Results 1 to 6 of 6
Thread: 2012 Passat SE TDI - Unknown Error Code
    May 2015
    I just bought this car with 22k on it a few weeks ago.
    On a 60 mile 70mph trip on the interstate, I had my check engine light come on. That prompted me to order a Hex-USB-Can cable and see what was going on.
    At address 01 (engine), an unknown code came up. I have since cleared the code. I haven't taken any long trips since the reset, and the light is still out.
    I had the car checked out by a mechanic (pre-purchase), and his auto scan picked out the low voltage hits as well. This scan was done before I had the chance to change out the battery, which I had done just yesterday. We'll see if the under voltages calm down.
    I thought I would post it, to see if there were any suggestions.
    Thanks
    Thursday,28,May,2015,17:48:15:46764
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: 1VWBN7A34CC037631   License Plate:
    Mileage: 36680km-22791mi   Repair Order:
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
              77
    VIN: 1VWBN7A34CC037631   Mileage: 36680km-22791miles
    Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
       Part No SW: 03L 906 012 BP    HW: 03L 907 309 S
       Component: R4 2,0L EDC   H21 7445
       Revision: 71H21---    Serial number:
       Coding: 001D0012042400000000
       Shop #: WSC 64940 000 1048576
       ASAM Dataset: EV_ECM20TDI01103L906012BP 004009
       ROD: EV_ECM20TDI01103L906012.rod
       VCID: 73E59B36DA0384B963D-8026
    15733 - ROD - Unknown Error Code
              - 00 [236]
                        Mileage: 36467 km
                        Date: 2015.05.23
                        Time: 17:21:58
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 3113
       Revision: 05351113    Serial number: 00001111031555
       Shop #: WSC 09003 957 00200
       VCID: 2643B2629151A111343-8073
       Revision: 00H31001
       Coding: C54BC0F549250001A31103E7921A0042A71000
       VCID: 7DF1BD0EE447C2C9059-8028
    02214 - Tire Pressure Warning
                        Reset counter: 174
                        Mileage: 36132 km
                        Date: 2015.05.16
                        Time: 22:19:15
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 50944
                        Count: 256
       Part No SW: 561 907 044 H    HW: 561 907 044 H
       Component: Climatronic   043 0202
       Revision: 00001001
       Coding: 0018001002
       VCID: 1C37908A171D6BC1927-8049
       Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
       Component: BCM PQ35 H+   121 0164
       Revision: BL121001
       Coding: 6F200E1B902B08D408880001160085480071008640A00560648060000C70
       VCID: 74E7982AD70D83817A7-8021
       Component: RLS 031111 05  54  0403
       Coding: 22300A
                        Fault Status: 00101010
                        Reset counter: 174
                        Mileage: 36078 km
                        Date: 2015.05.16
                        Time: 15:35:22
                            Term 15 On
                        Voltage: 13.30 V
       Part No SW: 5C0 959 655     HW: 5C0 959 655
       Component: AirbagVW10G   013 0809
       Serial number: 003ENM00SZ1/
       Coding: 00003548
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: 6FED9746B62BA059875-803A
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y110000954X0K
       Coding: 30324D
       Serial number: 3572MSME20153164ZZZF
       Serial number: 3582MSME5F6A6365ZZZ7
       Serial number: 3516KSME5B515F15ZZZ.
       Serial number: 3526KSME0B5B4615ZZZX
       Serial number: 3556LSME1C125111ZZZI
       Serial number: 3566LSME17295111ZZZM
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110409100468
       Coding: 088A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76E3A222C9719191443-8023
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Component: E221__MFL-YVJ  H06 0022
       Coding: E20000
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 167
    136194 - Supply voltage
                        Reset counter: 167
       Part No SW: 561 920 970 C    HW: 561 920 970 C
       Component: KOMBI         H07 0507
       Coding: 231E01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
       VCID: 1A3B96921D2915F180B-804F
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 24111101290902
       Coding: 461000
       VCID: 3D717D0EA4C702C9459-8068
       Component: IMMO          H07 0507
       VCID: 6ADB86528DC94571D0B-803F
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Revision: A1001003    Serial number: 7660974205
       Coding: 020000
       VCID: 2959B95E404F8E69191-807C
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H33 0265
       Serial number: VWZAZ2L8479950
       Coding: 0400042104000B0000008000
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2345AB762A63543953D-8076
       Subsystem 1 - Part No: 3AA 919 866 B
       Component: NAR_V2  0002
    1048578 - Supply voltage
                        Reset counter: 167
                        Mileage: 35908 km
                        Date: 2015.05.09
                        Time: 14:44:47
    1048580 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 167
                        Mileage: 35908 km
                        Date: 2015.05.09
                        Time: 14:44:47
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0003710839
       Coding: 0404F5
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BB5D39652932CF95BD-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  004 4472
       Coding: 800000
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Reset counter: 177
                        Mileage: 36240 km
                        Date: 2015.05.17
                        Time: 17:14:36
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Reset counter: 155
                        Mileage: 35858 km
                        Date: 2015.02.04
                        Time: 19:11:21
              B11EE 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 168
       Part No: 1K0 909 144 N
       Component: EPS_ZFLS Kl. 290    3301
       Revision: 00H22000
       VCID: 3561652E5CF7DA898D9-8060
    Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
       Component: EZE_2         H40 1623
       Coding: 01030108
       VCID: 6FED9746BE2BA059875-803A
       Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
       Component: J245 P05 FFD7  H07 0004
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0004
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0003440947
       Coding: 0404F4
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CB7D08A579D2BC1527-8009
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  004 4472
       Coding: 800000
                        Reset counter: 168
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007661192881
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: EV_UHVNA.rod
       VCID: 275DBF665E5BB8190F5-8072
    End-------------------------(Elapsed Time: 03:03)--------------------------
    There's a bug in the current dataset for that ECU that prevents VCDS from properly identifying that fault code. This should be fixed with the next dataset.
    In the meanwhile, it means:
    15733 - SCR NOx Catalyst Bank 1
    P20EE 00 [096] - Efficiency too Low
    And it's been discuseed at some length here.
  3. Likes Dana, Jack@European_Parts liked this post
    Stoke on Trent, England
    Uwe is that for 15733 - ROD - Unknown Error Code as I've seen a lot of ROD - Unknown Error Code with different numbers on here?
    I have 23 codes in my database for this 0021/4224/5603/8835/8842/8844/0393/0900/0913/0922/0943/0981/0983/0987/1048/1049/15604/15733/0364/18627/18640/18643/18644 all taken of here.
    New User Keith
    "ROD - Unknown Error Code" means VCDS couldn't find that code in the control-module specific "dictionary". Bear in mind that the raw fault code numbers coming from many modules that use UDS do not fit any standard pattern, so 12345 coming from one UDS module could mean something entirely different than 12345 coming from a different module.
  6. Likes Sebastian, Fredrick Awuor liked this post
    May 2015
    Awesome. Thank you.
    I did see that post but I wasn't too sure.
    I'll try to remove sensor and torch the bugger....
  8. Likes Uwe liked this post
  9. #6
    Oct 2018
    Romania
    Quote Originally Posted by mb2vw View Post
    Awesome. Thank you.
    Hello!
    Please excuse me if I am being a little offtopic, but I have a similar error message on my Auto-Trans gearbox and I do not know what it means?
    Can you please help? Thank you!
    Part No SW: 0DL 300 043 T HW: 0GC 927 711 G
    Component: TVS DQ500 H06 9999
    Revision: 00H06V07
    ROD: EV_TCMDQ500021.rod
    VCID: 3E263775A0FFCE77AC1-806A
    10908 - ROD - Unknown Error Code
    - 00 [040]
    Mileage: 25922 km
    Date: 2019.03.07
    Time: 13:01:01
    Engine speed: 1113.00 /min
    Coolant temperature: 88 C
    Clutch: primary stat: Neutral
    selected gear: GANG_R
    Driving position: P
    Engine torque: -16 Nm
    Control Module temperature: 72 C
    Accelerator position: 14.8 %
    DTC memory status: 50
