Results 1 to 9 of 9
Thread: 2015 Jetta TDI - OEM LED Tail Light Retrofit
    Jun 2015
    Hello all,
    I would like to add OEM LED Tail Lights (from Jetta Hybrid / GLI) to my 2015 Jetta TDI SE w/ Connectivity Package. I am not sure if the CECM that I have in my vehicle will support the LED tail lights. I have access to a pre-facelift MK6 Jetta LED Tail lights, and without coding, everything EXCEPT the blinkers work correctly with byte 18 coded as-is ... however, before I take the plunge and purchase the facelift Jetta MK6 LED Tails, I was hoping if someone could provide any insight into compatibility with my current CECM and LED tail Lights. byte 18 drop-down options do not include any mention of tail lights ... only Halogen / Xenon Headlight options.
    The CECM in question is: BCM PQ25 Max3 H78 0725
    My original, unmodified Auto-Scan of my vehicle with factory options is below:
    Monday,18,May,2015,15:56:21:17253
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    Chassis Type: AJ (6N0)
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77 0B
    Address 01: Engine (J623-CVCA)       Labels: None
       Part No SW: 04L 906 016 AK    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 8276
       Revision: 8AH20---
       Coding: 011D0012042410085000
       Shop #: WSC 00066 790 00014
       ASAM Dataset: EV_ECM20TDI01104L906016AK 001008
       ROD: EV_ECM20TDI01104L906016AK.rod
       VCID: 72C52DCAA5EC44B168B-8027
    4481 - Cruise Control Switch (E45)
              P0568 00 [032] - Implausible Signal
       Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4508
       Revision: 05653104    Serial number: 00001408270082
       VCID: 256F0696ECA263093D9-8070
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A14B400C492800FF851302ED921C0042A1100012
       Shop #: WSC 00066 790 00081
       VCID: 04297B1287587A014A7-8051
    Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
       Revision: 00092000    Serial number: 0349126476
       Coding: 000F0F
       ROD: EV_KESSYPQ35G_AU21.rod
       VCID: 3753DCDE8E0EE1999F5-8062
       Part No SW: 5C0 820 047 CA    HW: 5C0 820 047 CA
       Component: J301  Klimaanlage   0207
       Revision: 2001001S    Serial number: 00000002464433
       VCID: 61E75286B80ACF29011-8034
    Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
       Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
       Component: BCM PQ25 Max3 H78 0725
       Revision: B8078001    Serial number: 78003321140909
       Coding: 7B994BBA08AB0B0008382080340894CD0F86702E60000050B0A050022844
       Shop #: WSC 00066 011 00000
       VCID: 3041E7C2636036A1DEF-8065
       Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H10 0007
       Coding: 180000
       Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
       Coding: 280000
       Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Coding: 800000
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD03HHXD
       Coding: 00004B33
       Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
       Component: BF-Gewichtss.  H05 0016
       Serial number: IBH0000J140001QEAH09
       Coding: 303345
       Serial number: 3572MSME6A493D49ZZZ8
       Serial number: 3582MSME75493D49ZZZ5
       Serial number: 3516KSME5C386E31ZZZ+
       Serial number: 3526KSME77681E32ZZZ
       Serial number: 3556LSME7D4E4031ZZZ/
       Serial number: 3566LSME7F427731ZZZ+
       Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
       Component: KOMBI         H04 0807
       Coding: 270801
       Shop #: WSC 00066 011 00119
       VCID: 2C79F3B247485241E27-8079
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 090 A
       Component: GW-K-CAN TP20 H78 0725
       Revision: B8078001
       Coding: 102200
       VCID: 70C127C2A3E076A19EF-8025
       Component: IMMO          H04 0807
       Coding: 000007
       Shop #: WSC 00066 000 00119
       VCID: 6AF535AA8D3C8C71D0B-803F
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Revision: 00000000    Serial number: 14000305635003
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 3041E7C26B6036A1DEF-8065
    Address 2E: Media Player 3
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 306    3501
       Revision: 00H22000
       VCID: 3957DAE6701AF7E9691-806C
    Address 56: Radio (J503)       Labels: None
       Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
       Component: Radio Prem-8  H07 0009
       Revision: -----12S    Serial number: VWZ4Z7P3637534
       Coding: 01000440020006
       VCID: 2D7FFEB674525B49F59-8078
                        Fault Frequency: 9
                        Reset counter: 163
                        Mileage: 3066 km
                        Date: 2015.04.11
                        Time: 12:15:36
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140529
       Coding: 02630102C2163A007F1606000000
       Shop #: WSC 01383 790 50316
       ROD: EV_OCULow_SE12.rod
       VCID: 538B884E3AB62DB983D-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 126
                        Mileage: 7062 km
                        Date: 2015.05.18
                        Time: 15:50:41
    Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
       Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
       Component: TELEFON       H07 0593
       Revision: 1B001001    Serial number: 00007666828147
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 3245EDCA656C04B1A8B-8067
    End-------------------------(Elapsed Time: 02:38)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Mar 2015
    I've made the plunge, lights are installed, markers work and backups work, brakes not so much..
    Monday,17,August,2015,16:44:56:17578
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    VIN:    License Plate:
    Mileage: 19040km-11830mi   Repair Order:
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56 75 77 0B
    VIN:    Mileage: 19040km-11830miles
    Address 01: Engine (J623-CVCA)       Labels: 04L-907-309-V1.clb
       Revision: 8AH20---
       Shop #: WSC 09376 002 1048576
       VCID: 72EBE5AAA5EB8BAE50-8026
       Component: GSG DSG AG6     521 4508
       Revision: 05652104    Serial number: 00001407141886
       VCID: 2541CEF6ECA5AC1605-8070
       Revision: 00H46001
       Coding: A14B400C492400FC850F02E9921C0042A1100012
       VCID: 0407B372875FB51E72-8050
       Revision: 00092000    Serial number: 0343471265
       Coding: 030C0C
       Shop #: WSC 03516 444 00000
       ROD: EV_KESSYPQ35G.rod
       VCID: 377D14BE8E092E86A7-8062
       Part No SW: 1K8 907 044 E    HW: 1K8 907 044 E
       Component: Climatronic   H05 0102
       Revision: 00001K02
       Coding: 0010019002
       Shop #: WSC 00066 000 00120
       VCID: 31692AA6606DF0B6E9-8064
       Component: BCM PQ25 Max3 H74 0725
       Revision: B8074001    Serial number: 27011254140539
       Coding: 78994BBF08A90B0008382480644B84CD0F86860E60840050B0A050022844
       VCID: 306F2FA26367F9BEE6-8064
       Coding: 820000
       Coding: 820000
       Coding: 180000
       Coding: 280000
       Coding: 800000
       Coding: 800000
    03431 - Activation of Left Parking Light
                006 - Short to Plus
                        Fault Status: 01100110
                        Reset counter: 62
                        Mileage: 19049 km
                        Date: 2015.08.17
                        Time: 16:34:21
       Serial number: 003LZD02FL1P
       Coding: 00004B33
       Shop #: WSC 00066 790 00011
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       Serial number: IBH0000J1400018LCH00
       Coding: 303345
       Serial number: 3572MSME38322A48ZZZX
       Serial number: 3582MSME542E2A48ZZZ0
       Serial number: 3516KSME13173530ZZZC
       Serial number: 3526KSME02223530ZZZ7
       Serial number: 3556LSME44461B30ZZZR
       Serial number: 3566LSME48431B30ZZZT
       Part No SW: 5C6 920 974 FX    HW: 5C6 920 974 FX
       Component: KOMBI         H04 0808
       Coding: 271801
       VCID: 0B15984EA201FA6633-805E
       Component: GW-K-CAN TP20 H74 0725
       Revision: B8074001
       Coding: 102200
       VCID: 70EFEFA2A3E7B9BEA6-8024
       Component: IMMO          H04 0808
       Coding: 000007
       VCID: 6ADBFDCA8D3B436EE8-803E
       Revision: 00000000    Serial number: 14000165340003
       VCID: 306F2FA26B67F9BEE6-8064
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3C0 035 684 Q    HW: 1K8 035 684 B
       Component: RNS-MID       H05 5382
       Revision: AB001001    Serial number: VWZ6Z7P3325004
       Coding: 04090040000003A10000
       Shop #: WSC 03822 444 12345
       VCID: 31692AA6686DF0B6E9-8064
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V10  8246
       Component: EPS_ZFLS Kl. 307    3501
       Revision: 00H22000
       VCID: 39791286701D38F651-806C
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H08 6815
       Revision: --------    Serial number: EAA098A0165188
       VCID: 2643C9FA59A3A70E0C-8072
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Serial number: 000003554140526
       Coding: 02630102C2423A007F1606000000
       ROD: EV_OCULow.rod
       VCID: 53A5402E3AB1E2A6BB-8006
    0022 - Databus
                        Reset counter: 86
                        Mileage: 17971 km
                        Date: 2015.08.09
                        Time: 09:40:51
    0036 - Databus
                        Reset counter: 86
                        Mileage: 17971 km
                        Date: 2015.08.09
                        Time: 09:40:51
                        Fault Priority: 8
                        Reset counter: 62
                        Mileage: 19049 km
                        Date: 2015.08.17
                        Time: 16:41:22
       Revision: 1B001001    Serial number: 00007666427145
       Coding: 0A110300A0010110
       ROD: EV_UHVUMI.rod
       VCID: 326B25AA656BCBAE90-8066
    End-------------------------(Elapsed Time: 03:38)--------------------------
    Any suggestions?
    Mar 2015
    Ok I 've got the short worked out... and it appears my problem is this, 4 wires from the car, 3 going into the outer tail light, brake and turn are combined on the tail light and separate on the car, is there anyway to convince the PQ-25 BCM to send brake and turn on one wire?
    or, does anyone know if the RoW version of the LED tail for a 15 jetta has brake and turn separated? internally it appears there are 4 wires, but at the connector there are only 3.
    Thanks in advance and sorry for threadjacking, but its directly relates to the OP's question.
    Ken
    Apr 2015
    Uruguay
    When I did this in my 2012 GLI with 4 wires, I connected PARKING LIGHT and BRAKE LIGHT to the same pin, then TURN LIGHT to another pin and finally GROUND to the other one.
    I coded Byte 18 to 52 NAR or 53 ROW (if you have FOG). The lights work in a different way from OEM, you get the full LED BAR at a lower intensity when in PARKING LIGHT, you get the same full BAR at full brightness when you BRAKE and the LED "C" is used for turn signal. I got no errors with this coding.
    Here's a video of another car with the same setup:
    Mar 2015
    Quote Originally Posted by csalvarr View Post
    What BCM does your car have?
    Apr 2015
    Uruguay
    It's a different unit, so the usual Byte 18 table (and my codes) may not work for you.
    But the main point is I could not find a code to make them work as they work on OEM LED Taillight equiped cars (3 wires from the BCM, I checked that on a friend's car) so I went with that config and it has worked flawlessly since that day.
    About your other question, RoW taillights have a separate AMBER bulb position and 4 wires.
    My unit:
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 N HW: 5K0 937 086 N
    Component: BCM PQ35 M 021 0064
    Revision: BJ021001
    Coding: 2F200A3B802F3EC400080080000081240728008650908D605C 8000000040
    VCID: 3F8947CF15BD
    Mar 2015
    Can someone from the Ross-Tech team please chime in? suggestions?
  9. #8
    Oct 2014
    Singapore
    I tried and tried back in 2011 but nothing came out of my effort to code the LED rear lights in my country.
    Finally, I add a 4 ohm resistor sealed in high temp silicon encased in fiber casing to the brake and tail light circuits across to ground.
    Worked till now without any error or need to code Byte 18 !
    Try it ! Sometime, the old caveman method works best !
  10. #9
    Mar 2015
    Ok so I have them operating normally, no errors are present.. the North American outer tail lights would not work, 3 wires vs 4 wires, so I got ahold of RoW outers with separate turns, 4 wires.. the marker lights never presented an issue, I was getting a bulb out warning on brakes and turns, the brakes i resolved by turning on bulb diagnostics, the turns worked with the exception of hyper flashing on the dashboard, i tried bulb diags, but that did not help the way it did for the brake lights, i put a resistor across the turn and ground line and the hyper flash went away..
    Now while it works, I am not really happy with the resistor, its a hack as far as I am concerned and I would like the car to be as close to stock as possible, to that point i've removed my after market headlights and ordered stock bi-xenons.. will be installing the whole smack when it gets here.
    If anyone has any idea's on how to resolve the hyper flash without the use of a resistor or switching back to the stock tail lights... I would love to hear from you..
    Thanks!
    Ken
