Results 11 to 20 of 26
Thread: 2005 tdi BEW/PD wagon
    Jun 2015
    can that cause any problems like I'm having
  2. #12
    It certainly shouldn't prevent comms with other systems, but it makes me wonder what other skeletons are in this car's closet.
    My money is still on wiring damage at or near the K-Line junction.
  3. #13
    Jun 2015
    and where can the K Line junction be found
  4. #14
    Dallas (McKinney) ,TX ,USA
    I would put money on Bad Cluster and causing K-line short.
    I would disconnect cluster first and see can you communicate with rest of the module.
    NOTE :
    when you disconnect cluster ECu will not communicate and that is normal because communication goes via W-line in cluster.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes Uwe liked this post
  6. #15
    Jun 2015
    will a gas cluster work and how do you set up the cluster
  7. #16
    Why worry about what cluster will work until you've determined that the one you have is causing this problem? Try what Jetta,97 suggested. Disconnect the existing cluster and see if you have communications with stuff like CCM and Airbags. If you still can't communicate with those modules, then your cluster is not the problem.
  8. #17
    Jun 2015
    thanks for keeping me on track I will do that today.
  9. Likes Uwe liked this post
  10. #18
    Jun 2015
    I tried disconnecting the cluster the only thing I can read is the ABS brakes
  11. #19
    Jun 2015
    so what's the procedure for changing your cluster and do you need a diesel cluster
  12. #20
    Huh? If you disconnected the cluster and the problem still persists, the problem is NOT caused by the cluster.
    But while you have the cluster out, how about doing a continuity test between pin 7 of the OBD-II connector and the K-Line pin of the cluster harness? A lack of continuity would confirm that you do indeed have a wiring problem.
