Results 1 to 6 of 6
Thread: Access to telephone control module missing
    Jun 2015
    Question Access to telephone control module missing
    I am using HEX-NET with VCDS Mobile, ASAM and interface software are up to date. The vehicle is a 2015 S5 Cabriolet. On page 13 of the online PDF manual is a screen shot of the groups accessible to VDCS. It includes Electronics 1 and Electronics 2 groups. The telephone is shown to be in Electronics 1. Neither of hese groups appear on the VCDS mobile screen, but the others (Installed, Common, Drive Train etc) do. My purpose for purchasing HEX-NET was to activate voice control, which according to your documentation, is in the telephone control module, address 77 under Electronics 1. When I go directly to that address (Send), I get the ominous Kline Init 1, 2 & 3 which have done nothing except end in an error timeout whenever I encounter it. I get the same result from iMac, iPhone and iPad.
    What do you suggest to make this happen?
    Thanks,
    -Gary
    Please post an Auto-Scan so we can see what VCDS-Mobile finds in your car.
    Does your gateway see the telephone? An autoscan would answer that question.
    Jun 2015
    Auto-Scan results
    After viewing your video for posting an auto-scan, I selected the S5 chassis type FH based on my VIN. It is not the cabriolet although my window sticker says it is. ?? Anyway, I've deleted the previous posts and posted the most recent re-run of the auto scan. Here it is....
    Gateway list:
    The following is the scan after manually selecting the chassis type FH from the drop down list....
    VCDS Mobile 0.4123.0.4
    VIN: WAUCGAFH3FN000711
    Chassis Type:8T or FH
    Scan: 01 02 03 05 06 07 08 09 0E 0F 10 13 14 15 16 17 18 19 1B
    	 1E 36 37 3C 3D 42 46 47 52 53 55 56 57 5C 65 67 69 6C 6D 77
    Address 01: Engine  (CGXC4 J623)	Labels: 06E-907-551-CGW.clb
    	Part No SW: 8K5 907 551 F	HW: 4G0 907 551 A
    	Component: 3.0l V6 TFSI
    	Revision: --H07---
    	Coding: 1A250034052600060000
    	ASAM Dataset: EV_ECM30TFS0218K5907551F 001002
    	ROD: EV_ECM30TFS0218K5907551F.rod
    	VCID: 3935BEE721931AB7902D6D-806C
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels: 8K-02.lbl
    	Part No SW: 8K5 927 156 D	HW: 0B5 927 156 K
    	Component: 0B5 30TFSINAR H02 0003
    	Revision: --H02---
    	Coding: 000001
    	ROD: EV_TCMDL501021.rod
    	VCID: 3A37A1EB249511AF99579A-806F
    Address 03: ABS Brakes  (J104)	Labels: 8K0-907-379.clb
    	Part No SW: 8K0 907 379 CP	HW: 8K0 907 379 CP
    	Component: ESP8 quattro  H09 0020
    	Coding: 291D1801
    	VCID: 89558E27B1F35237404DFD-80DC
    Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
    	Part No SW: 8K0 907 064 JP	HW: 8K0 907 064 JP
    	Component: BCM2 2.0      H14 0650
    	Coding: 0D834040000000000000
    	VCID: 8751881FA7E724475659CB-80D2
    	Subsystem 1 - 	Part No SW: 8K0-959-754-ABÿ
    	Component: FBSAUDIB8 IDGH71 0083
    	Subsystem 2 - 	Part No SW: 8K0-905-852-E
    Address 06: Seat Mem. Pass  (J521)	Labels: 8T0-959-760.clb
    	Part No SW: 8T0 959 760 F	HW: 8T0 959 760 F
    	Component: MEM-BFS       H10 0077
    	Coding: C80370250D2400001000
    	VCID: 46CFC51B606D7D4FEDAF1E-8013
    Address 08: Auto HVAC  (J255)	Labels: 8K-08.lbl
    	Part No SW: 8K1 820 043 AR	HW: 8K1 820 043 AR
    	Component: KLIMA 3 ZONEN H04 0122
    	Coding: 6603228E00
    	VCID: 78B37BE35A19DBBFAFA330-802D
    Address 09: Cent. Elect.	Labels: 8K0-907-063.clb
    	Part No SW: 8K0 907 063 DH	HW: 8K0 907 063 DH
    	Component: 0103H16
    	Coding: 26000091863CAFE0010048C000003D0D0F9CD288A209022100000B004000030100000070000000
    	Subsystem 1 - 	Part No SW: 8F1-955-119	Labels: 1Kx-955-119.clb
    	Component: WWS 070514   H07 0080
    	Coding: 00FD11
    	Subsystem 2 - 	Part No SW: 8U0-955-559-B
    	Component: G397_RLFS    H06 0002
    	Coding: 02005D
    	Subsystem 3 - 	Part No SW: 8K0-941-531-AS-B
    	Component: E1 - LDS     H03 0031
    	Subsystem 4 - 	Part No SW: 4G0-907-410-A
    	Component: USHL4.2      H30 0030
    	Subsystem 5 - 	Part No SW: 4H0-907-658
    	Component: AQ_Hum_SensorH03 0003
    Address 15: Airbags  (J234)	Labels: 8F0-959-655.clb
    	Part No SW: 8F0 959 655 F	HW: 8F0 959 655 F
    	Component: AirbagVW-AU10 H21 0512
    	Coding: 303741353731393130304A55304C38463053
    	ASAM Dataset: EV_AirbaAU10SMEAU485 001210
    	ROD: EV_AirbaAU10SMEAU485.rod
    	VCID: 3B39A4EF2BAF28A7824197-806E
    	Subsystem 1 - 	Part No SW: 8K0-959-339-A
    	Component: BF-Gewichtss.H02 0060
    	Serial Number: 5810000R140000H43Cªª
    	Subsystem 2 - 	Serial Number: 6334MSME45496766KCªª
    	Subsystem 3 - 	Serial Number: 6344MSME45497026BCªª
    	Subsystem 4 - 	Serial Number: 6352QSME743E3E6C/Cªª
    	Subsystem 5 - 	Serial Number: 6362QSME4645107AFCªª
    	Subsystem 6 - 	Serial Number: 63732SME403F387A6Cªª
    	Subsystem 7 - 	Serial Number: 63832SME743E1E707Cªª
    Address 16: Steering wheel  (J527)	Labels: 8K0-953-568.clb
    	Part No SW: 8K0 953 568 Q	HW: 8K0 953 568 Q
    	Component: Lenks.Modul   H03 0003
    	Coding: 000036
    	VCID: 48D3CB236A796B3F1FC300-801D
    	Subsystem 1 - 	Component: E221 - MFL   H03 0004
    Address 17: Instruments  (J285)	Labels: 8T0-920-xxx-17.clb
    	Part No SW: 8T0 920 984 F	HW: 8T0 920 984 F
    	Component: KOMBIINSTR.   H35 0564
    	Coding: 8BBF19000301D705020000
    	VCID: 42C7D90B4C45416FC187C2-8017
    Address 19: CAN Gateway  (J533)	Labels: 8T0-907-468.clb
    	Part No SW: 8R0 907 468 P	HW: 8R0 907 468 D
    	Component: GW-BEM 5CAN-M H11 0060
    	Coding: 80C303FF00
    	VCID: 4CDBF7337E01871F3BEB5C-8019
    	Subsystem 1 - 	Part No SW: 8T0-915-181
    	Component: J367-BDMHellaH03 8041
    Address 36: Seat Mem. Drvr  (J136)	Labels: 8T0-959-760.clb
    	Component: MEM-FS        H10 0077
    	Coding: C81B7B250D2400001000
    Address 3C: Lane Change  (J769)	Labels: None
    	Part No SW: 8T0 907 566 B	HW: 8T0 907 566 B
    	Component: SWA Master    H05 0071
    	Coding: 010211
    	ROD: EV_LaneChangAssis.rod
    	VCID: 3FC1D0FF3FB73487AE69A3-806A
    Address 42: Door Elect, Driver  (J386)	Labels: 8K0-959-793.clb
    	Part No SW: 8T0 959 793 P	HW: 8T0 959 793 G
    	Component: TSG FA        H09 0305
    	Coding: 011C53724E08332C03
    	VCID: 56EF155BB0CDCDCF9D4FAE-8003
    Address 46: Central Conv.  (J393)	Labels: 8K0-907-064-46.clb
    	Coding: 010602BA00FA402180B0033200000000
    	Subsystem 1 - 	Part No SW: 8F0-959-719-B
    	Component: GTO BF       H01 0080
    	Subsystem 2 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    Address 47: Sound System  (J525)	Labels: 8F-47.lbl
    	Part No SW: 8F1 035 223 A	HW: 8F1 035 223 A
    	Revision: 00005001
    	Shop #: WSC 00000 000
    	VCID: 1F01707F9F774C878E2943-804A
    Address 52: Door Elect, Pass.  (J387)	Labels: 8K0-959-792.clb
    	Part No SW: 8T0 959 792 P	HW: 8T0 959 792 G
    	Component: TSG BF        H09 0305
    	Coding: 011C53324E08332C03
    	VCID: 55ED1257ADCBC6D79445B1-8000
    Address 53: Parking Brake  (----)	Labels: 8K0-907-801.clb
    	Part No SW: 8K0 907 801 N	HW: 8K0 907 801 J
    	Component: EPB-4         H02 0005
    	Revision: --------
    	ROD: EV_ParkiBrake_AU48.rod
    Address 56: Radio  (R)	Labels: None
    	Part No SW: 4G0 035 082 G	HW: 4G0 035 082
    	Component: Radio U SIRIU H60 0133
    	Coding: 020007010000000101
    	VCID: 240B7F93B6116F5FD37B94-8071
    Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
    	Part No SW: 8F0 907 441	HW: 4L0907441B
    	Component: J772__Rearview       0040
    	Revision: --H09---	Serial Number: 525PA8-J44B0FA
    	Coding: 1000009
    	VCID: E791A89F87A74447B619EB-80B2
    Jun 2015
    Found the info on Sean Harding's blog. 5F (electronics info), byte 16 (system dialogue). Voice command has been activated, you can close this thread. Thanks for looking at it for me.
    -Gary
    You shouldn't have to manually pick a chassis type on that car.
    Curiously, 5F doesn't show in the scan. I'm thinking that's because 5F is missing from the "manual" list. I'm not sure why we even have a manual list for that car at this point. ;-)
