2013 Q5 Trailer Hitch Retrofit
   #21
NEtech
C?ID=56995
I guess also [09] BCM, Byte 18, needs changed.
Side note, there is a bug in LCode, in stand alone, if for example an engine coding is used and a 39 Byte BCM Coding is pasted, the first Byte is changed, I have fixed it.
PoeTronik13
C?ID=87929
Dana,
Thanks for the codes, they have worked and fixed the issue i had.
thanks again for the codes
   #23
PoeTronik13
C?ID=87929
Dana, you're amazing. It never made sense in my mind after troubleshooting for weeks as to why I couldn't recode with similar codes from this form. Now it makes sense that it's vehicle specific. I greatly appreciate your help.
Hello Mark,
The 01 coding should be: 6A2A0013243600062000
The 03 coding should be: 159D1803 and you'll need to use SA code 61378
Dana
Western PA, USA
Thanks for the kind words but I wouldn't be amazing without the rest of the Ross-Tech team :-) The internal coding info I had came from Sebastian (he's working on getting that coding information into the next dataset). Niels (NEtech) is constantly working on enhancements to the LCH in addition to diagnostic info such as coding information.
On that note Trailer Hitch/Recognition active is supported as Niels mentioned in Byte 18 of BCM1 (AW 09). Please do enable that if you haven't already.
Andres Tamez
Mexico
C?ID=267051
* 69-Trailer - will need to be coded after installed.
How do I recode this one?, Is there a special code or something?
   #26
trackhack
Sydney, Australia
C?ID=416356
I'm having similar issues. I'm trying to install a hitch and module from my Q5 to my SQ5. So both a retro-fit and a de-retro-fit.
Have been following along here and coded the modules accordingly. But still getting errors in 01 and 13.
Secondary issue is trouble removing the hitch module from the Q5. How do I do this? I've removed the coding but how do I tell it I don't want the module to be active anymore before I disconnect it?
I'm still learning the software but do understand the concepts reasonably well from having used OBDeleven for a while.
This is the SQ5
aturday,05,December,2020,23:52:07:54103
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WAUZZZ8R7EA054561   License Plate:
Mileage: 87020km-54071mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
          53 56 5C 5F 62 69 6C 6D 72 A9 C0
VIN: WAUZZZ8R7EA054561   Mileage: 87020km-54071miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0003
   Revision: 57H25---
   Coding: 2A2A4032257603020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589 001006
   ROD: EV_ECM30BTD011_AU48.rod
   VCID: 7EA5FA71B07A408B20F-802B
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 87027 km
                    Date: 2020.12.05
                    Time: 23:40:08
                    Coolant temperature: 38 ∞C
                    Intake air temperature: 29 ∞C
                    Voltage terminal 30: 11.660 V
                    ACC target acceleration: 0.007 m/s≤
                    ACC control module received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
                    Acceleration: 0.000 m/s≤
                    Engine status: COENG_READY
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1005
   Revision: --H16---
   Coding: 000001
   VCID: 00598489CA8E367B523-8055
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AF    HW: 8R0 907 379 AF
   Component: ESP8 quattro  H09 0030
   Coding: 24ED0C01
   Shop #: WSC 06335 000 00000
   VCID: 04518899DE162A5B76B-8051
   Part No SW: 8K0 907 064 HR    HW: 8K0 907 064 GR
   Component: BCM2 2.0      H13 0641
   Coding: 05B54000000000000000
   VCID: 074B9F95EF200143139-8053
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01181020131270
   Coding: 3625628080
   VCID: 3A2D3661EC52ACAB5C7-806F
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000051250401
   Coding: 260000318074AFF2118140C300001D0D0F9DE70827090201000008004401010200020034000000
   Shop #: WSC 12345 123 61029
   VCID: 7AADF661ACD26CAB1C7-802F
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 131007  H11 0050
   Serial number: 90243015130829085044
   Coding: 01DD13
   Serial number: 21851352
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001410130258
   Subsystem 4 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Serial number: A71802D6000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 008189
   VCID: 372B2F55DF40B1C3A39-8063
                    Fault Status: 00101101
                    Reset counter: 70
                    Mileage: 87027 km
                    Date: 2020.12.05
                    Time: 23:30:16
                    Temperature: 36.0∞C
                    Voltage: 11.78 V
                    Hex Value: 0x00BD
                    Lateral Accel.: 0.00 m/s^2
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003JPDB0VM61
   Coding: 304A3431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C95CA9A23ECE3BDA3-801D
   Serial number: 6334MSME7F141273D
   Serial number: 6344MSME7F54612AO
   Serial number: 6352QSME0B383A68Q
   Serial number: 6362QSME47380740B
   Serial number: 63732SME48423560V
   Serial number: 63832SME3A420F685
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372RAJ000FI
   Coding: 0000FF
   VCID: 44D148999E96EA5B36B-8011
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 G    HW: 8R0 920 931 G
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: ZDM39KNAE
   Coding: B3EF22006F010008010000
   VCID: 392F296DE954A7B355D-806D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z139290316
   Coding: 80CD07FF00
   VCID: 4CC160B9B6C6221BFEB-8019
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 30283621231461241028
   Serial number: 13289003273011200410
   Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
   Component: DYNAMIKLENK.  H06 0720
   Coding: 040100
   VCID: 38292C69D25EBEBBAA3-806D
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CA1F079A6E6529B0EB-8029
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000078516505
   Coding: 01781B00000000000000
   VCID: 42DD4E818482E46B047-8017
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0317972623
   Coding: 010322
   Shop #: WSC 06334 000 00000
   VCID: 3FDB4775F7F089836B9-806B
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0317656987
   Coding: 010322
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000077773363
   Coding: 011D12205E01440004
   VCID: 4FFB77B547D019039B9-801B
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000002    Serial number: 0000061061
   Coding: 010001010001
   Shop #: WSC 29511 004 1048576
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46D55291A82AD84B28F-8013
   Revision: 00002001    Serial number: 0314765179
   Coding: 01000E2A20B930958420053680040047
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813021423703
   VCID: 2D070D3D2D1C0B13C95-8079
   Revision:             Serial number: 0000078886375
   VCID: 4EC56AB140DA100B90F-801B
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001384306
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F296DE9D4A7B355D-806D
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109J-0D7712271
   Coding: 040103010000000001
   VCID: 2615F21108EA384B08F-8073
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213A22000E3
   Coding: 0032004
   VCID: 372B2F55D340B1C3A39-8063
   Part No SW: 8R2 035 754 F    HW: 8R2 035 754 C
   Component: H-BN-RW       H46 0739
   Revision: --------    Serial number: 210JO0D7521034
   Coding: 1A0A01060205E9EF7D80CB4E00000403FC0000020000000000
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Component: DU7 High  H42 0104
   Serial number: A130J 0D2850866
   Serial number: 00000001647862
   Component: CD-Database  5298
                    Reset counter: 30
                    Mileage: 87027 km
                    Date: 2020.12.05
                    Time: 23:31:22
                    Bin. Bits: 00000001 00000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000079068460
   Coding: 010C12204001240004
   VCID: 46D55291A8AAD84B28F-8013
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
   Component: Anhaenger     H08 0080
   Revision: 1A002002    Serial number: 00000116068013
   Coding: 0300000000000000
   Shop #: WSC 21540 822 92067
   VCID: 33331B45CB385DE39F1-8067
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J37A8I4
   Coding: 1031010
   VCID: 34311859C2365ADB86B-8061
Address 6D: Trunk Elect. (J605)       Labels: 4L0-910-945.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B233365E36895A3471-806F
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Serial number: 8R0827852B
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000079068501
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 131005200520
   VCID: 79AFE96DA95467B315D-802D
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 130919200620
   VCID: 71BFD14DF1242FF3ADD-8025
End----(Elapsed Time: 02:03, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
   #28
trackhack
Sydney, Australia
C?ID=416356
Update: Modules 13 is no longer showing an error but module 01 still is. I don't know if the error in 5F was there before I did the retrofit or not. I do have an aftermarket CarPlay device plugged into the canbus I assumed the error is due to that. Car drives fine without errors on dash. ACC and lane assist both functioning.
Any advice on how to clear error in Engine module?
C0-Act. for Ext. Noise -- Status: Malfunction 0010
   Revision: 57H25---
          U1113 00 [039] - -
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:25:05
                    Coolant temperature: 50 ∞C
                    Intake air temperature: 31 ∞C
                    Voltage terminal 30: 12.100 V
   Revision: --H16---
   Coding: 000001
   Coding: 24ED0C01
   Coding: 3625628080
   Coding: 01DD13
   Coding: 02005C
H05 0012
H05 0012
   Coding: 008189
   Coding: 0000FF
   Coding: 80CD07FF00
   Coding: 040100
   Revision: AA001002
   Coding: 010322
   Coding: 010322
   Coding: 0032004
                    Reset counter: 30
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:22:50
   Coding: 1031010
0006 - Actuator 1 for Engine Noise Simulation
          C113C 13 [008] - Open Circuit
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:09:44
End----------(Elapsed Time: 02:05, VBatt start/end: 12.1V/12.1V)-----------
Sunday,06,December,2020,17:40:43:54103
   Revision: 57H25---
          U1113 00 [039] - -
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:33:30
                    Engine speed: 739.00 /min
                    Normed load value: 25.5 %
                    Intake air temperature: 30 ∞C
                    Voltage terminal 30: 13.760 V
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
   Revision: --H16---
   Coding: 000001
   Coding: 24ED0C01
   Coding: 3625628080
   Coding: 01DD13
   Coding: 02005C
H05 0012
H05 0012
   Coding: 008189
   Coding: 0000FF
   Coding: 80CD07FF00
   Coding: 040100
   Revision: AA001002
   Coding: 010322
   Coding: 010322
   Coding: 0032004
                    Reset counter: 30
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:38:01
   Coding: 1031010
                    Mileage: 87027 km
                    Date: 2020.12.06
                    Time: 17:09:44
End----------(Elapsed Time: 02:03, VBatt start/end: 14.2V/14.3V)-----------
