Results 1 to 3 of 3
Thread: A5 Sportback ABS coding
    Jun 2015
    Poland
    Hello. It's my first post here but i have hope not last. And hello to everyone. I'll be grateful if someone can helps me to calculate ABS coding Vagscan , i have label from trunk jpg but haven'i idea how to attach.
    In best Regards
    Type 8TA 06Y
    A5 quattro sportback 166Kw A7S
    Enginr Trans CDNC JKR LZK
    VCDS Version: Beta 15.6.1
    Data version: 20150612
    Monday,15,June,2015,19:48:35:42516
    Chassis Type: 8T (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 42 46 47 52 53 55 56
              62 69 72 77
    VIN: WAUZZZ8T5AA025355   Mileage: 23440km-14564miles
    Address 01: Engine (CL0MA-CDNC)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H15 0008
       Revision: E1H15---
       Coding: 0114000C240F0960
       Shop #: WSC 46396 133 63149
       ASAM Dataset: EV_ECM20TFS8K2907115P A01010
       ROD: EV_ECM20TFS0118K2907115AJ.rod
       VCID: 3C7CDA7CB7CDB3DFE5-8068
              U1113 00 [039] - -
              U1113 00 [039] - -
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K0 927 156 F    HW: 0B5 927 156 E
       Component: 0B5 20TFSIRdW H03 0013
       Revision: --H03---    Serial number: 0000001343
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501 A02088
       ROD: EV_TCMDL501.rod
       VCID: 3776C5508EEB908708-8062
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 090D08
       Shop #: WSC 06335 123 12345
       VCID: 7AF01C64F5794DEFB7-802E
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Coding: 010400
       VCID: 01026B8898AF1E37F6-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01061020091220
       Coding: 64000000
       Shop #: WSC 06342 000 00000
       VCID: 00046E8C93A5173FF9-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000357446
       Coding: 260050914074AF010009000300005D5D0F1C630800010141000000
       VCID: 3C7CDA7CBFCDB3DFE5-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 250909  H14 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0050
       Revision: 11001001    Serial number: 39840927914276
       Coding: 110107
       VCID: 4084AE8CD325D73FB9-8014
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EFD064SHE
       Coding: 30353438363030303030554A304C38543053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 4182AB88D02FDE37B6-8014
       Serial number: 6334MSME4B6042729
       Serial number: 6344MSME4C331670A
       Serial number: 6352QSME203D0F04E
       Serial number: 6362QSME343C0228C
       Serial number: 63732SME073E4E3AB
       Serial number: 63832SME5A3D33262
       Revision: --------    Serial number: 90315IJ1000LG
       Coding: 000036
       VCID: 3D7AD778A4D7BAD7D2-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 900 P    HW: 8T0 920 900 P
       Component: KOMBIINSTR.   H33 0255
       Revision: 00000000    Serial number: CHS12GE99
       Coding: 0F07310003000008000000
       Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
       Component: GW-BEM 6CAN   H06 0105
       Revision: HB600050    Serial number: 5000H09906844B
       Coding: 00C303
       VCID: 51A29BC8084F2EB726-8004
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0170
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02019864747464545425363E
       VCID: 336EF14092937CA734-8066
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020202
       VCID: 3972C368B0FF86F7FE-806C
       Part No SW: 8T0 959 793 D    HW: 8T0 959 793 A
       Component: TSG FA        H07 1101
       Coding: 011C02624000450005
       VCID: 4A908CA4E5191D6F67-801E
       Revision: 00002001    Serial number: 0121986841
       Coding: 01000620203904000130040000000000
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F66FD307EBB584750-807A
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1201
       Coding: 011C02224000450005
       VCID: 4FA69DB01E7B384730-801A
       Revision: 00000003    Serial number: 10000000329765
       VCID: 346CF25C979D7B9F2D-8060
       Part No: 8K5 907 357
       Shop #: WSC 06324 000 00000
       VCID: 77F60550066B5087C8-8022
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H04 0310
       Revision: 00000007    Serial number: AUZ5Z6I1279914
       Coding: 0402008201048500435B070800
       VCID: 448CA29CC73DCB1F9D-8010
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
       Part No SW: 8T0 959 795 J    HW: 8T0 959 795 B
       Component: TSG HL        H05 1201
       Coding: 010C02224000450005
       VCID: 52A094C40D4955AF1F-8006
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 B    HW: 8K0 907 383 B
       Component: Anhaenger     H08 0080
       Revision: 1A002002    Serial number: 00000122499354
       Coding: 0100000000000000
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H05 1201
       Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
       Component: FSE_256x BT     H37 0600
       Revision: 00000000    Serial number: 00000005111070
       Coding: 0010310
       VCID: 3B7ED9607AC3B4E7EC-806E
    End-------------------------(Elapsed Time: 03:35)--------------------------
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    in ABS-ECU is "trailer mounted" missed. Please aktivate in Long Coding Helper for ABS Byte-1 Bit-7.
    -Wolfgang
    Drive more talk less
  3. Likes Uwe, roth liked this post
    Jun 2015
    Poland
    Hello. I was blind ... Thank's I wasn't supposed to someone install trailer hitch to A5 ... and i wasn't check my own scan. Thank You
    Regards
  5. Likes Uwe liked this post
