Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Audi A8 Label files
    Did this problem occur out of the blue ?
    In your Autoscan from march, there was no communication problem with [06] and [36].
    Try this first before an possible address fix:
    First Ignition ON, then OFF
    1) Open Driver door and try memory buttons on both seats, any reaction ?
    2) Open Passenger door and try memory buttons on both seats, any reaction ?
    Is 1) or 2) true ?
  2. #12
    Mar 2015
    Rhode Island
    Is 1) or 2) true ?
    Yeah it was a on then off intermittent. I will check what you said and give you feedback.
  3. #13
    Mar 2015
    Rhode Island
    Quote Originally Posted by BostonSlaya View Post
    Ok here is a video on it.
    I did notice that my lights don't come on my passenger side door now to. I'll check a fuse but would have thought it would shoot a code? The driver and passenger side electric door module has the same coding? Also why is it after I put my key in or while it's running I have to hold the memory button to set my seat, but when there is no key I press it once and it goes by itself? Thanks
  4. #14
    Check harness door point under boot!
  5. #15
    From the information, I don't think it could be a missing/wrong controller address, as Jason correct suggested.
    To adapt the Controller Addresses, it is necessary to communicate with the Control modules.
    There is also no communication with Passenger controller.
    So it looks like CAN connection, fuse, ground, etc. as Jack also wrote, or Seat controllers as golfi_vend wrote.
  6. Likes Uwe, Dana, Jack@European_Parts liked this post
  7. #16
    United States
    Thanks Niels.
    Jason, I wanted to add some clarity to the missing/wrong controller address word that you remembered. That was a B8 chassis (2011ish A5/S5 convertible if I remember correctly) flood repair tech ticket and several control modules in addition to wiring were damaged. Both 06 and 36 were included in that list of replaced controllers but they used the identical part number so one would communicate and the other wouldn't.
    After some digging we determined that if one seat module failed, and the other one communicated in a non-flood repair, the brand new controller would have identified himself properly.
    However, if both controllers fail simultaneously the new ones may take the same address word or identity resulting in no communication to the other side with any scan tool. (Yes, the Audi dealer attempted to resolve this for the guy with the CP and SVM visits but failed) We had to unplug one of them to determine which address the one that was plugged in happened to respond to. I'll call that 36 for example so we moved it to the wrong side of the car and then changed an Adaptation channel to tell it you are 06 and turned the key off. We reconnected both controllers on the proper sides of the vehicle and things sorted out at that point or shortly after.
    In conclusion, the confused module in question needs to communicate or you won't be able to get into the Adp function. Modules that use different part numbers or coding bridges in the harness should be excluded from my example.
    On that note however I looked back at this scan and 06 wasn't online and 36 was unhappy:
    http://forums.ross-tech.com/showthre...ms-Please-help
    Kevin, do you have a old scan with both 06 and 36 communicating?
    Edit, I found a scan sent to us via email with 06 and 36 communicating (Wednesday,04,March,2015). If you don't have that please let me know and I'll paste it here.
  8. Likes Uwe, jyoung8607, Jack@European_Parts liked this post
  9. #17
    United States
    Kevin,
    We don't usually post or share any information sent privately however you have quite a few scans in our forum already so I figured it shouldn't be a problem. This was the oldest scan we have on file:
    >> MyAutoScan.txt
    >> VCDS Version: Release 14.10.1
    >> Data version: 20150130
    >> Wednesday,04,March,2015,14:17:50:14758
    >> Chassis Type: 4E (4E0)
    >> Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38
    >>           42 46 47 4F 52 53 55 56 61 62 65 72 75 76
    >> VIN: WAUML44E74N017518   Mileage: 74280km-46155miles
    >> 00-Steering Angle Sensor -- Status: OK 0000
    >> 01-Engine -- Status: Malfunction 0010
    >> 02-Auto Trans -- Status: OK 0000
    >> 03-ABS Brakes -- Status: OK 0000
    >> 05-Acc/Start Auth. -- Status: OK 0000
    >> 06-Seat Mem. Pass -- Status: Malfunction 0010
    >> 07-Control Head -- Status: OK 0000
    >> 08-Auto HVAC -- Status: Malfunction 0010
    >> 09-Cent. Elect. -- Status: OK 0000
    >> 0E-Media Player 1 -- Status: OK 0000
    >> 0F-Digital Radio -- Status: OK 0000
    >> 15-Airbags -- Status: Malfunction 0010
    >> 16-Steering wheel -- Status: OK 0000
    >> 17-Instruments -- Status: OK 0000
    >> 19-CAN Gateway -- Status: OK 0000
    >> 25-Immobilizer -- Status: OK 0000
    >> 28-HVAC, Rear -- Status: OK 0000
    >> 34-Level Control -- Status: Malfunction 0010
    >> 36-Seat Mem. Drvr -- Status: OK 0000
    >> 37-Navigation -- Status: OK 0000
    >> 38-Roof Electronics -- Status: Malfunction 0010
    >> 42-Door Elect, Driver -- Status: OK 0000
    >> 46-Central Conv. -- Status: Malfunction 0010
    >> 47-Sound System -- Status: OK 0000
    >> 4F-Centr. Electr. II -- Status: OK 0000
    >> 52-Door Elect, Pass. -- Status: OK 0000
    >> 53-Parking Brake -- Status: Malfunction 0010
    >> 55-Headlight Range -- Status: Malfunction 0010
    >> 56-Radio -- Status: OK 0000
    >> 61-Battery Regul. -- Status: Malfunction 0010
    >> 62-Door, Rear Left -- Status: Malfunction 0010
    >> 65-Tire Pressure -- Status: Malfunction 0010
    >> 72-Door, Rear Right -- Status: Malfunction 0010
    >> 75-Telematics -- Status: Malfunction 0010
    >> 76-Park Assist -- Status: OK 0000
    >> Address 01: Engine        Labels: 077-910-560-BFM.lbl
    >>    Part No SW: 4E0 910 560 A    HW: 4E0 907 560
    >>    Component: 4.2L V8/5V      G   0070
    >>    Revision: 00000000    Serial number: AUX3Z0CD531019
    >>    Coding: 0007773
    >>    Shop #: WSC 02313 785 00200
    >>    VCID: 1F4DDD45CE847AD977A-804A
    >> 4 Faults Found:
    >> 17981 - Left Engine Mount Solenoid Valve (N144)
    >>             P1573 - 004 - Open Circuit
    >> 18282 - Valve for Torque Support Mount
    >>             P1874 - 001 - Short to Plus
    >> 16804 - Catalyst System; Bank 1
    >>             P0420 - 002 - Efficiency Below Threshold
    >> 16814 - Catalyst System; Bank 2
    >>             P0430 - 002 - Efficiency Below Threshold
    >> Readiness: 0000 0001
    >> Address 02: Auto Trans        Labels: 09E-927-156.lbl
    >>    Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
    >>    Component: AG6 09E 4,2L5V USA  0110
    >>    Revision: 00000001    Serial number:        0027237
    >>    Coding: 0000002
    >>    VCID: 2447D2A9E7E259012A8-8071
    >> No fault code found.
    >> Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
    >>    Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
    >>    Component: ESP 5.7 allrad  H46 0510
    >>    Coding: 0007597
    >>    Shop #: WSC 23435 000 00000
    >>    VCID: 224BD4B1FDF65731584-8077
    >> Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
    >>    Part No SW: 4E0 910 131     HW: 4E0 909 131 A
    >>    Component:     FBS AUDID3  H03 0140
    >>    Revision: 01403903    Serial number: AUX3Z0CD531019
    >>    Coding: 0263168
    >>    Shop #: WSC 02311 785 00200
    >>    VCID: 58BFB659EB2ACDE1760-800D
    >>    Subsystem 1 - Part No: 4E0 905 852 C
    >>    Component: ELV                 1734
    >> Address 06: Seat Mem. Pass        Labels: None
    >>    Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
    >>    Component: Sitzmemory BFS H02  0010
    >>    Revision: 00000000    Serial number: 5DS 008 795-03
    >>    Coding: 3940960
    >>    Shop #: WSC 23435 444 82899
    >> 1 Fault Found:
    >> 01720 - Sensor for Seat-Back Recline; Pass. Seat (G279)
    >>             007 - Short to Ground
    >>              Freeze Frame:
    >>                     Fault Status: 01100111
    >>                     Fault Priority: 4
    >>                     Fault Frequency: 24
    >>                     Reset counter: 30
    >>                     Mileage: 116320 km
    >>                     Time Indication: 0
    >>                     Date: 2015.01.28
    >>                     Time: 17:44:16
    >> Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
    >>    Part No SW: 4E0 910 729 J    HW: 4E0 035 729
    >>    Component: Interfacebox    H43 0600
    >>    Revision: 00000000    Serial number: 346IP047514325
    >>    Coding: 0000103
    >>    VCID: 2F6D2D85BE24EA59C7A-807A
    >>    Subsystem 1 - Part No: 4E0 910 611
    >>    Component: E0380 BedienteilH01 0050
    >>    Subsystem 2 - Serial number: 00000000097794
    >>    Subsystem 3 - Serial number: 0113.11.130000000100010015˙
    >>    Subsystem 4 - Serial number: 010015˙
    >> Address 08: Auto HVAC        Labels: None
    >>    Part No SW: 4E0 910 043     HW: 4E0 820 043 B
    >>    Component: KLIMAAUTOMAT    016 0240
    >>    Revision: 00000022    Serial number: 00000000033347
    >>    Coding: 1151313
    >>    VCID: 5ABBAC519526DFF1404-800F
    >>    Subsystem 1 - Part No: 4E0 910 772 A
    >>    Component: Sitzluefter  FS H02  010
    >>    Subsystem 2 - Part No: 4E0 910 772 A
    >>    Component: Sitzluefter BFS H02  010
    >>    Subsystem 3 - Serial number: 898053000
    >>    Subsystem 4 - Serial number: HO15122003065A000000000168˙† 89
    >>    Subsystem 5 - Serial number: 000168˙† 898053000      000-SHO
    >>    Subsystem 6 - Serial number:     000-SHO18122003065A00000000
    >>    Subsystem 7 - Serial number: 65A000000000072˙
    >> 1 Fault Found:
    >> 00066 - Rear Right Footwell Heater (Z43)
    >>             004 - No Signal/Communication
    >>              Freeze Frame:
    >>                     Fault Status: 01100100
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:05:13
    >>              Freeze Frame:
    >>                     Voltage: 11.20 V
    >> Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
    >>    Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
    >>    Component: ILM Fahrer      H11 0100
    >>    Coding: 0111113
    >>    VCID: 2A5B3C9185C68F71104-807F
    >>    Subsystem 1 - Part No: 4E1 910 113
    >>    Component: Wischer WWS D3  H30 0320
    >>    Coding: 00000030
    >>    Shop #: WSC 02313
    >> Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
    >>    Part No SW: 4E0 910 111     HW: 4E0 035 111
    >>    Component: CD-Changer      H43 0220
    >>    Revision: 00000501    Serial number: AUZ5ZBD1033967
    >>    Shop #: WSC 00000 000 00000
    >>    VCID: 56A3B861E13EFB9164C-8003
    >> Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
    >>    Part No SW: 4E0 910 593 B    HW: 4E0 035 593
    >>    Serial number: AUZ4Z7E20
    >>    VCID: 2643C8A191DEAB1134C-8073
    >> Address 15: Airbags        Labels: 4E0-910-655-84.lbl
    >>    Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
    >>    Component: Airbag 8.4E+    H10 0920
    >>    Coding: 0530707
    >> 1 Fault Found:
    >> 01220 - Rear Side Airbag Igniter; Passenger Side (N202)
    >>             001 - Upper Limit Exceeded - Intermittent - MIL ON
    >> Address 16: Steering wheel        Labels: 4E0-910-549.lbl
    >>    Part No SW: 4E0 910 549     HW: 4E0 953 549 A
    >>    Component: Lenksäulenmodul H13 0040
    >>    Coding: 0012241
    >>    VCID: 65C18FADAC586009FD6-8030
    >>    Subsystem 1 - Part No: XXXXXXXXXXX
    >>    Component: Lenkradmodul    H04 0080
    >> Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
    >>    Part No SW: 4E0 910 900     HW: 4E0 920 950 B
    >>    Component: KOMBIINSTR. VDO H44 0090
    >>    Revision: D15         Serial number: AUDID3CD006664
    >>    Coding: 0000001
    >>    Shop #: WSC 65537 000 00032
    >>    VCID: 5CB7AA499F1221C1528-8009
    >> Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
    >>    Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
    >>    Component: Gateway         H07 0030
    >>    Revision: 07          Serial number: 0200503C0111AE
    >>    Coding: FCFE7FDD1B2B04
    >>    Shop #: WSC 07228 444 53694
    >> Address 25: Immobilizer        Labels: 4E0-910-131.lbl
    >>    Coding: 0263168
    >>    Component: ELV                 1734
    >>    4E0905852C  ELV                 1734
    >> Address 28: HVAC, Rear        Labels: None
    >>    Part No SW: 4E0 910 158     HW: 4E0 919 158 A
    >>    Component: KLIMA-STG. FOND 015 0210
    >>    Revision: 00000014    Serial number: 00000000013996
    >>    Coding: 0000000
    >>    VCID: 61C99BBDB8700C2901E-8034
    >> Address 34: Level Control        Labels: 4E0-910-553.lbl
    >>    Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
    >>    Component: LUFTFDR.-CDC    H05 4290
    >>    Coding: 0015510
    >>    Shop #: WSC 22145 444 54027
    >>    VCID: 2541CFADECD8A0093D6-8070
    >> 1 Fault Found:
    >> 00776 - Level Control System Sensor; Left Front (G78)
    >>             012 - Electrical Fault in Circuit
    >>              Freeze Frame:
    >>                     Fault Status: 11101100
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 2
    >>                     Reset counter: 30
    >>                     Mileage: 0 km
    >>                     Time Indication: 0
    >> Address 36: Seat Mem. Drvr        Labels: None
    >>    Part No SW: 4E0 910 760 C    HW: 4E0 959 760
    >>    Component: Sitzmemory FS  H07  0060
    >>    Coding: 4071522
    >>    VCID: 2345D1B5E2EC5E39532-8076
    >> Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
    >>    Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
    >>    Component: MNS US          H42 0570
    >>    Revision: 00000000    Serial number: 355LL037514310
    >>    VCID: 35611FED5C78D0898D6-8060
    >> Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
    >>    Part No SW: 4E0 910 135 A    HW: 4E0 907 135
    >>    Component: Dachknoten D3   H01 0090
    >>    Serial number: 00000332500063
    >>    Coding: 0003989
    >>    VCID: 1D31E74DC48868C9656-8048
    >> 4 Faults Found:
    >> 02138 - Control Circuit for Front Right Interior Lights
    >>              Freeze Frame:
    >>                     Fault Status: 01101100
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:14:00
    >> 00211 - Control Circuit for Rear Illumination Lights
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:17:00
    >> 02139 - Control Circuit for Left Front Interior Lights
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:18:00
    >> 02141 - Control Circuit for Front Right Makeup Mirror Light
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 30
    >>                     Mileage: 74272 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.04
    >>                     Time: 11:31:00
    >> Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
    >>    Part No SW: 4E1 910 802     HW: 4E1 959 801
    >>    Component: Türsteuer.FS BRM005 0110
    >>    Coding: 0028196
    >>    VCID: 5EB3A041890E33D13CC-800B
    >> Address 46: Central Conv.        Labels: 4E0-910-289.lbl
    >>    Part No SW: 4E0 910 289 A    HW: 4E0 907 289
    >>    Component: Komfortgeraet   H03 0030
    >>    Revision: 00300003    Serial number:  W040312110112
    >>    Coding: 0065086
    >>    VCID: 275DC5A596D4B2190FA-8072
    >>    Subsystem 1 - Part No: 4E0 910 853
    >>    Component: Heckdeckel      H06 0060
    >>    Subsystem 2 - Part No: 4E0 907 719
    >>    Component: Neigungssensor  H02 0020
    >> 4 Faults Found:
    >> 01134 - Alarm Horn (H12)
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 254
    >>                     Reset counter: 30
    >>                     Mileage: 214225 km
    >>                     Time Indication: 0
    >>                     Date: 2003.10.18
    >>                     Time: 11:58:49
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 214225 km
    >>                     Time Indication: 0
    >>                     Date: 2003.10.18
    >>                     Time: 11:58:49
    >> 01504 - Bulb for License-Plate Light (X)
    >>             009 - Open or Short to Ground
    >>              Freeze Frame:
    >>                     Fault Status: 01101001
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 193858 km
    >>                     Time Indication: 0
    >>                     Date: 2011.08.15
    >>                     Time: 01:50:33
    >> 01565 - Luggage Compartment Light (W3)
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 106
    >>                     Reset counter: 30
    >>                     Mileage: 231779 km
    >>                     Time Indication: 0
    >>                     Date: 2015.01.03
    >>                     Time: 15:00:26
    >> Address 47: Sound System        Labels: 4E0-910-223.lbl
    >>    Part No SW: 4E0 910 223 H    HW: 4E0 035 223 B
    >>    Component: DSP-High D3/AUX H13 0370
    >>    Revision: Dev_D01     Serial number: 00000000655399
    >>    Coding: 0000018
    >> Address 4F: Centr. Electr. II        Labels: None
    >>    Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
    >>    Component: ILM Beifahrer   H08 0020
    >>    Revision:             Serial number: 00000000030051
    >>    Coding: 0010111
    >>    VCID: 1E33E041C98E73D17CC-804B
    >>    Subsystem 1 - Serial number: VK4978T078WE
    >> Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
    >>    Part No SW: 4E1 910 802     HW: 4E1 959 802
    >>    Component: Türsteuer.BF BRM005 0110
    >>    Coding: 0028196
    >> Address 53: Parking Brake        Labels: 4E0-910-801.clb
    >>    Part No SW: 4E0 910 801 A    HW: 4E0 907 801
    >>    Component: EPB  AV1C1010   H01 1010
    >>    Revision: AV1C1010
    >>    Coding: 0000532
    >>    Shop #: WSC 23435 444 58960
    >> 1 Fault Found:
    >> 02596 - Rear Brake Pads Worn
    >>             008 - Implausible Signal
    >>              Freeze Frame:
    >>                     Fault Status: 01111000
    >>                     Fault Priority: 6
    >>                     Fault Frequency: 1
    >>                     Reset counter: 9
    >>                     Time Indication: 0
    >>              Freeze Frame:
    >>                     Voltage: 6.21 V
    >>                     Count: 61
    >> Address 55: Headlight Range        Labels: 4E0-910-357.lbl
    >>    Part No SW: 4E0 910 357     HW: 4E0 907 357
    >>    Component: Pre-AFS         H01 0040
    >>    Coding: 0000001
    >>    VCID: 62CB94B1BD761731184-8037
    >> 1 Fault Found:
    >> 01310 - Level Control System Control Module (J197)
    >>             013 - Check DTC Memory - Intermittent
    >>              Freeze Frame:
    >>                     Fault Status: 00101101
    >>                     Fault Priority: 2
    >>                     Fault Frequency: 0
    >>                     Reset counter: 40
    >>                     Mileage: 74168 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:13:47
    >> Address 56: Radio        Labels: 4E0-910-541.lbl
    >>    Part No SW: 4E0 910 541 B    HW: 4E0 035 541
    >>    Component: TUNER EU/US/RDW H41 0220
    >>    Revision: 00000000    Serial number: 304CE047583230
    >>    Coding: 0000002
    >>    Shop #: WSC 06802 176 59446
    >> Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
    >>    Part No SW: 4E0 910 181 B    HW: 4E0 915 181
    >>    Component: ENERGIEMANAGER  H02 0240
    >>    Revision: 00000000    Serial number: 00000001900564
    >>    Subsystem 1 - Part No: 000 915 105 AK
    >>    Component: von VA0  1401050124
    >>    Coding: 303030393135313035414B56413031343031303530313234
    >>    Shop #: WSC 22186 444 58975
    >> 4 Faults Found:
    >> 02273 - Quiescent Current Stage 2
    >>             000 -  -  - Intermittent
    >>              Freeze Frame:
    >>                     Fault Status: 00100000
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 19
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:04:57
    >> 02276 - Quiescent Current Stage 5
    >>             000 -  -
    >>              Freeze Frame:
    >>                     Fault Status: 01100000
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 17
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:25
    >> 02274 - Quiescent Current Stage 3
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 16
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:35
    >> 02277 - Quiescent Current Stage 6
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 16
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:45
    >> Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
    >>    Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
    >>    Component: Türsteuer.HL BRM003 0100
    >>    Coding: 0032364
    >> 1 Fault Found:
    >> 02130 - Interior Door Lighting
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 14
    >>                     Reset counter: 30
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 09:57:34
    >> Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
    >>    Part No SW: 4E0 910 273     HW: 4E0 907 273
    >>    Component: Reifendruck 2   H01 0210
    >>    Coding: 0212127
    >>    VCID: 5FCD9D458E043AD937A-800A
    >> 2 Faults Found:
    >> 01477 - System Switched Off
    >>             000 -  -
    >>              Freeze Frame:
    >>                     Fault Priority: 4
    >>                     Fault Frequency: 29
    >>                     Reset counter: 30
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:01:28
    >>              Freeze Frame:
    >>                     Speed: 0.0 km/h
    >>                     Temperature: 21.0*C
    >>                     Error Code: 0
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >> 01521 - Sensor for Tire Pressure
    >>             004 - No Signal/Communication - MIL ON
    >>              Freeze Frame:
    >>                     Fault Status: 11100100
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74182 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 13:37:41
    >>              Freeze Frame:
    >>                     Speed: 142.0 km/h
    >>                     Temperature: 31.0*C
    >>                     Error Code: 0
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >> Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
    >>    Part No SW: 4E0 910 802     HW: 4E0 959 802 A
    >>    Component: Türsteuer.HR BRM005 0110
    >>    Coding: 0028196
    >>    VCID: 5DB1A74D840828C9256-8008
    >> 1 Fault Found:
    >> 02111 - Motor for Window Regulator
    >>             005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    >>              Freeze Frame:
    >>                     Fault Status: 00100101
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 66
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 09:59:54
    >> Address 75: Telematics        Labels: None
    >>    Part No SW: 4E0 910 616     HW: 4E0 035 616 A
    >>    Component: Telematik USA1      0070
    >>    Revision: 00000004    Serial number: 0000ATD3006845
    >>    Coding: 0000005
    >>    VCID: 60CF9EB9B07A05210E0-515E
    >> No Faults Found
    >>   or DTCs not supported by controller
    >>   or a communication error occurred
    >> Address 76: Park Assist        Labels: 4E0-910-283.lbl
    >>    Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
    >>    Component: Parkhilfe 8-Kan H11 0010
    >>    Revision: --.--.--    Serial number: 00000335600021
    >>    Coding: 0001208
    >>    VCID: 2149DBBDF8F04C2941E-8074
    >> End-------------------------(Elapsed Time: 05:18)--------------------------
    If you want it removed just report my post. If I don't notice it first Uwe can pull it out.
    delboy is correct. The 06 and 36 modules in this car use two entirely different part numbers.
  10. #18
    Mar 2015
    Rhode Island
    Kevin,
    >> MyAutoScan.txt
    >>    Coding: 0007773
    >> 4 Faults Found:
    >>    Coding: 0000002
    >>    Coding: 0007597
    >>    Coding: 0263168
    >>    Component: ELV                 1734
    >>    Coding: 3940960
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 4
    >>                     Fault Frequency: 24
    >>                     Reset counter: 30
    >>                     Mileage: 116320 km
    >>                     Time Indication: 0
    >>                     Date: 2015.01.28
    >>                     Time: 17:44:16
    >>    Coding: 0000103
    >>    Coding: 1151313
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:05:13
    >>              Freeze Frame:
    >>                     Voltage: 11.20 V
    >>    Coding: 0111113
    >>    Coding: 00000030
    >>    Shop #: WSC 02313
    >>    Coding: 0530707
    >> 1 Fault Found:
    >>    Coding: 0012241
    >>    Coding: 0000001
    >>    Coding: 0263168
    >>    Component: ELV                 1734
    >>    4E0905852C  ELV                 1734
    >>    Coding: 0000000
    >>    Coding: 0015510
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 2
    >>                     Reset counter: 30
    >>                     Mileage: 0 km
    >>                     Time Indication: 0
    >>    Coding: 4071522
    >>    Coding: 0003989
    >> 4 Faults Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:14:00
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:17:00
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:18:00
    >>              Freeze Frame:
    >>                     Fault Priority: 0
    >>                     Fault Frequency: 1
    >>                     Reset counter: 30
    >>                     Mileage: 74272 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.04
    >>                     Time: 11:31:00
    >>    Coding: 0028196
    >>    Coding: 0065086
    >> 4 Faults Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 214225 km
    >>                     Time Indication: 0
    >>                     Date: 2003.10.18
    >>                     Time: 11:58:49
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 214225 km
    >>                     Time Indication: 0
    >>                     Date: 2003.10.18
    >>                     Time: 11:58:49
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 193858 km
    >>                     Time Indication: 0
    >>                     Date: 2011.08.15
    >>                     Time: 01:50:33
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Reset counter: 30
    >>                     Mileage: 231779 km
    >>                     Time Indication: 0
    >>                     Date: 2015.01.03
    >>                     Time: 15:00:26
    >>    Coding: 0000018
    >>    Coding: 0010111
    >>    Coding: 0028196
    >>    Revision: AV1C1010
    >>    Coding: 0000532
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 6
    >>                     Fault Frequency: 1
    >>                     Reset counter: 9
    >>                     Time Indication: 0
    >>              Freeze Frame:
    >>                     Voltage: 6.21 V
    >>                     Count: 61
    >>    Coding: 0000001
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 2
    >>                     Fault Frequency: 0
    >>                     Reset counter: 40
    >>                     Mileage: 74168 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:13:47
    >>    Coding: 0000002
    >> 4 Faults Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 19
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:04:57
    >>             000 -  -
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 17
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:25
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 16
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:35
    >>              Freeze Frame:
    >>                     Fault Priority: 7
    >>                     Fault Frequency: 16
    >>                     Reset counter: 255
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:21:45
    >>    Coding: 0032364
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 14
    >>                     Reset counter: 30
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 09:57:34
    >>    Coding: 0212127
    >> 2 Faults Found:
    >>             000 -  -
    >>              Freeze Frame:
    >>                     Fault Priority: 4
    >>                     Fault Frequency: 29
    >>                     Reset counter: 30
    >>                     Mileage: 74163 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 10:01:28
    >>              Freeze Frame:
    >>                     Speed: 0.0 km/h
    >>                     Temperature: 21.0*C
    >>                     Error Code: 0
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 25
    >>                     Mileage: 74182 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 13:37:41
    >>              Freeze Frame:
    >>                     Speed: 142.0 km/h
    >>                     Temperature: 31.0*C
    >>                     Error Code: 0
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>                         Not Recogn.
    >>    Coding: 0028196
    >> 1 Fault Found:
    >>              Freeze Frame:
    >>                     Fault Priority: 3
    >>                     Fault Frequency: 1
    >>                     Reset counter: 66
    >>                     Mileage: 74160 km
    >>                     Time Indication: 0
    >>                     Date: 2015.03.02
    >>                     Time: 09:59:54
    >>    Coding: 0000005
    >> No Faults Found
    >>    Coding: 0001208
    Dana, Thanks for the reply on the thread I forgot about going back to this and fix. I'm still having the same problem. So with you saying 06 and 36 use different part numbers? I'm still getting the error codes thanks....
