ignition cycle, and you may even have to start the engine and then cycle the ignition off and back on to get the Output Test sequence to run.
    thanks Uwe, i'll try that sequence,
