- Joined
- Apr 14, 2014
- Messages
- 2
- Reaction score
- 1
- Location
- Tasmania, Australia
- VCDS Serial number
- C?ID=150916
I have a 2008 Skoda Octavia. In the past I’ve installed the following:
A 2012 VW RNS510 (all worked fine) with an updated canbus gateway (for the battery issue).
Bluetooth unit.
Factory parking sensors front & rear.
Tow bar wiring.
MDI unit ( I have a little coding issue with that too. I think I need to code to disable the Accessory audio socket in the armrest pocket).
Q1. The issue I have now is I have arranged to swap my VW RNS510 with another person that has the reverse - a Skoda Columbus unit in a VW. This is so we get the correct colour buttons, startup screen and graphics for our cars.
The problem I’m having is the steering wheel buttons aren’t working with the Skoda radio in my car - a Skoda! (they did work when I had the VW unit in).
You may note in the log - Radio/Navigation errors for speakers. I’m also putting in an aftermarket amp and speakers, which aren’t connected yet - so there are no speakers connected to the RNS510. I can still ‘pretend’ to play the radio and turning the volume knob on the unit shows the volume being adjusted, but not the steering wheel buttons.
This is the type of steering wheel I have (it has cruise control on the left stalk):
(can't work out the format of the link for photo's)
https://www.flickr.com/photos/8753947@N06/13857679734/in/set-72157629221672317
Any ideas? Log below:
Bluetooth unit.
Tow bar wiring.
Sunday,13,April,2014,23:19:15:46507
VCDS Version: 14.2.3.0
Data version: 20140320
VIN: TMBKE61Z482108213 License Plate:
Mileage: 94590km-58775mi Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 52 56 62 69
72 77
VIN: TMBKE61Z482108213 Mileage: 94590km-58775miles
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 SS HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 1302
Revision: --H07--- Serial number: SKZ7Z0G4674602
Coding: 0050172
Shop #: WSC 66565 257 00032
VCID: 820122E4DDBA3A2403-80D7
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0023170
Shop #: WSC 73430 790 00000
VCID: 72E1F2246D1A8AA493-8027
Part No SW: 1Z0 907 044 AB HW: 1Z0 907 044 AB
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
VCID: 76E9CE3401729684BF-8023
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000005403549
Coding: E1880F011004140040110D000000000000087F075C00000C000000000000
Shop #: WSC 73430 790 12345
VCID: 71E3FD28681CB1BC6A-8024
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 111207 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 271207 046 0204
Coding: 00471077
Shop #: WSC 73430
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H06 0005
Revision: --H06--- Serial number: 28261216303427
Coding: 110001
ASAM Dataset: EV_EPHVA18SKxxx0000 001001
ROD: EV_EPHVA18SKxxx0000.rod
VCID: 438F67E0CA20732CC8-8016
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q3 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D13SLJI
Coding: 0020787
VCID: 6BDFEF404A305B6C50-803E
Subsystem 1 - Serial number: 6332MSME2D42254BE
Subsystem 2 - Serial number: 6342MSME37136549A
Subsystem 3 - Serial number: 6351HSME1204096B0
Subsystem 4 - Serial number: 6361HSME1204237E1
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0002042
VCID: 78F5C00C0B66E0F4AD-802D
Component: E0221 002 0010
Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0G4674602
Coding: 0002101
Shop #: WSC 23050 822 88145
VCID: 3875000C4BE620F46D-806D
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 250511F1000940
Coding: 352303
VCID: 3065382C6396F8B425-8065
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
VCID: 36690E3441F2D6847F-8063
Component: IMMO VD1 1612
Shop #: WSC 73129 959 96102
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662009629
VCID: 2953D548404C897CE2-807C
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 194
Mileage: 94594 km
Time: 23:16:28
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 B HW: 3T0 035 680 B
Component: RNS-MID H60 4120
Revision: AB001001 Serial number: SKZ6Z7L5341119
Coding: 00000400040000A00000
Shop #: WSC 73430 790 00098
VCID: 2F673B507EA8E74C3C-807A
Subsystem 1 - Part No: 3T0 051 859 P
Component: AUNZ V6 7920
8 Faults Found:
Reset counter: 194
Mileage: 94592 km
Time: 23:14:03
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1204
Coding: 0000758
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 73430 000 90108
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 88801A085283007F3F02850500085F01807C00
VCID: 830F27E0C2A0332C08-80D6
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000758
VCID: 3973050870EC39FC92-806C
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
8 Faults Found:
Reset counter: 194
Mileage: 94592 km
Time: 23:14:03
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Reset counter: 194
Mileage: 94592 km
Time: 23:14:04
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3777033046F82F8C64-8062
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H13 2730
Revision: 1B001001 Serial number: 00007661882609
Coding: 0200000000010110
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA.rod
VCID: 356B093894F4DD9C76-8060
End ---------------------------------------------------------------------
