Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 122
Thread: Audi A6 2006 with EVAP problem (P2404)
    Jun 2015
    Question Audi A6 2006 with EVAP problem (P2404)
    My Audi A6 2006 is having persistent P2404 CEL codes. I can go a few days, then one pops up. I have looked at various engine vacuum lines (and fixed one that was causing a slew of other codes, the tube near the oil dipstick that is a common problem). I replaced the Purge Value, no change, and also replaced the J757 relay that Bentley claims is often the problem. The gas cap looks good and the o-ring is in good condition.
    I have read that the Audi VAG tool can be used to test the EVAP system:
    "Yes, with VAG-com. Go into 01 engine electronics, 04 basic settings, group 070 and 071. One is a tank leak check, the other is purge valve function."
    I didn't see anything on the Ross-Tech site or in the manual about this. Is there an EVAP test I can run using your software?
    Did you see the P-code forum here?
    Please post a complete auto-scan in code tags and maybe have a look at the repair manual.
    www.erwin.audi.com
    Here is a helpful link........
    http://wiki.ross-tech.com/wiki/index...6/P2404/009220
    Ahhhh you could use the output tests for the N80 and LDP in addition to those 070 and 071 block tests.
    0x1-03 GO/NEXT! RTFB
    There is this thingy they call a mighty vac I suggest you do some reading on.
    Smoke in a CAN?
    Jun 2015
    Actually I misstated where I read about J757 - it was from the Ross-Tech WIKI you reference. The tests - well, I have read the Bentley manual. They usually reference some VAG setting or other tool not easily found. That's why I asked - is there a specific set of directions to diagnose this one failure. I guess not, but that's why I asked.
    I have a Mini-Vac tool - it shows that the tube near the dipstick is not holding vacuum, but this with the engine turned off. Should it hold vacuum? well, no way to tell - there is nothing I can find that tells you this. So sure, I can pull the rear wheel off, try to figure out what tube is what, and use a plug to verify the pipe/hose is not leaking. All that said, there are so many complaints about this particular code - I was hoping there might be something besides "read the manual" (which is not for the faint of heart).
    Nope..........Isolate zones manually......
    It starts with the heart of information called an auto-scan....... to establish all attributes.
    "Core control is aware of the problem .......no information is currently available"
    Auto-scan please or security access is a negative response from controller.
    Jun 2015
    I'm quite new to this tool, and having a hard time understanding what your reply means. I see there is an "Auto-Scan" button. Are you telling me if I auto-scan, I may get more codes that will help me determine the problem?
    With the cracked tube - the one going to the EVAP pump - I was getting a slew of errors. Finding and fixing that pipe caused most codes to go away. But I didn't do an auto-scan, so guess I can do that and see what happens.
    Have no idea of what "security access is a negative response from controller" means - possibly that without posting the results of auto-scan no one can help me?
    In any case, I'll isolate all the components by hand and try to find a leak somewhere.
    Thank you for replying.
    David,
    One of the things Jack is trying to tell you is that in a modern car, with all the systems heavily networked together, it's important to look at any issues in a holistic manner, i.e. in the context of the whole car. That's why we ask people to post complete Auto-Scans. There's a tutorial on how to do that here.
  7. #7
    Crimp tests of the N80 line should be done to see if the valve is stuck open, while doing the LDP 071 test and very common.
    A dead give away the N80 is open is the fuel tank will suck down, instead of pressurizing...... like a beer can being crushed.
    It sucks down so hard the straps can appear loose on tank visually.
    Sorry for my poor humor from BSG.
  8. #8
    Jun 2015
    I ran a complete scan, and there were these 3 errors:
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 4F1 910 559 F    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0040
       Revision: --H15---    Serial number:
       Coding: 010D0106190F0120
       Shop #: WSC 98765 666 36124
       VCID: 2E591F2BB93C7D51CC3-807B
    009220 - EVAP Leak Detection Pump Sense Circuit
                   P2404 - 006 - Implausible Signal - MIL ON
                        Fault Status: 10100001
                        Fault Frequency: 10
                        Reset counter: 40
                        Mileage: 187356 km
                        Date: 2015.06.11
                        Time: 08:13:31
                        RPM: 2080 /min
                        Mass Air / Rev.: 294.3 mg/str
                        Temperature: 91.5C
                            Part Throttle
                        Voltage: 13.77 V
                        Speed: 61.0 km/h
    Readiness: 0000 0100
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 120080560282B7
       Coding: 6CFE73CD1B1106
       Shop #: WSC 01115 444 54714
       VCID: 2757EA0F96C62C190F5-8072
                        Fault Status: 00101011
                        Reset counter: 180
                        Mileage: 187663 km
                        Date: 2015.06.18
                        Time: 11:14:33
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000050776
       Shop #: WSC 02445 823 62659
       VCID: 234FFE1FE2FEC03953D-8076
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  1506090014
       Coding: 344630393135313035452056413031353036303930303134
       Shop #: WSC 00000 384 00290
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Fault Frequency: 41
                        Reset counter: 188
                        Mileage: 185613 km
                        Date: 2015.05.03
                        Time: 23:34:30
    What I found really interesting was that the air temperature was close to boiling in the P2404 error: "91.5C"
  9. #9
    Stoke on Trent, England
    Quote Originally Posted by dhoerl View Post
    Reset counter: 180
    Mileage: 187663 km
    Date: 2015.06.18
    Time: 11:14:33
    I don't know why users always post 00470 - Company Comfort Databus in Single Wire when its Combination Comfort Data Bus in Single Wire.
    http://wiki.ross-tech.com/wiki/index.php/00470
    New User Keith
  10. #10
    Jun 2015
    We do it because we are stupid ignorant noobies, and just do what the experts (see above) tell us (i.e., post the results of your Auto-Scan). In my particular field of endeavor, I'm not a noobie nor am I ignorant of the general expertise level, but here I am. Sorry you have to endure my ramblings.
