Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 2013 Audi A4 work shop code?
    Trying to enjoy all of the features of this software but come up against dialog box wanting "3" code, 0-9999. Is there some way to glean this from an autoscan? Car has been to the shop I can see that from the scan but there is nothing to indicate what the access code might be to "unlearn behaviours" etc. Thanks in advance for any input. I can post up whatever will help of course for anyone with knowledge of this. Best to all on the forum
    My apologies, I did not fully read the online manual about the work shop codes. I will be more vigilant and let the software do its job and read more in depth before I post.
    Update, when i went back to options in startup menu and selected save settings I was still asked for the 3 digit code when I try to tweak in module 44. If i go to "security" in the 44 module it asks for a 5 digit code? I did notice that the WSC starts with 5 digits so I will try that. Otherwise the program did not act in stealth mode as suggested and will not let me "unlearn steering behaviour". Any input would be welcome.
    I'm having a hard time visualizing exactly where this is occurring. Can you post up some screen-shots please?
    Hi Uwe,
    Much obliged for responding to the post. Will post up some screen shots as soon as possible.
    Best
    Hi Uwe,
    I just sent my autoscan off to RossTech and I am on a slight learning curve with the Toshiba laptop I went with to do this kind of work. Needless to say I have been a Mac person for the last 30 years so getting the screen shots up is going to take me a little longer. The screenshot issue I have down but posting them will require I do a little more reading. I don't want to waste your time until I can do this a little more efficiently. I will get them up as soon as possible.
  7. #7
    Hi Uwe,
    Any chance I can send you an autoscan along with the screenshots? I will give support another day but I haven't heard back from them after following their instructions. I have all the screen shots in photot bucket url form and cayn add them along with the autoscan. Let me know if this is something you would consider. Don't want to take advantage of your generosity.
    GB
  8. #8
    Is there some reason you don't want to post them here?
    United States
    I believe he is referring to the UDS (reserved) box but I'm not entirely sure.
    Internal Ref to E?ID=200940
  10. #10
    2013 A4 Work Shop Code
    Hi, here is the first scan I took, the latest scan and screen shots. Hopefully I did this right.
    Sunday,13,April,2014,13:30:29:21746
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUHFAFL2DA195461   License Plate: GFM1511
    Mileage: 17440km-10836mi   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62 6C
             72
    VIN: WAUHFAFL2DA195461   Mileage: 17440km/10836miles
    Address 01: Engine (0-----CAEB)       Labels: 06H-907-115-CDN.clb
      Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
      Component: 2.0l R4/4V TF H09 0005
      Revision: ECH09---
      Coding: 4A190013242600062000
      Shop #: WSC 38543 000 1048576
      ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
      ROD: N/A
      VCID: 326B16B4657B938E5D3-8067
    No ASAM data for: "EV_ECM20TFS0118K5907115C" (AU48)
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
      Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
      Coding: 071D18
      Shop #: WSC 06325 000 00000
      VCID: 8407006C074F6D3E3FF-80D1
                       Fault Status: 00101101
                       Reset counter: 193
                       Mileage: 17443 km
                       Date: 2014.04.06
                       Time: 11:06:32
                       Hex Value: 0x0000
                       Hex Value: 0x0082
                       Hex Value: 0x001A
                       Hex Value: 0x0297
                       Hex Value: 0x0000
      Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
      Component: BCM2 2.0      H12 0633
      Coding: 0F814000000000000000
      VCID: 81090978185D7816149-80D4
      Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
      Revision: C1000000    Serial number: 01180120131569
      Coding: 6400208000
      VCID: 39792198B00D60D69C9-806C
      Revision: 08016001    Serial number: 00000539092902
      Coding: 26000091863CAFC00000480300003D0D0F1C1208A2090221000008000000030100000030000000
      VCID: 78FFE49CCB87B9DEA37-802D
      Component: WWS 210113  H07 0080
      Coding: 00FD11
      Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
      Coding: 02005D
      Component: E1 - LDS  H03 0031
      Component: USHL4.2  H30 0030
      Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
      Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
      Serial number: 003KJD91AGHM
      Coding: 303842354730303030304A55304C384B3053
      ROD: EV_AirbaECUVWAUDI010_AU48.rod
      VCID: 4A9B6E54EDEBFB4E053-801F
      Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
      Serial number: 5810000R120000AZ8Z
      Serial number: 6334MSME76116C44E
      Serial number: 6344MSME761108647
      Serial number: 6352QSME6826365AN
      Serial number: 6362QSME3E2D486C/
      Serial number: 63732SME6D262544+
      Crash sensor for front airbag; passenger side:
      Serial number: 63832SME4527336E1
      Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
      Component: Lenks.Modul   H02 0171
      Revision: 00000000    Serial number: 20130121000643
      Coding: 000016
      VCID: 4FAD7F401E89DE6652D-801A
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
      Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
      Component: KOMBIINSTR.   H35 0556
      Revision: 00300000    Serial number: UVN79AJ1E
      Coding: 8BB409000301D705020000
      VCID: 35612DA89C1584B6781-8060
      Component: GW-BEM 4CAN-M H11 0055
      Revision: 1Y060027    Serial number: 2741Y131150658
      Coding: 80C303FF00
      VCID: 4A9B6E54E5EBFB4E053-801F
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
      Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
      Component: MEM-FS        H06 0076
      Revision: AA000000    Serial number: 00000048546902
      Coding: 00581B00000000000000
      VCID: 3B753B90BA3152C68E5-806E
      Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
      Component: TSG FA        H09 0304
      Coding: 011C13204E00410001
      VCID: 56A38A242153AFAE91B-8003
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
      Revision: 00001000    Serial number: 0007166157
      Coding: 100000000001
      Shop #: WSC 06324 000 00000
      ROD: EV_RCEPSAU48X.rod
      VCID: 346710AC9F6F9DBE4FF-8061
      Revision: 00002001    Serial number: 0300234317
      Coding: 0106023A00FA404580B0013200000000
      Component: GTO BF  H01 0080
      Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
      Component: J245 PS050  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
      Revision: 00005001    Serial number: 94813009669202
      VCID: 2D5105C87445CC76001-8078
      Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
      Component: TSG BF        H09 0304
      VCID: 55A18D283C55A4B6981-8000
      Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
      Component: EPB-4         H01 0003
      Revision: --------    Serial number: 00000001232281
      ROD: EV_ParkiBrake_AU48.rod
      VCID: 387F249C830779DE637-806D
    721152 - Brake pad replacement mode active
             C1011 00 [000] - -
                       Fault Status: 00000000
                       Fault Frequency: 0
                       Reset counter: 0
                       Time: 00:00:00
      Part No SW: 4G0 035 082 E    HW: 4G0 035 082
      Component: Radio U SIRIU H60 0121
      Revision: AB001007    Serial number: 156AV0D7682402
      Coding: 020007010000000001
      VCID: 224BE6F43D9B030EAD3-8077
      Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
      Component: H-BNT-NA      H44 0624
      Revision: --------    Serial number: 204AO0D7555132
      Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
      VCID: 377D27A0861976A66AD-8062
      Subsystem 1 - Part No: 8R0 060 884 BA
      Component: NAR 2013  0703
      Component: DU7 High  H42 0104
      Component: CD-Database  4949
      Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
      Component: TSG HL        H07 0304
      Coding: 010C13204000210001
      VCID: 59B98118504D80D6BC9-800C
      Revision: --H07---    Serial number: 525PA8-J2X935D
      Coding: 1000006
      VCID: 387F249C4B0779DE637-806D
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
      Component: TSG HR        H07 0304
    Sunday,13,April,2014,15:20:51:21746
             72
      Revision: ECH09---
      ROD: N/A
      Coding: 071D18
                       Reset counter: 193
                       Mileage: 17443 km
                       Date: 2014.04.06
                       Time: 11:06:32
                       Hex Value: 0x0000
                       Hex Value: 0x0082
                       Hex Value: 0x001A
                       Hex Value: 0x0297
                       Hex Value: 0x0000
      Coding: 6400208000
      Coding: 00FD11
      Coding: 02005D
      Coding: 000016
      Coding: 80C303FF00
             C1011 00 [000] - -
                       Fault Frequency: 0
                       Reset counter: 0
                       Time: 00:00:00
      Coding: 1000006
    Sunday,13,April,2014,15:24:49:21746
    Address 44: Steering Assist (8K0 909 144 F)
    15:24:33
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/dsrbox.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/44pane.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/adaptset.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/error2.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/VCDS9.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/IDscreen.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/adaptscreen.png[/IMG]
    [IMG]http://s1191.photobucket.com/user/garnetlake/media/steerassist.png[/IMG]
    Latest Scan
     Thursday,17,April,2014,15:17:43:21746
    Mileage: 17460km-10849mi   Repair Order:
              72
    VIN: WAUHFAFL2DA195461   Mileage: 17460km/10849miles
       Revision: ECH09---
       ROD: N/A
       Coding: 071D18
                        Reset counter: 193
                        Mileage: 17443 km
                        Date: 2014.04.06
                        Time: 11:06:32
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x001A
                        Hex Value: 0x0297
                        Hex Value: 0x0000
                        Reset counter: 156
                        Mileage: 17445 km
                        Date: 2014.04.13
                        Time: 18:18:16
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0015
                        Hex Value: 0x1098
                        Hex Value: 0x0000
       Coding: 6400208000
       Coding:
    000
    1KX-955-119.CLB
       Coding: 00FD11
       Coding: 02005D
       Coding: 000016
       Coding: 80C303FF00
       Coding: 000000000001
              C1011 00 [000] - -
                        Fault Frequency: 0
                        Reset counter: 0
                        Time: 00:00:00
       Coding: 1000006
