Hi, I did a few logs (recording them), and I was wondering where they go for review later? On my computer/tablet that is. I thought I would get a "save as" or something like that.
If you allowed VCDS to install where it normally likes to do so on the C drive of your computer, then you should find the Ross-Tech folder in the root directory, find a VCDS folder, and within the VCDS folder, a folder called logs.
Damn you guys rock. You are so responsive to the customer. I love it.
I found it. For example, I did a boost pressure one. There is a lot of data on the excel sheet.
1. How do you access the vag-meter function?
2. I figured out how to start the saved file as a vag-scope. But how do I determine what the four color graph lines mean? I know I can change the colors which is helpful, but what does each line mean?
3. How do I determine the max boost pressure based off my numbers (for instance Engine speed 2310/Boost Pressure specified 1795.2/Boost pressure actual 1866.2/Charge control duty cycle 49.3)
