Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 130
Thread: 07 V10 TDI. And so it begins...
    Translation: Look in Measuring Blocks, Group 034, on both your ECUs. Field 2 should be the position it's trying to achieve, while field 3 should be the actual (measured) position of the actuators.
  2. #12
    Jun 2014
    Thanks for dumbing it down Uwe. I read that and thought "Damn, is that what i sound like to my girlfriend?
  3. Likes NZDubNurd, Dana, Jack@European_Parts liked this post
  4. #13
    Jun 2014
    By the way Uwe, just how closely do you look like Peter Sellers? I've got that image burned into my brain, along with the accent of that character.
  5. #14
    http://www.ross-tech.com/about.html
    Nahh.
  6. #15
    Are you sure?
  7. #16
    Sure......you trim that mustache on sides and yeah even Dr. Strangelove would heil/salute you.
    Than again the proper breeding techniques is an idea.
  8. #17
    Jun 2014
    Ah, I do recall having seen that vapor pic before
    Back OT, my woman and I escaped the brutal heat wave of home today where it was heading for low 90s and 97 tomorrow. We are in a cabin in Long Beach, WA where it is at least 30 degrees cooler.
    The car was running well when we left town. No light and it seemed to have modest boost, but i didn't hammer it.
    About 30 miles into the trip the DPF light came on and the MFD said something about the DPF and my wallet. Seriously.
    The message extinguished before i could switch glasses. I assumed it was telling me it was going to do an active purge, so i just kept on. The text never returned, but the DPF icon stayed on.
    She just ran to the store and told me the message came up "diesel part filter veh wallet"
    WTF does that mean?
    For the record, it still runs fine. No neck snapping power but im pulling away from campers on a grade.
  9. #18
    Look in the Owners Manual
    I would think it is saying, drive for a while at constant speed, so a regeneration can be performed.
    If you drive to long with this problem, it will empty your wallet
    But that are maybe not possible, because of the turbo problems, or other errors, you have.
    Maybe you still have DTC('s), resulting not to perform regeneration, I am just guessing.
    Make 2 Controller Map's, one with ignition and one in idle.
    Also Error code in engine ECU's.
    Post it here.
  10. Likes Uwe liked this post
  11. #19
    Quote Originally Posted by Flaps10 View Post
    Do you guys not have a cellphone with a camera? 'Cause a picture of that message would be priceless.
  12. #20
    Jun 2014
    Per the request. You can see it even has an exclamation after the word wallet.
    We're home now. The car pulled the flashing glow plug light thing in combination with the DPF light. Averaged 22.6 mpg on the trip and when I got home I managed to get my first auto scan. Oh, and it pulled a slippery road light which apparently means my traction control is Tango Uniform.
    In general when I've had multiple "Houston, we have a problem", Three Stooges style 'flush the toilet and the shower comes on' faults it is straight up electrical.
    While the scan below was running I started the process of exposing the front battery. I'll look over connections and maybe run down and get a new battery if it's the original one (9 friggin years old at this point, right?)
    As pointed out above, the DPF burn didn't run probably either because it is actually FUBAR or it won't run because there are codes. I've just cleared them and will take it for a drive after I address the battery.
    Our car didn't come with an owner's manual. Any more they assume you have no technical knowledge anyway and tell you to take it to the dealer for a good spanking.
    VCDS Version: Release 14.10.2 (x64)
    Data version: 20150311
    Sunday,28,June,2015,14:11:42:15876
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGPT77L67D004129   Mileage: 195070km-121210miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG001AGMª9805
       Revision: --H02---    Serial number: VWZ3Z0F6478811
       Coding: 0060575
       Shop #: WSC 23347 444 84359
       VCID: 61C303F8BB77AE29011-5140
    006482 - Turbocharger Control Module 1
                   P1952 - 000 - Defective - Intermittent
                        Fault Frequency: 25
                        Mileage: 194108 km
                        RPM: 2142 /min
                        Speed: 51.2 km/h
                        Load: 36.9 %
                        Bin. Bits: 00000000
                        Bin. Bits: 00100000
                        Absolute Pres.: 1611.6 mbar
                        Absolute Pres.: 1856.4 mbar
    Readiness: 1 1 0 0 0
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H37000    Serial number:
       Coding: 0004216
       Shop #: WSC 31414 000 00000
       VCID: 7F07A5802DC378D9175-5140
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D7B9F88674FAAC9459-5140
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 A    HW: 5WK 485 02
       Component: 29 Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F6478811
       Coding: 0147688
       VCID: 3163B3B8AB175EA9D11-515C
       Subsystem 1 - Part No: 4E0 905 852 E
       Component: ELV                 1940
    00956 - Key 2
                002 - Lower Limit Exceeded
    00164 - Battery Monitoring Control Module (J367) in Emergency Mode
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77F74DA005F340995F5-5140
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 T
       Component: CLIMAtronic R/L     4222
       Coding: 0020030
       VCID: 4183E3781BB7CE29211-5140
    00709 - Sunlight Photosensor 2 (G134)
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3002
       Coding: 0110815
       Shop #: WSC 05244 444 64165
       VCID: 4797FD603593F019EF5-5140
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG001AGSª9805
       Coding: 0060575
       VCID: 61C303F8BB77AE29011-515C
    006483 - Turbocharger Control Module 2
                   P1953 - 000 - Defective - Intermittent
                        Mileage: 194203 km
                        RPM: 1953 /min
                        Speed: 40.5 km/h
                        Load: 34.9 %
                        Absolute Pres.: 1570.8 mbar
                        Absolute Pres.: 1693.2 mbar
    012302 - Diesel Particulate Filter (Bank 2)
                   P300E - 000 - Restricted/Clogged - MIL ON
                        Fault Status: 11100000
                        Mileage: 194732 km
                        RPM: 2394 /min
                        Speed: 39.3 km/h
                        (no units): 0.0
                        Duty Cycle: 75.0 %
                        (no units): 224.40
                        Temperature: 12.6°C
                        Time: 0.0 s
       Part No: 3D0 909 601 H
       Component: 05 Airbag 8.4E++H01 0562
       Revision: BB38727     Serial number: 0008132:
       Coding: 0012341
       VCID: 28555EDC98CD1F6106F-515C
       Subsystem 1 - Part No: 7L0 959 339 C
       Component: BF-Gewichtsens. 006 0008
       Part No: 7L6 953 549 H
       Component: Lenksäulenmodul     3401
       Coding: 0010032
       VCID: 448DEA6C04A5DB010A7-5140
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 4895FE5C388DFF61E6F-515C
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000100
       VCID: 336FB9B0510B6CB9A3D-5140
       Part No: 6N0 909 901
       Coding: 0000006
       Shop #: WSC 23342 444 84068
       VCID: 70E576BC609D17A19EF-5140
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       VCID: 458BF7680F9FE2091D9-5140
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D1B0F48176F5A49159-5140
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 H
       Component: LUFTFDR.-CDC- 3C3P1 3099
       Coding: 0015521
       VCID: 38758E9C486D8FE196F-5140
       Component: Sitzverstellung     0703
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50A5D63CC0DD37A1BEF-5140
       Part No: 7L0 959 933 H
       Component: YM HSG              0400
       Coding: 0000085
       VCID: 4183E3781BB7CE29211-4B20
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 7L6 035 456
       Component: 08K Audioverst.     0105
       Subsystem 1 - Part No: 7L6 035 456
    No Faults Found
    Address 55: Headlight Range        Labels: 7L6-907-357.lbl
       Part No SW: 7L6 907 357     HW: 7L6 907 357
       Component: AFS-Steuergeraet    0003
       Revision:   H09       Serial number:
       Coding: 0000003
       Shop #: WSC 23347 444 59343
       VCID: 78F54E9C08ED4FE156F-5140
       Subsystem 1 - Part No: 7L6 941 329
       Component: AFS-Lst.-Modul l    X018
       Coding: 00000034
       Subsystem 2 - Part No: 7L6 941 330
       Component: AFS-Lst.-Modul r    X018
       Coding: 00000034
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014042
       VCID: 356B87A85F7F72898D9-5140
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C7D928C7C55A3C1727-5140
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J630434
       Coding: 0000101
       Shop #: WSC 31414 790 00001
       VCID: 72E17CB46E9125B168B-5140
       Part No SW: 7L6 959 107     HW: 7L6 959 107
       Component: J605  HECKKLAPPE    1110
       Revision: --H05---    Serial number: --------002637
       Coding: 0022110
    Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
       Part No: 7L6 919 044 T
       Component: DACHDISPLAY         0539
       Revision: 00900539    Serial number: 2009289.07
       VCID: 4895FE5C388DFF61E6F-5140
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 39738B98736796E9691-5140
    End-------------------------(Elapsed Time: 08:58)--------------------------
  13. Likes Eric, NZDubNurd, jyoung8607, ivagp, Dana liked this post
