Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: How to create VCDS-Cloud account (IOS)
  1. #41
    Quote Originally Posted by Gary View Post
    Yes I tried that, I tried several times, also cleared rods and even the option for cache. Autoscan again update found for asam data, seems to complete but the LED still flashing red and green and the screen is locked with only back button showing.
    OK, I'm gonna wait for Shaun's input here.
  2. #42
    HexNet interface has a red LED flashing to the right of the USB connector and seems to be locked.
    After the update, it sometimes has a lot of old or temporary files that it needs to delete, which sounds like what it is doing. Most of the time, this process is quick, but if you have done a bunch of dataset/rod updates and manually rebooted it after so it can't complete the cleanup process, it may have compounded all of these files. I would try doing the update, and when it gets to this state, leave it plugged in and just let it run for at least ten minutes. It should eventually finish and come back to a normal state.
  3. Likes Uwe liked this post
  4. #43
    Dec 2019
    I seem to be having a similar issue. I have set up my cloud account, but when trying to do cloud functions I get the server error. I wait the 10 seconds and try again. Then it directs me to the VCDS Cloud Index Page and prompts me to login. I enter my username and password and then all I can see is “View saved files” and “Account management”
    I’m working with a VW Tiguan SEL-P module 5F I have the HEX-Net tethered to my Android phone and I’m using the app on that same phone.
  5. #44
    What module are you having this issue with, can you post an autoscan? Have you tried some of the other modules in the car, to see if they work?
  6. #45
    Dec 2019
    Shaun, here are the Autoscan I did. One is over the USB, and the other is over WiFi. I was attempting to use module 09 (Central Elect.). I did not try a different module. I ended up grabbing an old laptop. I can attempt again with my phone on a different module.
    EDIT: Tried again tonight, and cloud functions were working as expected on multiple modules. Must has been a glitch in the matrix.
    USB:
    Thursday,12,December,2019,15:59:41:31648
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: 3VV4B7AX2KM######   License Plate:
    Mileage: 2788km-1732mi   Repair Order:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
              4B 52 5F 6C 6D 75 A5 CA D6 D7
    VIN: 3VV4B7AX2KM######   Mileage: 2788km-1732miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 83A 907 115     HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H31 0004
       Revision: 1DH31000
       Coding: 012A00122466012FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00451
       ASAM Dataset: EV_ECM20TFS01183A907115 001006
       ROD: EV_ECM20TFS01183A907115.rod
       VCID: 63868DD16A2E1857DA-8036
       Part No SW: 09G 927 158 DT    HW: 09G 927 158
       Component: AISIN AQ8     206 3549
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00446
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 085CBA7DB3489B0FEF-805C
       Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
       Component: ESC           H35 0108
       Revision: 00000000    Serial number: 51479000001482
       Coding: 0BFA6BA450281B6CC5770303A2C749D0D60AD8A3C045927438415058D2AA4A0B00402864121A1C230935351919323200
       VCID: 0640B445B95C8D7F9D-8052
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0514420935
       Coding: 132C2C0723
       Shop #: WSC 01383 790 50316
       VCID: 43C66D51CAEE7857FA-8016
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11741140
       Part No SW: 5NN 907 044 N    HW: 5NN 907 044 N
       Component: AC Automat    H35 4601
       Revision: 20K03000    Serial number: 00000D00387459
       Coding: 00020024200118001105010C1211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 57FEA9012E76C4F7B6-8002
       Air quality sensor:
       Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 94600257
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Revision: --------    Serial number: C86421061902J1
       Shop #: WSC 00066 790 00267
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BB6D5B1F29EC097F2-802E
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 190405  034 0373
       Serial number: 19040421004440
       Component: RLHS  052 0107
       Serial number: S6Y19M05D23H17M05S29
       Coding: 00A8DD
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
       Component: Lenks.Modul  H23 0170
       Serial number: 0300260620190C200173
       Part No SW: 5QA 919 294 C    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0050
       Serial number: 000137088R19175
       Coding: 0471255811
       ASAM Dataset: EV_EPHVA18AU3700000 009039
       VCID: 4CD4466DE7B0B72F0B-8018
       Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0342
       Coding: 320000C258FF8728749C810530409700000000000000000000
       ASAM Dataset: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
       VCID: 42C86855D5F4715FF1-8016
       Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
       Component: AirbagVW21    005 0403
       Serial number: 003FGM03PKW7
       Coding: 8CCCFC00000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 0C54866DA730F72FCB-8058
       Occupant Detection:
       Serial number: IBH00000000000BPA80E
       Coding: 303352
       Subsystem 2 - Part No SW: -----------    HW: 480 001 005 19
       Serial number: 3570000000085BF82C3-
       Subsystem 3 - Part No SW: -----------    HW: 480 001 705 19
       Serial number: 358000000009A465FB3-
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001BAF029AA7F85Q
       Subsystem 5 - Part No SW: -----------    HW: 480 401 705 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C8EFE7865C34X
       Subsystem 6 - Part No SW: -----------    HW: 480 403 105 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001BCF051DB3FA1P
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 403 105 19
       Component: FrontSensor_P  005 6149
       Serial number: 3560001BCF051DB3841D
       Part No SW: 5NA 920 890 D    HW: 5NA 920 890 D
       Component: KOMBI         509 1701
       Coding: 08A4041AEF88CF050288634B50010000A0000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 44C46E4DCFE07F6FC3-8010
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 21061900840047
       Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E90ECE5B1ECA53F45-803A
       Component: 0-00-0d-00-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 0981902550700324FG2B
       Coding: 2E0000
       Serial number: 8840436600
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00002.04.19
       Coding: 0101
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C27349C4DA4667D4-8010
       Serial number: 19000110819008
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 33263D919A4EC8D76A-8066
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
       Component: Sitzmemory    H09 0024
       Serial number: Y0006SDE37620
       Coding: 0010000000000500018280808080000000008101000000F400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       VCID: 3D321BA9AC0A0EA78C-8068
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Component: HRE_Master    H12 0081
       Serial number: 0515380406
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0081
       Serial number: 0519089033
       Coding: 020111
       Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
       Component: TSG FS        006 0247
       Serial number: 42038913301668
       Coding: 003F1B205200048000000000
       VCID: 4FEE516116A68C376E-801A
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Serial number: 00000000000003397190
       Coding: 011000
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  173 1081
       Coding: 911F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50EC521D0B9893CF77-8004
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1KMD04XU6C
       VCID: 2E102CE5716CE53F05-807A
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 16061900840037
       Coding: 0000000509001D5200210F01090000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 35220389943AD6E744-8060
       Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0247
       Serial number: 46038915800683
       Coding: 003F13205E00048000000000
       VCID: 4ED04C6511AC853F65-801A
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Serial number: 00000000000003431911
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 027306020000000051220002001808001F0500E401200405C6
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  254 8130
       Serial number: VWZ6ZMW1755086
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG052686
       Coding: 01230601A20F20003000400C
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
       VCID: 393A0FB9B8223287A0-806C
       Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0266
       Revision: --------    Serial number: A2-C758-8700-2
       Coding: 0A28
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: 46C07445F9DC4D7FDD-8012
       Component: OCULowMQBUS   009 0570
       Coding: 02230602C2823A037F1E06020000
       Shop #: WSC 14217 002 1048576
       ROD: EV_OCULowMQB.rod
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H09 0610
       Serial number: 16121815P20374
       Coding: 0003070601020201002213548150490084000E20012000
       ROD: EV_MFKBoschMQBB_002_VW37.rod
       VCID: 40CC625DDBF8634FE7-8014
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Coding: 00804073260C
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 75A2C389D4BA96E784-8020
       Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
       Component: LED1L         H07 0008
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 004CA25D9B78A34FA7-8054
       Component: LED1R         H07 0008
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxRKEBODVW481.rod
    End----------(Elapsed Time: 02:12, VBatt start/end: 14.8V/14.8V)-----------
    Mobile:
    VCDS Mobile 0.4513.0.4
    Address 01: Engine  (DGUA J623)	Labels: None
    	Revision: 1DH31000
    	VCID: E389BC8F2D4BB0C4EBF065-80B6
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels: 09-02.lbl
    	VCID: 88538B23F42D339CDE427A-80DD
    Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
    	Revision: 00000000
    	ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
    	VCID: 864F851BFE3925ECAC2E64-80D3
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Revision: 00037000
    	Coding: 132C2C0723
    	VCID: 43C9DC0F0D8B50C44BB045-8016
    Address 08: Auto HVAC  (E87)	Labels: 5N-08.lbl
    	Revision: 20K03000
    	ROD: EV_ACClimaPrehVW37X_002_VW37.rod
    	VCID: 57F1185FE913EC64077861-8002
    	Subsystem 1 - 	Part No SW: 5Q0-907-659-C
    	Serial Number: 94600257
    	Subsystem 2 -
    Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
    	Revision: --------
    	ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
    	VCID: 7BB964EF35FBE80443C0ED-802E
    	Subsystem 1 - 	Part No SW: 5NN-955-119	Labels: 1Kx-955-119.clb
    	Component: 326 LL 190405034 0373
    	Serial Number: 19040421004440
    	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
    	Serial Number: S6Y19M05D23H17M05S29
    	Coding: 00A8DD
    	Subsystem 3 -
    	Subsystem 4 - 	Part No SW: 5Q1-953-521-R
    	Serial Number: 0300260620190C200173
    Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
    	Coding: 0471255811
    	VCID: 4CDBF73320D59FBCBAEAE6-8019
    Address 13: Auto Dist. Reg  (J428)	Labels: 2Q0-907-572.clb
    	ROD: EV_ACCMRRCONTIVW376_003.rod
    	VCID: 42C7D90B129159CC408678-8017
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	VCID: 8C5BB733E0555FBCFA6AA6-80D9
    	Subsystem 1 - 	Part No SW: 4M0-959-339-B
    	Component: BF-Gewichtss.H13 0022
    	Serial Number: IBH00000000000BPA80E
    	Coding: 303352
    	Subsystem 2 - 	Part No SW: --------------
    	Component: SideSensor_Df001 0887
    	Serial Number: 3570000000085BF82C3-
    	Subsystem 3 - 	Part No SW: --------------
    	Component: SideSensor_Pf001 0887
    	Serial Number: 358000000009A465FB3-
    	Subsystem 4 - 	Part No SW: --------------
    	Component: SideSensor_Dr005 6149
    	Serial Number: 3510001BAF029AA7F85Q
    	Subsystem 5 - 	Part No SW: --------------
    	Component: SideSensor_Pr005 6149
    	Serial Number: 3520001C8EFE7865C34X
    	Subsystem 6 - 	Part No SW: --------------
    	Component: FrontSensor_D005 6149
    	Serial Number: 3550001BCF051DB3FA1P
    Address 17: Instruments  (J285)	Labels: 5N-17.lbl
    	VCID: 44CBDF13088557FC72BA4E-8011
    Address 19: CAN Gateway  (J533)	Labels: 3Q0-907-530-V1.clb
    	ROD: EV_GatewNF_VW37.rod
    	VCID: 6E9F5DBB76898DACF45E1C-803B
    	Subsystem 1 - 	Component: 0-00-0d-00-04
    	Subsystem 2 - 	Part No SW: 5NA-959-442-B
    	Component: E221__MFL-TATH06 0025
    	Serial Number: 0981902550700324FG2B
    	Coding: 2E0000
    	Subsystem 3 - 	Part No SW: 5QA-915-181-D
    	Component: J367-BDMHellaH10 9070
    	Serial Number: 8840436600
    Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
    	Coding: 0101
    	Shop #: WSC 00000 000
    	VCID: 45CDC21703BF6EF465A45B-8010
    Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
    	VCID: 33298CCF5D2BE044DB1095-8066
    Address 36: Seat Mem. Drvr  (J810)	Labels: None
    	ROD: EV_SeatMemorDriveSide_002.rod
    	VCID: 3D3DAAF76B6F26343D7403-8068
    	ROD: EV_LCMRightHELLAAU736_VW37.rod
    Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
    	Coding: 02011103
    	ROD: EV_HREntryHella.rod
    Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
    	Coding: 001F1B205200048000000000
    	VCID: 4FE1E03FD1C3A4A4DF08C9-801A
    Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
    	Coding: 911F0000
    	VCID: 50E3E343CCFDBB5CC632D2-8005
    Address 47: Sound System  (J525)	Labels: 5Q0-035-456.clb
    	Revision: 00000001
    	VCID: 2E1F9DBBB609CDACB4DE5C-807B
    Address 4B: Multifunc. Module  (J745)	Labels: None
    	VCID: 352DB2D7535FFE74F504EB-8060
    Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
    	Coding: 001F13205E00048000000000
    	VCID: 4EDFFD3BD6C9ADACD41EFC-801B
    Address 5F: Information Electr.  (J794)	Labels: 5G0-035-MIB-STD2.clb
    	Subsystem 1 - 	Part No SW: 5G6-919-605-D
    	Component: ABT_Std-2_Nav254 8130
    	Serial Number: VWZ6ZMW1755086
    	Subsystem 2 - 	Part No SW: 5NA-919-866-E
    	Serial Number: --------------------
    Address 6C: Back-up Cam.  (J928)	Labels: 5Q-6c.lbl
    	ROD: EV_CamSysRVAV2ARCE2MQBAB_006.rod
    	VCID: 3935BEE77F471A14112CD7-806C
    Address 6D: Trunk Elect.  (J605)	Labels: 5Q0-959-107.clb
    	Revision: --------
    	Coding: 0A28
    	VCID: 46CFC51B3EB965EC6CAEA4-8013
    Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
    Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q0-980-65X-A5.clb
    	Coding: 0003070601020201002213548150890084000E20012000
    	ROD: EV_MFKBoschMQBB_002.rod
    	VCID: 40C3D3031C9D4BDC569262-8015
    Address CA: Sunroof  (J245)	Labels: None
    	VCID: 75AD72D713DFBE743584AB-8020
    Address D6: Light Ctrl Left 2  (A31)	Labels: None
    	VCID: 80439303DC1D0BDC961222-80D5
    Address D7: Light Ctrl Right 2  (A27)	Labels: None
    	ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End--(Elapsed Time: 03:04, VBatt start/end: 12.3/12.3 Vign: 0.0)-
