Audi A6 2006 with EVAP problem (P2404)
dhoerl
C?ID=131476
My Audi A6 2006 is having persistent P2404 CEL codes. I can go a few days, then one pops up. I have looked at various engine vacuum lines (and fixed one that was causing a slew of other codes, the tube near the oil dipstick that is a common problem). I replaced the Purge Value, no change, and also replaced the J757 relay that Bentley claims is often the problem. The gas cap looks good and the o-ring is in good condition.
I have read that the Audi VAG tool can be used to test the EVAP system:
"Yes, with VAG-com. Go into 01 engine electronics, 04 basic settings, group 070 and 071. One is a tank leak check, the other is purge valve function."
I didn't see anything on the Ross-Tech site or in the manual about this. Is there an EVAP test I can run using your software?
Did you see the P-code forum here?
Please post a complete auto-scan in code tags and maybe have a look at the repair manual.
www.erwin.audi.com
Here is a helpful link........
http://wiki.ross-tech.com/wiki/index.php/18836/P2404/009220
Ahhhh you could use the output tests for the N80 and LDP in addition to those 070 and 071 block tests.
0x1-03 GO/NEXT! RTFB
There is this thingy they call a mighty vac I suggest you do some reading on.
Smoke in a CAN?
dhoerl
C?ID=131476
Actually I misstated where I read about J757 - it was from the Ross-Tech WIKI you reference. The tests - well, I have read the Bentley manual. They usually reference some VAG setting or other tool not easily found. That's why I asked - is there a specific set of directions to diagnose this one failure. I guess not, but that's why I asked.
I have a Mini-Vac tool - it shows that the tube near the dipstick is not holding vacuum, but this with the engine turned off. Should it hold vacuum? well, no way to tell - there is nothing I can find that tells you this. So sure, I can pull the rear wheel off, try to figure out what tube is what, and use a plug to verify the pipe/hose is not leaking. All that said, there are so many complaints about this particular code - I was hoping there might be something besides "read the manual" (which is not for the faint of heart).
Nope..........Isolate zones manually......
It starts with the heart of information called an auto-scan....... to establish all attributes.
"Core control is aware of the problem .......no information is currently available"
Auto-scan please or security access is a negative response from controller.
dhoerl
C?ID=131476
I'm quite new to this tool, and having a hard time understanding what your reply means. I see there is an "Auto-Scan" button. Are you telling me if I auto-scan, I may get more codes that will help me determine the problem?
With the cracked tube - the one going to the EVAP pump - I was getting a slew of errors. Finding and fixing that pipe caused most codes to go away. But I didn't do an auto-scan, so guess I can do that and see what happens.
Have no idea of what "security access is a negative response from controller" means - possibly that without posting the results of auto-scan no one can help me?
In any case, I'll isolate all the components by hand and try to find a leak somewhere.
Thank you for replying.
David,
One of the things Jack is trying to tell you is that in a modern car, with all the systems heavily networked together, it's important to look at any issues in a holistic manner, i.e. in the context of the whole car. That's why we ask people to post complete Auto-Scans. There's a tutorial on how to do that here.
Crimp tests of the N80 line should be done to see if the valve is stuck open, while doing the LDP 071 test and very common.
A dead give away the N80 is open is the fuel tank will suck down, instead of pressurizing...... like a beer can being crushed.
It sucks down so hard the straps can appear loose on tank visually.
Sorry for my poor humor from BSG.
dhoerl
C?ID=131476
I ran a complete scan, and there were these 3 errors:
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 010D0106190F0120
   Shop #: WSC 98765 666 36124
   VCID: 2E591F2BB93C7D51CC3-807B
009220 - EVAP Leak Detection Pump Sense Circuit
               P2404 - 006 - Implausible Signal - MIL ON
                    Fault Status: 10100001
                    Fault Frequency: 10
                    Reset counter: 40
                    Mileage: 187356 km
                    Date: 2015.06.11
                    Time: 08:13:31
                    RPM: 2080 /min
                    Mass Air / Rev.: 294.3 mg/str
                    Temperature: 91.5°C
                        Part Throttle
                    Voltage: 13.77 V
                    Speed: 61.0 km/h
Readiness: 0000 0100
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Component: Gateway         H10 0060
   Revision: 10          Serial number: 120080560282B7
   Coding: 6CFE73CD1B1106
   Shop #: WSC 01115 444 54714
   VCID: 2757EA0F96C62C190F5-8072
                    Fault Status: 00101011
                    Reset counter: 180
                    Mileage: 187663 km
                    Date: 2015.06.18
                    Time: 11:14:33
   Component: ENERGIEMANAGER  H12 0490
   Revision: 00000000    Serial number: 00000000050776
   Shop #: WSC 02445 823 62659
   VCID: 234FFE1FE2FEC03953D-8076
   Subsystem 1 - Part No: 4F0 915 105 E
   Component: von VA0  1506090014
   Coding: 344630393135313035452056413031353036303930303134
   Shop #: WSC 00000 384 00290
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 41
                    Reset counter: 188
                    Mileage: 185613 km
                    Date: 2015.05.03
                    Time: 23:34:30
What I found really interesting was that the air temperature was close to boiling in the P2404 error: "91.5°C"
Keithuk
Stoke on Trent, England
C?ID=122432
Reset counter: 180
Mileage: 187663 km
Date: 2015.06.18
Time: 11:14:33
I don't know why users always post 00470 - Company Comfort Databus in Single Wire when its Combination Comfort Data Bus in Single Wire.
http://wiki.ross-tech.com/wiki/index.php/00470
dhoerl
C?ID=131476
We do it because we are stupid ignorant noobies, and just do what the experts (see above) tell us (i.e., post the results of your Auto-Scan). In my particular field of endeavor, I'm not a noobie nor am I ignorant of the general expertise level, but here I am. Sorry you have to endure my ramblings.
Still no posted auto-scan............:banghead:
Stop rambling post the scan......:p
What is LDP condition of operation when running test 071 and or 0x01-03 Outputs?
Fault Frequency: 10
Reset counter: 40
Mileage: 187356 km
Date: 2015.06.11
Time: 08:13:31
RPM: 2080 /min
Temperature: 91.5°C
Part Throttle
Voltage: 13.77 V
Speed: 61.0 km/h
This code doesn't always mean there is a leak.......it means there could be and is most likely a wiring/power supply problem or issue with noid/reed on LDP or faulty controller.
Using VCDS with the 071 test in conjunction with WD .....while observing block and DVOM would be a good idea.
It is highly unlikely you would get an implausible signal from a leak in tank.
Because there's a discrepancy between the text in VCDS and the text in the Wiki.
The text in VCDS is a more literal translation of the original German, "Konzern-Datenbus Komfort im Eindraht" than the English text in the Wiki.
dhoerl
C?ID=131476
Monday,22,June,2015,13:52:20:11064
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WAUKG74F66N034772   License Plate:
Mileage: 187820km-116705mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 42 46 47 4F 52 53 55
          56 61 62 65 6D 72 77
VIN: WAUKG74F66N034772   Mileage: 187820km-116705miles
                    Fault Frequency: 10
                    Reset counter: 40
                    Mileage: 187356 km
                    Date: 2015.06.11
                    Time: 08:13:31
                    RPM: 2080 /min
                    Temperature: 91.5°C
                        Part Throttle
                    Voltage: 13.77 V
                    Speed: 61.0 km/h
   Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4042926
   Shop #: WSC 02325 785 00200
   VCID: 31630457A80262A9D11-8064
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H03 0090
   Coding: 0020895
   VCID: 2D5B1827B43A0649F59-8078
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Component: FBSAUDIC6 ELV   H30 0160
   Revision: 27100401    Serial number: 10600300181659
   Coding: 0000139
   Shop #: WSC 02323 785 00200
   VCID: 63CFBE1FA27E803913D-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H44 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H39 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 731 B    HW: 4E0 035 729
   Component: Interfacebox    H43 1190
   Revision: 00000000    Serial number: 303FC057501703
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 2143F417F8E2D229411-8074
   Component: Bedienteil MMIC6H07 0050
   Subsystem 2 - Serial number: 00000000175950
   Subsystem 3 - Serial number: 0109.06.050000000100010077ÿ
   Subsystem 4 - Serial number: 010077ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000030027802
   Coding: 0524582
   VCID: 5BBF86FF9A0EB8F95BD-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H15 0080
   Coding: 0013123
   VCID: 66C9A70B514CF511F43-8033
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
                    Fault Frequency: 217
                    Reset counter: 150
                    Mileage: 185560 km
                    Date: 2015.05.03
                    Time: 10:57:00
                    Reset counter: 150
                    Mileage: 185560 km
                    Date: 2015.05.03
                    Time: 10:57:00
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBE7183772
   VCID: 1B3FC6FFDA8EF8F99BD-804E
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 66 AIRBAG AUDI8RH29 0300
   Revision: 10H29000    Serial number: 00359D08CLRC
   Coding: 0013878
   Shop #: WSC 40329 444 53665
   VCID: 2A51133B85D4117110B-807F
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME0A266372/
   Subsystem 3 - Serial number: 6342CSME0A300A73
   Subsystem 4 - Serial number: 6352QSME022217595
   Subsystem 5 - Serial number: 6362QSME014835054
   Subsystem 6 - Serial number: 63734SME02133E7B%
   Subsystem 7 - Serial number: 63834SME02391C6D5
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026051530016
   Coding: 0002022
   Component: Lenkradmodul    H07 0080
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H10 0630
   Revision: 00900000    Serial number: 4R8703845
   Coding: 0083263
   Shop #: WSC 61847 001 1048576
   VCID: 1E39CFEBC99CEDD17C3-804B
                    Reset counter: 180
                    Mileage: 187663 km
                    Date: 2015.06.18
                    Time: 11:14:33
   Coding: 0082946
   VCID: 61C3B417B8629229011-8034
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H11 0040
   Revision: 00000000    Serial number: Xpr
   Coding: 0036587
   Shop #: WSC 02327 785 00200
   VCID: 2953EC3780D21A69191-807C
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H18 0130
   Revision: 01300018    Serial number: 01004703410000
   Coding: 7764541
   Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
   Component: DSP-High C6     H09 0140
   Revision: PROD_01     Serial number: 00000000791217
   Coding: 0000116
   VCID: 1C3DC5E3DF80FFC1927-8049
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000002110
   Coding: 0002114
   VCID: 5EB98FEB891CADD13C3-800B
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H11 0040
   Revision: 00000000    Serial number: (�r
   Coding: 0036587
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   VCID: 5DBB88E7841AB6C9259-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Component: AFS 1           H01 0030
   Coding: 0000016
   VCID: 2649E70B91CC3511343-8073
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394F$057557178
                    Fault Frequency: 41
                    Reset counter: 188
                    Mileage: 185613 km
                    Date: 2015.05.03
                    Time: 23:34:30
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H11 0030
   Coding: 0036394
   VCID: 69D3AC374052DA69D91-803C
   Part No SW: 4F0 910 273     HW: 4F0 907 273
   Component: Reifendruck 3   H04 0080
   Revision: 00040080    Serial number: 00000700006980
   Coding: 0062221
   Shop #: WSC 02334 785 00200
   VCID: 60C5B113B3689B210EF-8035
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 B
   Component: ValeoHeckdeckel H14 0280
   Revision: --H14001    Serial number: E5030000B
   Shop #: WSC 23250 431 715754
   VCID: 6CDDD5234FA0CF41A27-8039
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: KK02.06.05--H14001001A0037ÿ
   Subsystem 4 - Serial number: 1A0037ÿ
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H11 0030
   Coding: 0036394
   Part No SW: 4F0 910 336 B    HW: 4E0 862 335
   Component: Handyvorb2      H11 0440
   Revision: 00000000    Serial number: 00000007502536
   Coding: 0010900
   VCID: 2241FB1BFDE4C93158B-8077
End-------------------------(Elapsed Time: 03:08)--------------------------
Thank you for the scan....
Your new mission............:cool:
Please investigate ( D107 ) T17b/13 at current track 163 for water damage or corrosion.
( T17b - 17-pin connector, black, coupling station on electronics box, left in plenum chamber )
dhoerl
C?ID=131476
Thank you so much for the actionable suggestion - I had no idea that the "passing" tests would provide additional info!
In the P2404 error code, I see "Temperature: 91.5°C". Now this cannot possibly be the air temperature. I googled around for P2404, and see a bunch of other such freeze frames, and each one has a temperature of between 20 and 30 degrees C. Could my sensor be defective? Should I change it in any case?
Nope .......not related.
Stop the shot gun repair techniques.......
Traditionally the LDP tests run when engine and intake temp are low, however,.......... in FSI and later CAN cars, it runs more frequent during throttle offset and under slight load.
Continued tests in 071 during idle will historically result with small leak reported in cars after 2005>
It would be a good idea to isolate the zones and do a crimp test to verify the consistency of the noids ability to hold the PSI...........( Advised )
dhoerl
C?ID=131476
I looked in the Bentley manual and found the schematic with T17b and the EVAP pump on it (pages 2/12 and 2/13). I went to component locations, and looked at every section in vain to find a locator. Is this T17b - the circled connector? In any case I opened it up, the contacts are pristine. I see that D107 is the power bus going to the Purge Value as well as the EVAP pump, and that it is fused. I plan to check the fuse (when I figure out where it is), but wouldn't Auto-Scan pick that up?
This car is garaged and in excellent condition.
dhoerl
C?ID=131476
My wife (who drives the car) has reset this code many times using the "Automatic" app (and ODB widget). It normally triggers when she is driving around 30-40 MPH and many minutes after starting the car.
Does that circled aforementioned connector look like it holds 17 terminals or wires? :banghead:
Time to RTFB the section called how to read WD in the manual.
Get a tone generator and test from LDP up > Just follow the noise ......... Run a fast overlay.
See if supply was faulty you would see DTC's for other BUS D107 items most likely.
I would tests zones first for holding PSI generated by LDP before I went nuts with harness.
Run the LDP manually with 071 and crimps in place to establish the hold or is it electrical!
pdachnowicz
C?ID=249207
I'm in the same exact boat. I just had the evap-pump replaced and the CEL light remained off for about 30 miles.
Not sure where to go next my VAG output is. Also readiness code went from 0000 to 0010.
I do see a lot of notes about the J757 relay being the cause. I'm embarrassed to say I am unable to locate. (any hints)
Don't mind taking to my mechanic,(who initially replace the Evap-pump) but relay seems something i could handle.
And for the 13.00 it might be worth the shot. here is my output.
Thank you guys..
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Coding: 0000000000000000
Shop #: WSC 08815 444 53817
VCID: 2B554FDC8AA1AF79EBD-807E
Reset counter: 40
Mileage: 206704 km
Date: 2015.07.01
Time: 09:01:30
RPM: 1568 /min
Mass Air / Rev.: 245.3 mg/str
Temperature: 46.5°C
Part Throttle
Voltage: 13.16 V
Speed: 45.0 km/h
