Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: 2005 tdi BEW/PD wagon
    Jun 2015
    I have no check engine light at all. When I pug my ross-tech cable in I get a green light and can communicate with the ABS system. Other than that I cannot enter any other parts of the programmer? Does anyone one have a clue what to look for. There is a aftermarket radio it works fine, I unplugged it hoping that might help, but their was no change.
    So you're saying you've run an Auto-Scan and the ONLY thing that talked was the ABS?
    Jun 2015
    Yes the only thing that responds is the ABS. The fuses all look good, new battery, good ground. I have no engine light but all the other lights come up. I'm guessing this has a correlation with a non communication issue.
    Any history? When how did this occur? Does the engine start/run?
    Jun 2015
    I bought the car last weekI was told the timing belt was changed. the car runs goods 270 5000 miles on it
    I suppose if it were mine, I'd trace the K-line from pin 7 of the diagnostic connector to the corresponding pins on some of the modules. You're going to need a WD and DVM.
  7. #7
    Jun 2015
    there was a tracking device installed in the car that was removed
  8. #8
    Then I would definitely be inspecting / tracing the wiring.
  9. #9
    Jun 2015
    the other thing I find weird is there's a car with a key on next to the a b s light
  10. #10
    So something like this?
    If that's on all the time and the car runs anyway, chances are someone has done immobilizer defeat on your ECU.
