Results 1 to 3 of 3
Thread: Check light error for LED reverse lights, Fabia III
    Jun 2015
    I have a strange problem with my Fabia: I replaced the reverse lights with high-power LEDs and now I get a check light warning. I have learned that I should be able to set the load for each bulb individually, and also that the reverse lights should be Leuchte28. It is in fact the only one with a mention of "Rueckfahrlicht" in the entire module, but I do not have a channel "(1) Load type" for the Leuchte28 ?? In the latest beta, this channel shows up, but it is "Not activated" or something similar (I can't remember the exact wording), and I am not able to change the value.
    Wednesday,27,May,2015,22:04:21:63777
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: TMBEN6NJ3FZ0xxxxx   License Plate: xxx-xxx
    Mileage: 3386   Repair Order:
    Chassis Type: NJ (6C0)
    Scan: 01 03 05 08 09 10 13 15 17 19 2B 44 5F 69
    VIN: TMBEN6NJ3FZ025636
    Address 01: Engine (J623-CJZD)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
       Component: 1.2l R4 TSI   H21 8229
       Revision: R4H21---
       Coding: 01190032243415080000
       Shop #: WSC 73430 031 00045
       ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
       ROD: EV_ECM12TFS_VW26.rod
       VCID: 66C8BB60999EEC11F43-8033
       Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0003
       Serial number: 08508261150116
       Coding: 41F5487D492533C5091A106C0057821292CC9008000DCBF98F00
       Shop #: WSC 13765 031 00045
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       ROD: EV_Brake1ESP90iBOSCHPQ26_SE26.rod
       VCID: 336E12349ACC49B9A3D-8066
       Revision: 00021000    Serial number: 0358182678
       Coding: 030C0C
       Shop #: WSC 13765 790 00045
       ROD: EV_KessyHellaMQBAB_SK26.rod
       VCID: 3A703F10BDA6B8F160B-806F
       Part No SW: 6V0 907 044     HW: 6V0 907 044
       Component: Climatronic   H01 0105
       Serial number:  1501201A-0253
       Coding: 100000001011100001
       ASAM Dataset: EV_ACClimaValeoPQ26 003001
       ROD: EV_ACClimaValeoPQ26.rod
       VCID: 74ECD128DF420E817A7-8021
    329476 - Motor for Fresh Air / Recirculated Air Flap
              B108B 71 [012] - Actuator stuck
                        Reset counter: 33
                        Mileage: 11 km
                        Date: 2015.03.03
                        Time: 09:13:44
    1179905 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 8
                        Mileage: 3032 km
                        Date: 2015.05.13
                        Time: 20:14:50
       Part No SW: 6C0 937 090 B    HW: 6C0 937 090
       Component: BCM PQ26 HiKR H07 0065
       Serial number: 001108006926
       Coding: 0C03085042150AFB43804000402F07080800D900D30A3500000000000000
       Shop #: WSC 73430 790 00045
       ASAM Dataset: EV_BCMA0 004008
       ROD: EV_BCMA0_SK26.rod
       VCID: 2756F6645E1435190F5-8072
       Slave 2:
       Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A
       Component: RLHS  037 0059
       Serial number: S5Y15M01D28H17M24S34
       Coding: 00185E
       Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
       Component: FHSG DRV  007 0001
       Serial number: 00000000000000733403
       Coding: 011200
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
       Component: PARKHILFE 3K  H10 0048
       Revision: --------    Serial number: 39231502402235
       Coding: 0001050101
       ROD: EV_EPHVA14AU3700000_AU37.rod
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 18121403212312
       Coding: 00000800FE0739
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 3874251883AAAAE196F-806D
    Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
       Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
       Component: VW20Airbag023 001 0340
       Revision: --------    Serial number: 003RJ000L0E+
       Coding: 88CCC000000000005C5400CF000800000000
       ROD: EV_AirbaVW20BPAVW26X_SK26.rod
       VCID: 36682B2089BE5C91843-8063
       Subsystem 1 - Part No SW: -----------    HW: 410 822 101 15
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00C116DB7D0D0C/
       Subsystem 2 - Part No SW: -----------    HW: 410 822 101 15
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H00AF18F34B0C2B1
       Subsystem 3 - Part No SW: -----------    HW: 442 152 501 15
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00A7183BFD540DU
       Subsystem 4 - Part No SW: -----------    HW: 442 152 501 15
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00A7183BFD4543P
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 6V0 920 740     HW: 6V0 920 740
       Component: KOMBI         214 0290
       Coding: 072401102180000801882A011000000000000000
       ROD: EV_DashBoardVDDMQBAB_SE25.rod
       VCID: 72E0D730A55600B168B-8027
       Part No SW: 6C0 909 901     HW: 6C0 937 090
       Component: GW MQB A0     H07 0065
       Revision: --------    Serial number: 001108006926
       Coding: 030100342F0A640000000000000000010001050000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: EV_GatewA0Lear_SK26.rod
       VCID: 65CABC6C6498E709FD9-8030
       Subsystem 1 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H05 0130
       Serial number: 000000000C0332230115
       Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
       Component: J367-BDM  H08 0223
       Serial number: 62016I56432821347447
       Revision: 00000000    Serial number: 15000004170002
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB_SE25.rod
       VCID: 346C11289FC24E81BA7-8061
    Address 44: Steering Assist (J792)       Labels: Redir Fail!
       Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  311 3211
       Serial number: CF1Q0865
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_SK26.rod
       VCID: 3260173065D640B1A8B-8067
       Part No SW: 5Q0 035 819     HW: 5Q0 035 819
       Component: MU-S--ER      H11 0135
       Serial number: SKZAZ2R0010231
       Coding: 03620000BE00000011110004000808002F0100C40120010000
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_SK26.rod
       VCID: 70E4DD38AB5A32A19EF-8025
       Media Player Position 1:
       Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
       Component: ABTm_Std2  H40 1022
       Serial number: SKZ8Z9RH30067B
              U11B8 00 [008] - No Communications
                        Fault Frequency: 91
                        Reset counter: 30
                        Mileage: 123 km
                        Date: 2015.03.11
                        Time: 19:53:14
    Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
       Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 8C001001    Serial number: 0358097400
       Coding: 0100000202000000
       ROD: EV_TrailFunctGener2Hella.rod
       VCID: 3972201CB8A0B3E9691-806C
    End-------------------------(Elapsed Time: 02:58)--------------------------
    (19)-Leuchte27 KL58XS C67-Dimming_Direction_GH_27,maximize
    (2)-Leuchte28RFL C3-Lampendefektbit_Position_28,2B
    (3)-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28,34
    (4)-Leuchte28RFL C3-Light_Function_A_28,Rueckfahrlicht
    (5)-Leuchte28RFL C3-Light_Function_B_28,not active
    (6)-Leuchte28RFL C3-Dimming_AB_28,100
    (7)-Leuchte28RFL C3-Light_Control_HD_AB_28,Always
    (8)-Leuchte28RFL C3-Light_Function_C_28,not active
    (9)-Leuchte28RFL C3-Light_Function_D_28,not active
    (10)-Leuchte28RFL C3-Dimming_CD_28,0
    (11)-Leuchte28RFL C3-Dimming_Direction_CD_28,maximize
    (12)-Leuchte28RFL C3-Light_Function_E_28,not active
    (13)-Leuchte28RFL C3-Light_Function_F_28,not active
    (14)-Leuchte28RFL C3-Dimming_EF_28,0
    (15)-Leuchte28RFL C3-Dimming_Direction_EF_28,maximize
    (16)-Leuchte28RFL C3-Light_Function_G_28,not active
    (17)-Leuchte28RFL C3-Light_Function_H_28,not active
    (18)-Leuchte28RFL C3-Dimming_GH_28,0
    (19)-Leuchte28RFL C3-Dimming_Direction_GH_28,maximize
    (1)-Leuchte29 KL30G A69-Type_Of_Load_29,allgemeineGluehlampe12W
    (2)-Leuchte29 KL30G A69-Lampendefektbit_Position_29,00
    (3)-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29,01
    (4)-Leuchte29 KL30G A69-Light_Function_A_29,Klemme 30G
    (5)-Leuchte29 KL30G A69-Light_Function_B_29,not active
    (6)-Leuchte29 KL30G A69-Dimming_AB_29,100
    (7)-Leuchte29 KL30G A69-Light_Control_HD_AB_29,Always
    (8)-Leuchte29 KL30G A69-Light_Function_C_29,not active
    (9)-Leuchte29 KL30G A69-Light_Function_D_29,not active
    (10)-Leuchte29 KL30G A69-Dimming_CD_29,0
    (11)-Leuchte29 KL30G A69-Dimming_Direction_CD_29,maximize
    (12)-Leuchte29 KL30G A69-Light_Function_E_29,not active
    (13)-Leuchte29 KL30G A69-Light_Function_F_29,not active
    (14)-Leuchte29 KL30G A69-Dimming_EF_29,0
    (15)-Leuchte29 KL30G A69-Dimming_Direction_EF_29,maximize
    (16)-Leuchte29 KL30G A69-Light_Function_G_29,not active
    (17)-Leuchte29 KL30G A69-Light_Function_H_29,not active
    (18)-Leuchte29 KL30G A69-Dimming_GH_29,0
    (19)-Leuchte29 KL30G A69-Dimming_Direction_GH_29,maximize
    (1)-Leuchte2SL VLB22-Type_Of_Load_2,LED Tagfahrlichtmodul Signal
    (2)-Leuchte2SL VLB22-Lampendefektbit_Position_2,48
    Is it possible to somehow change the load type for the Leuchte28, or to disable the light check altogether for this bulb, or do I just have to live with the error or switch back to traditional bulbs for the reversing lights. Based on advice I have tried changing the load type for Leuchte29, but that did not do any good.
    Mar 2014
    Europe
    You can turn off the light bulb checking to the specified bulb by altering its lampendefektbitposition to 00 and/or fehlerormittleresbyte to 00. If I'm right it's enough to change just one of these, however I'm not sure whether it is the defektbitposition or fehlerort... You have to try yourself.
  3. Likes Uwe, Eric liked this post
    Jun 2015
    Thanks for the tip!
    I set the value for
    to 00, and I no longer getting the error message!
  5. Likes Uwe, Eric liked this post
