I'm told there are differences between the 2015 FL model and the original so I hope this helps......
Sunday,14,June,2015,14:26:47:53338
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WAUZZZ8U6FR030114   License Plate: SNAPSH0T
Mileage: 3240km-2013mi   Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 25 2B 42 44 46 52 55
          5F 62 72
VIN: WAUZZZ8U6FR030114   Mileage: 3240km-2013miles
Address 01: Engine (J623-CUVC)       Labels: None
   Part No SW: 04L 906 016 BE    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 0790
   Revision: 8AH20---
   Coding: 02250012043701083000
   Shop #: WSC 00049 770 00118
   ASAM Dataset: EV_ECM20TDI01104L906016BE 002002
   ROD: EV_ECM20TDI01104L906016BE.rod
   VCID: 6DD1891FBC41A449B59-8038
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 012 K    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 4703
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_AU21.rod
   VCID: 2B55470742D56A79EBD-807E
   Part No SW: 5N0 614 109 CA    HW: 5N0 614 109 CA
   Component: ESC-EBC460iV1 H08 0004
   Serial number: A00RGRZ
   Coding: 21F124A1C923C36C2078840124C793C304345700508B4884
   Shop #: WSC 00049 770 00151
   ASAM Dataset: EV_Brake1ESCEPBTRW 003039
   ROD: EV_Brake1ESCEPBTRW.rod
   VCID: 6CD7841B875BAD41A27-8039
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Revision: 00092000    Serial number: 0361125730
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: 377D6B778E9DDE999F5-8062
   Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043F
   VCID: 34675C7B57EB3581BA7-8061
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
   Component: BCM PQ35  M   113 0817
   Revision: AB113817
   Coding: 4E000A2CA805F1C0201849C80144094C43FF25AA006F91BBE4008784E0C1
   Shop #: WSC 00049 770 00099
   VCID: 7CF7B45BFF3B3DC1327-8029
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119
   Component: WWS316 150205  H37 0090
   Coding: 0047F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475 AH    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0080
   Revision: 11001001    Serial number: 61031505103995
   Coding: 08C308
   ASAM Dataset: EV_EPHVA18AU21X0000 003008
   ROD: EV_EPHVA18AU21X0000.rod
   VCID: 0C17E49BA79B0D41027-8059
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655 C    HW: 8U0 959 655 C
   Component: AirbagVW-AU10 H09 0900
   Serial number: 003PAR0AP1ET
   Coding: 30523232333030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316.rod
   VCID: 479D1BB7FE7DAE19EF5-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME1D656035ZZZZ
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME5B236135ZZZO
   Serial number: 3516KSME186B6035ZZZT
   Serial number: 3526KSME343C6135ZZZR
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME4A487B32ZZZ8
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 521 K    HW: 5K0 953 569 AH
   Component: LENKS.MODUL   016 0162
   Revision: FF010018    Serial number: 20150223100306
   Coding: 1014204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 44870CBBCF4B85010A7-8011
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 23 02 2015  E0073045
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 H    HW: 8U0 920 990 H
   Component: KOMBI_COLOUR  H02 0350
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 428B0AA3D55F8B3138B-8017
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 AC    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0074
   Revision: 1P140041    Serial number: 4141P1522800C2
   Coding: FBCF1A5A000100610353
   VCID: 0305CFA782C5423973D-8056
   Component: J367-BDM  H07 0180
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 02020A64747464545425363E00
   VCID: 3A7B7243B58FC3F160B-806F
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00011.02.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 52AB3AE3053F1BB188B-8007
   Component: IMMO          H02 0350
   Coding: 000007
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 15000054651004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 306F506B6BF309A1DEF-8065
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011816201C01000000
   VCID: 52AB3AE30D3F1BB188B-8007
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 297    3501
   Revision: 00H22000
   VCID: 408F00AB135399212EF-8015
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011816201E01000000
   VCID: 51A935EF083960A9B11-8004
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 150221-0002-034
   Coding: 11C7A4101000A500
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 8U1 035 192 A    HW: 8U1 035 192 A
   Component: RMC Nav Plus  H61 0139
   Coding: 01010600024153470823020103010000000000
   VCID: 33655F6792E532B9A3D-8066
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H42 0018
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010016200001000000
   VCID: 4FAD33971E0D7659A75-801A
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 03:30)--------------------------
