- Joined
- Apr 14, 2014
- Messages
- 6
- Reaction score
- 0
- VCDS Serial number
- C?ID=90623
My vehicle is a 2013 Q5 3.0TDI, Australian spec.
In trying to code for a trailer hitch (not yet successful), I am seeing some strange responses when I look at or modify certain controllers.
I have never previously seen the "This appears to be an uninitialized control module" message and am not sure why it would be the case?
Any advice?
..Neil
auto-scan below:
Any advice?
..Neil
auto-scan below:
Tuesday,08,April,2014,18:28:23:48594
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ8R2DA09xxxx License Plate: xxxxxx
Mileage: 11320km-7033mi Repair Order: Trailer install
Chassis Type: 8R (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 36 42 44 46 52 53 56 5C 5F
62 6C 6D 72
VIN: WAUZZZ8R2DA09xxxx Mileage: 11320km/7033miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CDUD) Labels: 059-907-311-CLA.clb
Part No SW: 8K5 907 401 G HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0001
Revision: 53H41---
Coding: 2A254012056703020000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TDI0118K5907401G 001001
ROD: EV_ECM30TDI0118K5907401G.rod
VCID: 346CE7FE9F86BDBE4FF-8061
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R1 927 156 S HW: 0B5 927 156 J
Component: 0B5 30 TDIRdW H02 0006
Revision: --H02---
Coding: 000001
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501021 001012
ROD: EV_TCMDL501021.rod
VCID: 4C9C9F1EE776C57E37F-8019
Part No SW: 8R0 907 379 AB HW: 8R0 907 379 AB
Component: ESP8 quattro H09 0050
Coding: 225D0C01
VCID: 8004FB2E13BE511E1B7-80D5
Part No SW: 8K0 907 064 GR HW: 8K0 907 064 FR
Component: BCM2 2.0 H12 0633
Coding: 05B54040000000000000
VCID: 8608ED36319A7F2E21B-80D3
Part No SW: 8K2 820 043 S HW: 8K2 820 043 S
Revision: D0000000 Serial number: 01260420130040
Coding: 3625628080
VCID: 3972D6CAB0E440D69C9-806C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00000599460002
Coding: 260000108034AFE20181408000001D0D0F9DC70827090201000008004401030100000034000000
VCID: 77F610F2C67096A6AAD-8022
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130408 H11 0050
Coding: 01DD13
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0100
Coding: 008190
VCID: 3776D0F286F056A66AD-8062
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Serial number: 003JPD93AJL-
Coding: 304A3431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4894A30EF30E295E137-801D
Serial number: 6334MSME7B21207FI
Serial number: 6344MSME7B16186DR
Serial number: 6352QSME7A2F1E6C1
Serial number: 6362QSME1230525EA
Serial number: 63732SME15300364L
Crash sensor for front airbag; passenger side:
Serial number: 63832SME16304260M
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MDO0016G
Coding: 0000FF
VCID: 448CB73EC7260D3EFFF-8011
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 R HW: 8R0 920 930 R
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UWN239Y4E
Coding: B3E6220047010008010000
VCID: 438EB422C2280A06C65-8016
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z134158043
Coding: 80CF07FF00
VCID: 4C9C9F1EEF76C57E37F-8019
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000056724295
Coding: 01781B00000000000000
VCID: 4280B126DD32030ECD3-8017
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0508
Revision: Serial number: 0000059746261
Coding: 011D12205E01440004
VCID: 4FA688121E60FE6652D-801A
Address 44: Steering Assist (J500) Labels: None
Part No SW: 8R0 909 144 E HW: 8R0 909 144 B
Component: RCEPS H37 0506
Revision: 00001000 Serial number: 0023424016
Coding: 100001010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 006012
ROD: EV_RCEPSAU48X.rod
VCID: 3A70C9C6BDE24BCE953-806F
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0305764437
Coding: 01000E2220B93081842005368004000F
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0508
Revision: Serial number: 0000059251227
VCID: 4E989516196AF76E59B-801B
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000207486
ROD: EV_ParkiBrake_AU48.rod
VCID: 3874D3CE83EE59DE637-806D
Part No SW: 4G0 035 056 G HW: 4G0 035 056
Component: Radio U STD H60 0121
Revision: AB001007 Serial number: 230D.0D2759592
Coding: 040003020100000001
VCID: 254A0ABA2C5CD436C81-8070
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 6002134220007F
Coding: 0022004
VCID: 3776D0F246F056A66AD-8062
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 754 B HW: 8R2 035 754 C
Component: H-BN-RW H45 0639
Revision: -------- Serial number: 210DQ0D7512537
Coding: 160A01060005A9EF6D80CB4E00000403FC0000020000000000
VCID: 3668DDF681FAAFAE71B-8063
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000059342686
Coding: 010C12204001240004
VCID: 4688AD36F11A3F2EE1B-8013
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07--- Serial number: 525PA8-J33A0IU
Coding: 1020010
VCID: 346CE7FE5786BDBE4FF-8061
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B7ECCC2BAD872C68E5-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000059338350
End ---------------------------------------------------------------------
