Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 122
Thread: Audi A6 2006 with EVAP problem (P2404)
    We do it because we are stupid ignorant noobies, and just do what the experts (see above) tell us (i.e., post the results of your Auto-Scan). In my particular field of endeavor, I'm not a noobie nor am I ignorant of the general expertise level, but here I am. Sorry you have to endure my ramblings.
    Still no posted auto-scan............
    Stop rambling post the scan......
    What is LDP condition of operation when running test 071 and or 0x01-03 Outputs?
    Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
    Part No SW: 4F1 910 559 F HW: 4F1 907 559 A
    Component: 3.2l V6 FSI 0040
    Revision: --H15--- Serial number:
    Coding: 010D0106190F0120
    Shop #: WSC 98765 666 36124
    VCID: 2E591F2BB93C7D51CC3-807B
    009220 - EVAP Leak Detection Pump Sense Circuit
    P2404 - 006 - Implausible Signal - MIL ON
    Fault Status: 10100001
    Fault Frequency: 10
    Reset counter: 40
    Mileage: 187356 km
    Date: 2015.06.11
    Time: 08:13:31
    RPM: 2080 /min
    Mass Air / Rev.: 294.3 mg/str
    Temperature: 91.5°C
    Part Throttle
    Voltage: 13.77 V
    Speed: 61.0 km/h
    This code doesn't always mean there is a leak.......it means there could be and is most likely a wiring/power supply problem or issue with noid/reed on LDP or faulty controller.
    Using VCDS with the 071 test in conjunction with WD .....while observing block and DVOM would be a good idea.
    It is highly unlikely you would get an implausible signal from a leak in tank.
  2. #12
    Quote Originally Posted by Keithuk View Post
    I don't know why users always post 00470 - Company Comfort Databus in Single Wire when its Combination Comfort Data Bus in Single Wire.
    http://wiki.ross-tech.com/wiki/index.php/00470
    Because there's a discrepancy between the text in VCDS and the text in the Wiki.
    The text in VCDS is a more literal translation of the original German, "Konzern-Datenbus Komfort im Eindraht" than the English text in the Wiki.
  3. Likes Dana liked this post
  4. #13
    Jun 2015
    Monday,22,June,2015,13:52:20:11064
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: WAUKG74F66N034772   License Plate:
    Mileage: 187820km-116705mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53 55
              56 61 62 65 6D 72 77
    VIN: WAUKG74F66N034772   Mileage: 187820km-116705miles
                        Fault Frequency: 10
                        Reset counter: 40
                        Mileage: 187356 km
                        Date: 2015.06.11
                        Time: 08:13:31
                        RPM: 2080 /min
                        Temperature: 91.5°C
                            Part Throttle
                        Voltage: 13.77 V
                        Speed: 61.0 km/h
    Readiness: 0000 0100
       Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4042926
       Shop #: WSC 02325 785 00200
       VCID: 31630457A80262A9D11-8064
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Coding: 0020895
       VCID: 2D5B1827B43A0649F59-8078
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H30 0160
       Revision: 27100401    Serial number: 10600300181659
       Coding: 0000139
       Shop #: WSC 02323 785 00200
       VCID: 63CFBE1FA27E803913D-8036
       Subsystem 1 - Part No: 4F0 910 131 J
       Component: FBSAUDIC6 EZS   H44 0070
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H39 0040
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 731 B    HW: 4E0 035 729
       Component: Interfacebox    H43 1190
       Revision: 00000000    Serial number: 303FC057501703
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: 2143F417F8E2D229411-8074
       Component: Bedienteil MMIC6H07 0050
       Subsystem 2 - Serial number: 00000000175950
       Subsystem 3 - Serial number: 0109.06.050000000100010077’
       Subsystem 4 - Serial number: 010077’
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000030027802
       Coding: 0524582
       VCID: 5BBF86FF9A0EB8F95BD-800E
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H15 0080
       Coding: 0013123
       VCID: 66C9A70B514CF511F43-8033
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
                        Fault Frequency: 217
                        Reset counter: 150
                        Mileage: 185560 km
                        Date: 2015.05.03
                        Time: 10:57:00
                        Reset counter: 150
                        Mileage: 185560 km
                        Date: 2015.05.03
                        Time: 10:57:00
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7183772
       VCID: 1B3FC6FFDA8EF8F99BD-804E
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0300
       Revision: 10H29000    Serial number: 00359D08CLRC
       Coding: 0013878
       Shop #: WSC 40329 444 53665
       VCID: 2A51133B85D4117110B-807F
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME0A266372/
       Subsystem 3 - Serial number: 6342CSME0A300A73
       Subsystem 4 - Serial number: 6352QSME022217595
       Subsystem 5 - Serial number: 6362QSME014835054
       Subsystem 6 - Serial number: 63734SME02133E7B%
       Subsystem 7 - Serial number: 63834SME02391C6D5
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026051530016
       Coding: 0002022
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H10 0630
       Revision: 00900000    Serial number: 4R8703845
       Coding: 0083263
       Shop #: WSC 61847 001 1048576
       VCID: 1E39CFEBC99CEDD17C3-804B
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 120080560282B7
       Coding: 6CFE73CD1B1106
       Shop #: WSC 01115 444 54714
       VCID: 2757EA0F96C62C190F5-8072
                        Fault Status: 00101011
                        Reset counter: 180
                        Mileage: 187663 km
                        Date: 2015.06.18
                        Time: 11:14:33
       Coding: 0082946
       VCID: 61C3B417B8629229011-8034
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00000000    Serial number: Xpr
       Coding: 0036587
       Shop #: WSC 02327 785 00200
       VCID: 2953EC3780D21A69191-807C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H18 0130
       Revision: 01300018    Serial number: 01004703410000
       Coding: 7764541
       Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
       Component: DSP-High C6     H09 0140
       Revision: PROD_01     Serial number: 00000000791217
       Coding: 0000116
       VCID: 1C3DC5E3DF80FFC1927-8049
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000002110
       Coding: 0002114
       VCID: 5EB98FEB891CADD13C3-800B
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00000000    Serial number: (r
       Coding: 0036587
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       VCID: 5DBB88E7841AB6C9259-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000016
       VCID: 2649E70B91CC3511343-8073
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394F$057557178
       VCID: 234FFE1FE2FEC03953D-8076
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000050776
       Shop #: WSC 02445 823 62659
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  1506090014
       Coding: 344630393135313035452056413031353036303930303134
       Shop #: WSC 00000 384 00290
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Fault Frequency: 41
                        Reset counter: 188
                        Mileage: 185613 km
                        Date: 2015.05.03
                        Time: 23:34:30
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0036394
       VCID: 69D3AC374052DA69D91-803C
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000700006980
       Coding: 0062221
       Shop #: WSC 02334 785 00200
       VCID: 60C5B113B3689B210EF-8035
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 B
       Component: ValeoHeckdeckel H14 0280
       Revision: --H14001    Serial number: E5030000B
       Shop #: WSC 23250 431 715754
       VCID: 6CDDD5234FA0CF41A27-8039
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: KK02.06.05--H14001001A0037’
       Subsystem 4 - Serial number: 1A0037’
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0036394
       Part No SW: 4F0 910 336 B    HW: 4E0 862 335
       Component: Handyvorb2      H11 0440
       Revision: 00000000    Serial number: 00000007502536
       Coding: 0010900
       VCID: 2241FB1BFDE4C93158B-8077
    End-------------------------(Elapsed Time: 03:08)--------------------------
  6. #14
    Thank you for the scan....
    Your new mission............
    Please investigate ( D107 ) T17b/13 at current track 163 for water damage or corrosion.
    ( T17b - 17-pin connector, black, coupling station on electronics box, left in plenum chamber )
  7. #15
    Jun 2015
    Thank you so much for the actionable suggestion - I had no idea that the "passing" tests would provide additional info!
    In the P2404 error code, I see "Temperature: 91.5°C". Now this cannot possibly be the air temperature. I googled around for P2404, and see a bunch of other such freeze frames, and each one has a temperature of between 20 and 30 degrees C. Could my sensor be defective? Should I change it in any case?
  8. #16
    Nope .......not related.
    Stop the shot gun repair techniques.......
    Traditionally the LDP tests run when engine and intake temp are low, however,.......... in FSI and later CAN cars, it runs more frequent during throttle offset and under slight load.
    Continued tests in 071 during idle will historically result with small leak reported in cars after 2005>
    It would be a good idea to isolate the zones and do a crimp test to verify the consistency of the noids ability to hold the PSI...........( Advised )
  9. #17
    Jun 2015
    I looked in the Bentley manual and found the schematic with T17b and the EVAP pump on it (pages 2/12 and 2/13). I went to component locations, and looked at every section in vain to find a locator. Is this T17b - the circled connector? In any case I opened it up, the contacts are pristine. I see that D107 is the power bus going to the Purge Value as well as the EVAP pump, and that it is fused. I plan to check the fuse (when I figure out where it is), but wouldn't Auto-Scan pick that up?
    This car is garaged and in excellent condition.
  10. #18
    Jun 2015
    My wife (who drives the car) has reset this code many times using the "Automatic" app (and ODB widget). It normally triggers when she is driving around 30-40 MPH and many minutes after starting the car.
  11. #19
    Does that circled aforementioned connector look like it holds 17 terminals or wires?
    Time to RTFB the section called how to read WD in the manual.
    Get a tone generator and test from LDP up > Just follow the noise ......... Run a fast overlay.
    See if supply was faulty you would see DTC's for other BUS D107 items most likely.
    I would tests zones first for holding PSI generated by LDP before I went nuts with harness.
    Run the LDP manually with 071 and crimps in place to establish the hold or is it electrical!
  12. #20
    Jul 2015
    I'm in the same exact boat. I just had the evap-pump replaced and the CEL light remained off for about 30 miles.
    Not sure where to go next my VAG output is. Also readiness code went from 0000 to 0010.
    I do see a lot of notes about the J757 relay being the cause. I'm embarrassed to say I am unable to locate. (any hints)
    Don't mind taking to my mechanic,(who initially replace the Evap-pump) but relay seems something i could handle.
    And for the 13.00 it might be worth the shot. here is my output.
    Thank you guys..
    Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
    Component: 3.2l V6 FSI 0030
    Coding: 0000000000000000
    Shop #: WSC 08815 444 53817
    VCID: 2B554FDC8AA1AF79EBD-807E
    Reset counter: 40
    Mileage: 206704 km
    Date: 2015.07.01
    Time: 09:01:30
    RPM: 1568 /min
    Mass Air / Rev.: 245.3 mg/str
    Temperature: 46.5°C
    Part Throttle
    Voltage: 13.16 V
    Speed: 45.0 km/h
