Page 9 of 19 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 185
Thread: HVAC IN HELL please save me from heat :-) 2010 B8
  1. #81
    May 2015
    Due to extreme heat around here, I went ahead and made an appt with AUDI for diagnostics tomorrow at 1pm, we REALLY hope we can figure this out, or at least narrow it down ourselves before then. But it is just to hot and dangerous and costing me work time to not have AC in the car.
    I took off today to focus just on this.
    So I am open to truly any and all ideas (and as always am beyond appreciative for all of the time and research you all have graciously given us!)
  2. #82
    Next time you're measuring, try to get a more precise reading. Also, was the car running? When you say "about 11" I take that to mean anything between 10.5 and 11.5. At the low end, that could mean a defective/high resistance wiring run. At the high end, that could just be a normal reading with the ignition on and a mildly low battery.
    ALWAYS USE UNITS
    Unless you're a Bosch firmware engineer of course
    I show "4H0 959 126" to be the factory part for your car, which is indeed what that eBay auction lists. PL24 shows that particular part as discontinued, as do some other sources, but refuse to admit what the new part number is for me. RT and/or your dealer may have better data sources.
    4H0 959 126 A is the new part, since 2013.
    Edit: they even give you a low res pic of the new one:
  3. #83
    Is it possible that if the G395 we got off ebay is not actually that part number that it claims,that it could be the entire reason the fault codes and the AC being inoperable are happening? Like if it just sends pressure signal instead of the exact CAN or digital wave signal the J519 wants to see, that it could be the entire reason?
    Absolutely Yes
    Please verify the wire can carry the current from fuse 12 to sensor and from ground at sensor to ground using the meter....... measuring........ with an appropriate watt/load bulb for the current track.
  4. Likes B82010 liked this post
  5. #84
    May 2015
    Here are the control module maps Dana had asked for/mentioned might help
    ;SW:8T1-820-043-AQ   HW:8T1-820-043-AQ ---  Auto HVAC
    ;Component:KLIMA 3 ZONEN H08 0171, Coding:64102000
    ;Wednesday,03,June,2015,17:09:52:07369
    ;VCDS Version: Release 14.10.2 (x64)  Data version: 20150311
    ;VCID: 000FC94C931FCA216EF-8055
    1,0,,
    1,1,,,
    ;0.000 A,Current,
    1,2,,,
    ;0.000 A,Current,
    1,3,,,
    1,4,,,
    ;ERROR, ,
    2,0,,
    2,1,,,
    ;5.0,(no units),
    2,2,,,
    ;0.0,(no units),
    2,3,,,
    ;0.0,(no units),
    2,4,,,
    ;0.0,(no units),
    3,0,,
    3,1,,,
    ;0.0,(no units),
    3,2,,,
    ;0.0,(no units),
    3,3,,,
    ;0.0,(no units),
    3,4,,,
    4,0,,
    4,1,,,
    ;10000,Count,
    4,2,,,
    ;10000,Count,
    4,3,,,
    ;10000,Count,
    4,4,,,
    ;11917,Count,
    5,0,,
    5,1,,,
    ;00000101,Bin. Bits,
    5,2,,,
    ;00000000,Bin. Bits,
    5,3,,,
    ;00001011,Bin. Bits,
    5,4,,,
    ;0.0 %,Load,
    6,0,,
    6,1,,,
    ;10000,Count,
    6,2,,,
    ;10000,Count,
    6,3,,,
    ;10000,Count,
    6,4,,,
    ;11233,Count,
    7,0,,
    7,1,,,
    ;00111101,Bin. Bits,
    7,2,,,
    7,3,,,
    ;10000011,Bin. Bits,
    7,4,,,
    ;0.0 %,Load,
    8,0,,
    8,1,,,
    ;11629,Count,
    8,2,,,
    ;11629,Count,
    8,3,,,
    ;10000,Count,
    8,4,,,
    ;11629,Count,
    9,0,,
    9,1,,,
    9,2,,,
    9,3,,,
    ;00001001,Bin. Bits,
    9,4,,,
    ;100.0 %,Load,
    10,0,,
    10,1,,,
    ;14373,Count,
    10,2,,,
    ;14373,Count,
    10,3,,,
    ;10000,Count,
    10,4,,,
    ;15831,Count,
    11,0,,
    11,1,,,
    11,2,,,
    11,3,,,
    ;10001001,Bin. Bits,
    11,4,,,
    ;74.5 %,Load,
    12,0,,
    12,1,,,
    ;14368,Count,
    12,2,,,
    ;14368,Count,
    12,3,,,
    ;10000,Count,
    12,4,,,
    ;15825,Count,
    13,0,,
    13,1,,,
    13,2,,,
    13,3,,,
    ;10000001,Bin. Bits,
    13,4,,,
    ;74.5 %,Load,
    14,0,,
    14,1,,,
    ;13372,Count,
    14,2,,,
    ;13372,Count,
    14,3,,,
    ;10000,Count,
    14,4,,,
    ;14216,Count,
    15,0,,
    15,1,,,
    15,2,,,
    15,3,,,
    15,4,,,
    ;79.5 %,Load,
    16,0,,
    16,1,,,
    ;13339,Count,
    16,2,,,
    ;13339,Count,
    16,3,,,
    ;10000,Count,
    16,4,,,
    ;14174,Count,
    17,0,,
    17,1,,,
    17,2,,,
    17,3,,,
    17,4,,,
    ;79.5 %,Load,
    18,0,,
    18,1,,,
    ;10000,Count,
    18,2,,,
    ;10000,Count,
    18,3,,,
    ;10000,Count,
    18,4,,,
    ;11329,Count,
    19,0,,
    19,1,,,
    19,2,,,
    19,3,,,
    ;00000111,Bin. Bits,
    19,4,,,
    ;0.0 %,Load,
    20,0,,
    20,1,,,
    ;10000,Count,
    20,2,,,
    ;10000,Count,
    20,3,,,
    ;10000,Count,
    20,4,,,
    ;11319,Count,
    21,0,,
    21,1,,,
    21,2,,,
    21,3,,,
    ;00001111,Bin. Bits,
    21,4,,,
    ;0.0 %,Load,
    22,0,,
    22,1,,,
    ;10000,Count,
    22,2,,,
    ;10000,Count,
    22,3,,,
    ;10000,Count,
    22,4,,,
    ;11197,Count,
    23,0,,
    23,1,,,
    23,2,,,
    23,3,,,
    23,4,,,
    ;0.0 %,Load,
    24,0,,
    24,1,,,
    ;98,Count,
    24,2,,,
    ;0,Count,
    24,3,,,
    ;0,Count,
    24,4,,,
    ;0,Count,
    32,0,,
    32,1,,,
    ;5.00 V,Voltage,
    32,2,,,
    ;11.70 V,Voltage,
    32,3,,,
    ;0.40 V,Voltage,
    32,4,,,
    ;0.025 A,Current,
    33,0,,
    33,1,,,
    ;0.00 s,Time,
    33,2,,,
    33,3,,,
    33,4,,,
    34,0,,
    34,1,,,
    ;29.0C,Temperature,
    34,2,,,
    ;27.0C,Temperature,
    34,3,,,
    ;27.0C,Temperature,
    34,4,,,
    ;25.0C,Temperature,
    35,0,,
    35,1,,,
    ;36.0C,Temperature,
    35,2,,,
    35,3,,,
    ;23.0C,Temperature,
    35,4,,,
    36,0,,
    36,1,,,
    ;23.0C,Temperature,
    36,2,,,
    ;3056 /min,RPM,
    36,3,,,
    ;78.0C,Temperature,
    36,4,,,
    ;OFF, ,
    37,0,,
    37,1,,,
    ;0 /min,RPM,
    37,2,,,
    ;0.0 km/h,Speed,
    37,3,,,
    ;0.0,(no units),
    37,4,,,
    ;0.0 Nm,Torque,
    38,0,,
    38,1,,,
    38,2,,,
    38,3,,,
    ;253.00 %, ,
    38,4,,,
    ;0.0 %,Load,
    39,0,,
    39,1,,,
    ;0.0 %,Load,
    39,2,,,
    39,3,,,
    ;0.0,(no units),
    39,4,,,
    ;50.0,(no units),
    41,0,,
    41,1,,,
    ;ERROR, ,
    41,2,,,
    ;300 W,Output,
    41,3,,,
    ;ERROR, ,
    41,4,,,
    ;300 W,Output,
    42,0,,
    42,1,,,
    ;ON, ,
    42,2,,,
    ;ON, ,
    42,3,,,
    ;not available, ,
    42,4,,,
    ;11.90 V,Voltage,
    43,0,,
    43,1,,,
    ;00:36,Clock,
    43,2,,,
    ;   00000,Bin. Bits,
    43,3,,,
    43,4,,,
    44,0,,
    44,1,,,
    ;0.0,(no units),
    44,2,,,
    ;not reduced, ,
    44,3,,,
    ;not available, ,
    44,4,,,
    45,0,,
    45,1,,,
    ;0.0,(no units),
    45,2,,,
    ;not reduced, ,
    45,3,,,
    ;not available, ,
    45,4,,,
    46,0,,
    46,1,,,
    ;     000,Bin. Bits,
    46,2,,,
    ;2.0,(no units),
    46,3,,,
    ;2.0,(no units),
    46,4,,,
    47,0,,
    47,1,,,
    ;not available, ,
    47,2,,,
    47,3,,,
    47,4,,,
    48,0,,
    48,1,,,
    ;not available, ,
    48,2,,,
    ;not available, ,
    48,3,,,
    ;OFF, ,
    48,4,,,
    ;not available, ,
    49,0,,
    49,1,,,
    ;not available, ,
    49,2,,,
    ;not available, ,
    49,3,,,
    49,4,,,
    ;not available, ,
    50,0,,
    50,1,,,
    ;not available, ,
    50,2,,,
    ;00:36,Clock,
    50,3,,,
    ;0.0C,Temperature,
    50,4,,,
    ;0.0C,Temperature,
    52,0,,
    52,1,,,
    ;1,Count,
    52,2,,,
    ;1,Count,
    52,3,,,
    ;1.0,(no units),
    52,4,,,
    53,0,,
    53,1,,,
    ;0.0,(no units),
    53,2,,,
    ;0 W,Output,
    53,3,,,
    ;0.0,(no units),
    53,4,,,
    ;      00,Bin. Bits,
    54,0,,
    54,1,,,
    ;0.0,(no units),
    54,2,,,
    ;0.0,(no units),
    54,3,,,
    54,4,,,
    55,0,,
    55,1,,,
    ;0.0,(no units),
    55,2,,,
    55,3,,,
    55,4,,,
    56,0,,
    56,1,,,
    ;ERROR, ,
    56,2,,,
    ;ERROR, ,
    56,3,,,
    56,4,,,
    57,0,,
    57,1,,,
    ;0.0,(no units),
    57,2,,,
    57,3,,,
    57,4,,,
    58,0,,
    58,1,,,
    ;0.0,(no units),
    58,2,,,
    ;3.0,(no units),
    58,3,,,
    ;476,Count,
    58,4,,,
    ;721,Count,
    59,0,,
    59,1,,,
    ;12.0C,Temperature,
    59,2,,,
    ;31.0 %,Load,
    59,3,,,
    ;32.0C,Temperature,
    59,4,,,
    ;27.0C,Temperature,
    60,0,,
    60,1,,,
    ;OFF, ,
    60,2,,,
    ;1.0,(no units),
    60,3,,,
    60,4,,,
    63,0,,
    63,1,,,
    ;7.0,(no units),
    63,2,,,
    ;Not Installed, ,
    63,3,,,
    ;7.0,(no units),
    63,4,,,
    ;Not Installed, ,
    64,0,,
    64,1,,,
    ;not available, ,
    64,2,,,
    ;not available, ,
    64,3,,,
    64,4,,,
    65,0,,
    65,1,,,
    65,2,,,
    65,3,,,
    ;29.0C,Temperature,
    65,4,,,
    66,0,,
    66,1,,,
    ;0.000 A,Current,
    66,2,,,
    66,3,,,
    ;0.00 V,Voltage,
    66,4,,,
    ;25.10 V,Voltage,
    76,0,,
    76,1,,,
    76,2,,,
    76,3,,,
    ;0.0,(no units),
    76,4,,,
    ;0.0,(no units),
    77,0,,
    77,1,,,
    ;011000,Bin. Bits,
    78,0,,
    78,1,,,
    ;-128.0C,Temperature,
    78,2,,,
    78,3,,,
    78,4,,,
    79,0,,
    79,1,,,
    ;0.0,(no units),
    79,2,,,
    ;0,Count,
    79,3,,,
    ;00000010,Bin. Bits,
    79,4,,,
    ;0,Count,
    80,0,,
    80,1,,,
    ;534,Count,
    80,2,,,
    ;197 h,ON Time,
    80,3,,,
    80,4,,,
    81,0,,
    81,1,,,
    ;180,Count,
    81,2,,,
    ;843,Count,
    81,3,,,
    ;0,Count,
    81,4,,,
    ;5,Count,
    82,0,,
    82,1,,,
    ;117,Count,
    82,2,,,
    ;not available, ,
    82,3,,,
    ;not available, ,
    82,4,,,
    ;7259,Count,
    83,0,,
    83,1,,,
    ;01100100,Bin. Bits,
    83,2,,,
    ;00010000,Bin. Bits,
    83,3,,,
    ;00100000,Bin. Bits,
    83,4,,,
    85,0,,
    85,1,,,
    ;0.0,(no units),
    85,2,,,
    ;0.0,(no units),
    85,3,,,
    ;0.0,(no units),
    85,4,,,
    86,0,,
    86,1,,,
    ;608 /min,RPM,
    86,2,,,
    ;624 /min,RPM,
    86,3,,,
    ;640 /min,RPM,
    86,4,,,
    ;00110000,Bin. Bits,
    87,0,,
    87,1,,,
    ;0.0,(no units),
    87,2,,,
    ;0 /min,RPM,
    87,3,,,
    ;0.0 bar,Absolute Pres.,
    87,4,,,
    88,0,,
    88,1,,,
    ;Valid, ,
    88,2,,,
    ;0,Count,
    88,3,,,
    88,4,,,
    89,0,,
    89,1,,,
    ;not available, ,
    89,2,,,
    ;not available, ,
    89,3,,,
    ;not available, ,
    89,4,,,
    ;not available, ,
    90,0,,
    90,1,,,
    ;Not Installed, ,
    90,2,,,
    ;Not Installed, ,
    90,3,,,
    ;Not Installed, ,
    90,4,,,
    91,0,,
    91,1,,,
    ;Not Installed, ,
    91,2,,,
    ;Not Installed, ,
    91,3,,,
    ;Not Installed, ,
    91,4,,,
    ;Not Installed, ,
    92,0,,
    92,1,,,
    ;Not Installed, ,
    92,2,,,
    ;Not Installed, ,
    92,3,,,
    ;Not Installed, ,
    92,4,,,
    93,0,,
    93,1,,,
    ;Not Installed, ,
    93,2,,,
    ;Not Installed, ,
    93,3,,,
    ;Not Installed, ,
    93,4,,,
    94,0,,
    94,1,,,
    ;Not Installed, ,
    94,2,,,
    ;Not Installed, ,
    94,3,,,
    ;Not Installed, ,
    94,4,,,
    95,0,,
    95,1,,,
    ;Not Installed, ,
    95,2,,,
    ;Not Installed, ,
    95,3,,,
    ;Not Installed, ,
    95,4,,,
    96,0,,
    96,1,,,
    ;Not Installed, ,
    96,2,,,
    ;Not Installed, ,
    96,3,,,
    ;Not Installed, ,
    96,4,,,
    97,0,,
    97,1,,,
    ;Not Installed, ,
    97,2,,,
    ;Not Installed, ,
    97,3,,,
    ;Not Installed, ,
    97,4,,,
    98,0,,
    98,1,,,
    ;Not Installed, ,
    98,2,,,
    ;Not Installed, ,
    98,3,,,
    ;Not Installed, ,
    98,4,,,
    99,0,,
    99,1,,,
    ;Not Installed, ,
    99,2,,,
    ;Not Installed, ,
    99,3,,,
    ;Not Installed, ,
    99,4,,,
    100,0,,
    100,1,,,
    ;_*__LO___LO__0__0___B___MU__MU_11000_1_ , ,
    101,0,,
    101,1,,,
    ;0___LO___LO__0__0___B___MU__MU_11000_1_ , ,
    102,0,,
    102,1,,,
    ;1*__LO___LO__0__0___B___MU__MU_11000_1_ , ,
    103,0,,
    103,1,,,
    ;not available, ,
    103,2,,,
    103,3,,,
    103,4,,,
    104,0,,
    104,1,,,
    ;2___72___72__0__0__-1__*A*_*A*_01000_1_ , ,
    105,0,,
    105,1,,,
    ;not available, ,
    105,2,,,
    105,3,,,
    105,4,,,
    106,0,,
    106,1,,,
    ;3___71___60__0__0__-4___MU_*A*_11000_0_ , ,
    107,0,,
    107,1,,,
    ;not available, ,
    107,2,,,
    107,3,,,
    107,4,,,
    108,0,,
    108,1,,,
    ;4__22,0_22,0_0__0___0__*A*_*A*_00000_0_ , ,
    109,0,,
    109,1,,,
    ;not available, ,
    109,2,,,
    109,3,,,
    109,4,,,
    110,0,,
    110,1,,,
    110,2,,,
    110,3,,,
    ;11001000,Bin. Bits,
    110,4,,,
    ;10000010,Bin. Bits,
    111,0,,
    111,1,,,
    ;not available, ,
    111,2,,,
    ;not available, ,
    111,3,,,
    ;not available, ,
    111,4,,,
    112,0,,
    112,1,,,
    ;51.5 %,Load,
    112,2,,,
    ;2.00,(no units),
    112,3,,,
    112,4,,,
    204,0,,
    204,1,,,
    204,2,,,
    204,3,,,
    204,4,,,
    ;N/A,,
    227,0,,
    227,1,,,
    227,2,,,
    227,3,,,
    227,4,,,
    ;N/A,,
    228,0,,
    228,1,,,
    228,2,,,
    228,3,,,
    228,4,,,
    ;N/A,,
    229,0,,
    229,1,,,
    229,2,,,
    229,3,,,
    229,4,,,
    ;N/A,,
    231,0,,
    231,1,,,
    231,2,,,
    231,3,,,
    231,4,,,
    ;N/A,,
    233,0,,
    233,1,,,
    233,2,,,
    233,3,,,
    233,4,,,
    ;N/A,,
    235,0,,
    235,1,,,
    235,2,,,
    235,3,,,
    235,4,,,
    ;N/A,,
    ;SW:8K0-907-063-P   HW:8K0-907-063-P ---  Cent. Elect.
    ;Component:BCM1 1.0      H25 0380, Coding:26001091063CAF010000080300003D0D0F1C520800010161000000
    ;Wednesday,03,June,2015,17:10:48:07369
    ;VCID: 3C777DBCBF776EC1727-8069
    1,0,,
    1,1,,,
    ;11.90 V,,
    1,2,,,
    ;11.90 V,,
    1,3,,,
    ;N/A,,
    1,4,,,
    ;N/A,,
    2,0,,
    2,1,,,
    ;11.90 V,,
    2,2,,,
    ;11.90 V,,
    2,3,,,
    ;11.90 V,,
    2,4,,,
    ;N/A,,
    3,0,,
    3,1,,,
    ;Inactive,,
    3,2,,,
    ;Inactive,,
    3,3,,,
    ;Inactive,,
    3,4,,,
    ;N/A,,
    4,0,,
    4,1,,,
    ;ON,,
    4,2,,,
    ;ON,,
    4,3,,,
    ;ON,,
    4,4,,,
    ;N/A,,
    5,0,,
    5,1,,,
    ;100.0 %,,
    5,2,,,
    5,3,,,
    ;N/A,,
    5,4,,,
    ;N/A,,
    6,0,,
    6,1,,,
    6,2,,,
    6,3,,,
    6,4,,,
    ;N/A,,
    7,0,,
    7,1,,,
    ;OFF,,
    7,2,,,
    ;1.0,,
    7,3,,,
    ;Not Oper.,,
    7,4,,,
    ;Not Oper.,,
    8,0,,
    8,1,,,
    ;97.0 %,,
    8,2,,,
    8,3,,,
    8,4,,,
    9,0,,
    9,1,,,
    ;100.0 %,,
    9,2,,,
    ;100.0 %,,
    9,3,,,
    ;0.0 %,,
    9,4,,,
    ;0.0 %,,
    10,0,,
    10,1,,,
    10,2,,,
    10,3,,,
    ;100.0 %,,
    10,4,,,
    ;100.0 %,,
    11,0,,
    11,1,,,
    ;OFF,,
    11,2,,,
    ;OFF,,
    11,3,,,
    ;0.0 %,,
    11,4,,,
    ;0.0 %,,
    12,0,,
    12,1,,,
    ;0.0 %,,
    12,2,,,
    ;100.0 %,,
    12,3,,,
    ;253.0,,
    12,4,,,
    ;234.0,,
    13,0,,
    13,1,,,
    ;OFF,,
    13,2,,,
    ;Not Oper.,,
    13,3,,,
    ;0.0 %,,
    13,4,,,
    ;0.0 %,,
    14,0,,
    14,1,,,
    14,2,,,
    14,3,,,
    ;0.0 %,,
    14,4,,,
    ;0.0 %,,
    15,0,,
    15,1,,,
    ;OFF,,
    15,2,,,
    15,3,,,
    15,4,,,
    ;N/A,,
    16,0,,
    16,1,,,
    ;0.0 %,,
    16,2,,,
    ;0.0 %,,
    16,3,,,
    ;0.0 %,,
    16,4,,,
    ;19.0 %,,
    17,0,,
    17,1,,,
    ;Not Oper.,,
    17,2,,,
    17,3,,,
    ;OFF,,
    17,4,,,
    18,0,,
    18,1,,,
    ;Stage Int.,,
    18,2,,,
    ;0x0001,,
    18,3,,,
    ;N/A,,
    18,4,,,
    ;N/A,,
    19,0,,
    19,1,,,
    ;OFF,,
    19,2,,,
    ;1063.0,,
    19,3,,,
    ;Reached,,
    19,4,,,
    20,0,,
    20,1,,,
    ;ON,,
    20,2,,,
    ;ON,,
    20,3,,,
    ;0.00 km/h,,
    20,4,,,
    ;Closed,,
    21,0,,
    21,1,,,
    ;0.0 %,,
    21,2,,,
    ;OFF,,
    21,3,,,
    ;Inactive,,
    21,4,,,
    ;N/A,,
    22,0,,
    22,1,,,
    ;ON,,
    22,2,,,
    ;Inactive,,
    22,3,,,
    ;31.0,,
    22,4,,,
    ;153.0,,
    23,0,,
    23,1,,,
    23,2,,,
    23,3,,,
    23,4,,,
    24,0,,
    24,1,,,
    ;Not Oper.,,
    24,2,,,
    ;0x0005,,
    24,3,,,
    ;Not Oper.,,
    24,4,,,
    ;255.0,,
    25,0,,
    25,1,,,
    ;Not Oper.,,
    25,2,,,
    ;OFF,,
    25,3,,,
    ;N/A,,
    25,4,,,
    ;N/A,,
    26,0,,
    26,1,,,
    ;0.0,,
    26,2,,,
    ;Not Oper.,,
    26,3,,,
    ;Not Oper.,,
    26,4,,,
    ;Not Oper.,,
    27,0,,
    27,1,,,
    ;Not Oper.,,
    27,2,,,
    ;0x0002,,
    27,3,,,
    ;Activated,,
    27,4,,,
    ;Full,,
    28,0,,
    28,1,,,
    ;Full,,
    28,2,,,
    ;Not Oper.,,
    28,3,,,
    ;Inactive,,
    28,4,,,
    ;Inactive,,
    29,0,,
    29,1,,,
    ;23.5C,,
    29,2,,,
    ;N/A,,
    29,3,,,
    ;N/A,,
    29,4,,,
    ;N/A,,
    30,0,,
    30,1,,,
    30,2,,,
    30,3,,,
    30,4,,,
    31,0,,
    31,1,,,
    ;Closed,,
    31,2,,,
    31,3,,,
    ;N/A,,
    31,4,,,
    ;N/A,,
    32,0,,
    32,1,,,
    ;Inactive,,
    32,2,,,
    ;Inactive,,
    32,3,,,
    ;N/A,,
    32,4,,,
    ;N/A,,
    33,0,,
    33,1,,,
    33,2,,,
    ;0.0 %,,
    33,3,,,
    ;0.0 %,,
    33,4,,,
    ;N/A,,
    34,0,,
    34,1,,,
    ;OFF,,
    34,2,,,
    ;0.0 mA,,
    34,3,,,
    ;0.0 %,,
    34,4,,,
    ;N/A,,
    37,0,,
    37,1,,,
    37,2,,,
    ;N/A,,
    37,3,,,
    ;N/A,,
    37,4,,,
    ;N/A,,
    40,0,,
    40,1,,,
    40,2,,,
    40,3,,,
    40,4,,,
    41,0,,
    41,1,,,
    41,2,,,
    41,3,,,
    41,4,,,
    42,0,,
    42,1,,,
    42,2,,,
    ;N/A,,
    42,3,,,
    ;N/A,,
    42,4,,,
    ;N/A,,
    43,0,,
    43,1,,,
    43,2,,,
    43,3,,,
    43,4,,,
    44,0,,
    44,1,,,
    44,2,,,
    44,3,,,
    44,4,,,
    45,0,,
    45,1,,,
    ;0.0,,
    45,2,,,
    ;0.00 km/h,,
    45,3,,,
    ;15.0,,
    45,4,,,
    ;N/A,,
    46,0,,
    46,1,,,
    ;OFF,,
    46,2,,,
    ;0.0 %,,
    46,3,,,
    ;N/A,,
    46,4,,,
    ;N/A,,
    47,0,,
    47,1,,,
    ;Elect. Regul.,,
    47,2,,,
    ;0.0 mA,,
    47,3,,,
    ;System OK,,
    47,4,,,
    ;N/A,,
    48,0,,
    48,1,,,
    ;0.0,,
    48,2,,,
    ;0.0,,
    48,3,,,
    ;0.0,,
    48,4,,,
    ;0.0,,
    49,0,,
    49,1,,,
    ;0380,,
    50,0,,
    50,1,,,
    ;182.40 s,,
    50,2,,,
    ;269.24 s,,
    50,3,,,
    ;3.39 s,,
    50,4,,,
    ;N/A,,
    51,0,,
    51,1,,,
    ;404.0,,
    51,2,,,
    ;0.0,,
    51,3,,,
    ;N/A,,
    51,4,,,
    ;N/A,,
    52,0,,
    52,1,,,
    ;52606-6994-55762 ,,
    53,0,,
    53,1,,,
    ;C5407063 0350,,
    54,0,,
    54,1,,,
    ;FBL-Version: 47532.1.2.45,,
    55,0,,
    55,1,,,
    ;0.0,,
    55,2,,,
    ;N/A,,
    55,3,,,
    ;N/A,,
    55,4,,,
    ;N/A,,
    56,0,,
    56,1,,,
    56,2,,,
    56,3,,,
    ;N/A,,
    56,4,,,
    ;N/A,,
    57,0,,
    57,1,,,
    57,2,,,
    57,3,,,
    57,4,,,
    ;N/A,,
    58,0,,
    58,1,,,
    ;0.0,,
    58,2,,,
    ;0.0,,
    58,3,,,
    58,4,,,
    59,0,,
    59,1,,,
    ;OFF,,
    59,2,,,
    ;OFF,,
    59,3,,,
    ;N/A,,
    59,4,,,
    ;N/A,,
    60,0,,
    60,1,,,
    ;0.0C,,
    60,2,,,
    ;24.5C,,
    60,3,,,
    ;0.0 A,,
    60,4,,,
    ;N/A,,
    61,0,,
    61,1,,,
    ;0.0C,,
    61,2,,,
    ;23.0C,,
    61,3,,,
    ;0.0 A,,
    61,4,,,
    ;N/A,,
    62,0,,
    62,1,,,
    ;0.0,,
    62,2,,,
    ;0x0000,,
    62,3,,,
    ;0.0,,
    62,4,,,
    ;0x0000,,
    63,0,,
    63,1,,,
    63,2,,,
    63,3,,,
    63,4,,,
    ;N/A,,
    64,0,,
    64,1,,,
    64,2,,,
    64,3,,,
    64,4,,,
    ;N/A,,
    65,0,,
    65,1,,,
    65,2,,,
    65,3,,,
    65,4,,,
    66,0,,
    66,1,,,
    66,2,,,
    66,3,,,
    ;N/A,,
    66,4,,,
    ;N/A,,
    67,0,,
    67,1,,,
    67,2,,,
    67,3,,,
    67,4,,,
    ;N/A,,
    68,0,,
    68,1,,,
    68,2,,,
    68,3,,,
    68,4,,,
    ;N/A,,
    69,0,,
    69,1,,,
    69,2,,,
    69,3,,,
    69,4,,,
    70,0,,
    70,1,,,
    70,2,,,
    70,3,,,
    70,4,,,
    71,0,,
    71,1,,,
    71,2,,,
    71,3,,,
    71,4,,,
    72,0,,
    72,1,,,
    72,2,,,
    72,3,,,
    72,4,,,
    73,0,,
    73,1,,,
    ;0.0,,
    73,2,,,
    ;0.0,,
    73,3,,,
    ;0.0,,
    73,4,,,
    ;0.0,,
    74,0,,
    74,1,,,
    ;0x0004,,
    74,2,,,
    ;0x0003,,
    74,3,,,
    74,4,,,
    75,0,,
    75,1,,,
    75,2,,,
    75,3,,,
    75,4,,,
    76,0,,
    76,1,,,
    76,2,,,
    76,3,,,
    76,4,,,
    77,0,,
    77,1,,,
    77,2,,,
    77,3,,,
    77,4,,,
    78,0,,
    78,1,,,
    78,2,,,
    78,3,,,
    78,4,,,
    79,0,,
    79,1,,,
    79,2,,,
    79,3,,,
    79,4,,,
    80,0,,
    80,1,,,
    80,2,,,
    80,3,,,
    80,4,,,
    81,0,,
    81,1,,,
    81,2,,,
    81,3,,,
    81,4,,,
    82,0,,
    82,1,,,
    82,2,,,
    82,3,,,
    82,4,,,
    83,0,,
    83,1,,,
    83,2,,,
    83,3,,,
    83,4,,,
    84,0,,
    84,1,,,
    84,2,,,
    84,3,,,
    84,4,,,
    85,0,,
    85,1,,,
    85,2,,,
    85,3,,,
    85,4,,,
    86,0,,
    86,1,,,
    86,2,,,
    86,3,,,
    86,4,,,
    87,0,,
    87,1,,,
    87,2,,,
    87,3,,,
    87,4,,,
    90,0,,
    90,1,,,
    ;0,,
    90,2,,,
    ;0,,
    90,3,,,
    ;68,,
    90,4,,,
    ;92,,
    91,0,,
    91,1,,,
    ;110,,
    91,2,,,
    ;0,,
    91,3,,,
    ;0,,
    91,4,,,
    ;255,,
    94,0,,
    94,1,,,
    ;184,,
    94,2,,,
    ;0,,
    94,3,,,
    ;0,,
    94,4,,,
    ;0,,
    95,0,,
    95,1,,,
    ;0,,
    95,2,,,
    ;0,,
    95,3,,,
    ;68,,
    95,4,,,
    ;0,,
    99,0,,
    99,1,,,
    ;0x000F,,
    99,2,,,
    ;0x0103,,
    99,3,,,
    ;0.0,,
    99,4,,,
    ;0.0,,
    100,0,,
    100,1,,,
    ;not available,,
    100,2,,,
    ;not available,,
    100,3,,,
    ;Occupied,,
    100,4,,,
    ;Not Occup.,,
    101,0,,
    101,1,,,
    ;90.0 %,,
    101,2,,,
    ;90.0 %,,
    101,3,,,
    ;0.0 %,,
    101,4,,,
    ;0.0 %,,
    102,0,,
    102,1,,,
    ;Intermed pos.,,
    102,2,,,
    ;Inactive,,
    102,3,,,
    ;not available,,
    102,4,,,
    ;not available,,
    103,0,,
    103,1,,,
    103,2,,,
    103,3,,,
    103,4,,,
    104,0,,
    104,1,,,
    104,2,,,
    104,3,,,
    104,4,,,
    105,0,,
    105,1,,,
    105,2,,,
    105,3,,,
    105,4,,,
    106,0,,
    106,1,,,
    106,2,,,
    106,3,,,
    106,4,,,
    107,0,,
    107,1,,,
    ;Stage 0,,
    107,2,,,
    ;Stage 0,,
    107,3,,,
    ;20.0C,,
    107,4,,,
    ;23.5C,,
    108,0,,
    108,1,,,
    ;0.0,,
    108,2,,,
    108,3,,,
    ;N/A,,
    108,4,,,
    ;N/A,,
    110,0,,
    110,1,,,
    110,2,,,
    110,3,,,
    110,4,,,
    111,0,,
    111,1,,,
    111,2,,,
    111,3,,,
    111,4,,,
    112,0,,
    112,1,,,
    112,2,,,
    112,3,,,
    112,4,,,
    113,0,,
    113,1,,,
    113,2,,,
    113,3,,,
    113,4,,,
    114,0,,
    114,1,,,
    114,2,,,
    114,3,,,
    114,4,,,
    115,0,,
    115,1,,,
    115,2,,,
    115,3,,,
    115,4,,,
    116,0,,
    116,1,,,
    116,2,,,
    116,3,,,
    116,4,,,
    117,0,,
    117,1,,,
    117,2,,,
    117,3,,,
    117,4,,,
    120,0,,
    120,1,,,
    120,2,,,
    120,3,,,
    120,4,,,
    ;N/A,,
    121,0,,
    121,1,,,
    121,2,,,
    121,3,,,
    121,4,,,
    122,0,,
    122,1,,,
    122,2,,,
    122,3,,,
    122,4,,,
    150,0,,
    150,1,,,
    ;34572.0,,
    150,2,,,
    ;34634.0,,
    150,3,,,
    ;34628.0,,
    150,4,,,
    ;34631.0,,
    151,0,,
    151,1,,,
    ;384.0,,
    151,2,,,
    ;434.0,,
    151,3,,,
    ;599.0,,
    151,4,,,
    ;62.0,,
    200,0,,
    200,1,,,
    200,2,,,
    200,3,,,
    200,4,,,
    201,0,,
    201,1,,,
    201,2,,,
    201,3,,,
    201,4,,,
    202,0,,
    202,1,,,
    202,2,,,
    202,3,,,
    202,4,,,
    203,0,,
    203,1,,,
    203,2,,,
    203,3,,,
    203,4,,,
    204,0,,
    204,1,,,
    204,2,,,
    204,3,,,
    204,4,,,
    205,0,,
    205,1,,,
    205,2,,,
    205,3,,,
    205,4,,,
    206,0,,
    206,1,,,
    206,2,,,
    206,3,,,
    206,4,,,
    207,0,,
    207,1,,,
    207,2,,,
    207,3,,,
    207,4,,,
    208,0,,
    208,1,,,
    208,2,,,
    208,3,,,
    208,4,,,
    209,0,,
    209,1,,,
    209,2,,,
    209,3,,,
    209,4,,,
    210,0,,
    210,1,,,
    210,2,,,
    210,3,,,
    210,4,,,
    211,0,,
    211,1,,,
    211,2,,,
    211,3,,,
    211,4,,,
    212,0,,
    212,1,,,
    212,2,,,
    212,3,,,
    212,4,,,
    213,0,,
    213,1,,,
    213,2,,,
    213,3,,,
    213,4,,,
    214,0,,
    214,1,,,
    214,2,,,
    214,3,,,
    214,4,,,
    215,0,,
    215,1,,,
    215,2,,,
    215,3,,,
    215,4,,,
    216,0,,
    216,1,,,
    216,2,,,
    216,3,,,
    216,4,,,
    217,0,,
    217,1,,,
    217,2,,,
    217,3,,,
    217,4,,,
    251,0,,
    251,1,,,
    ;0.0,,
    251,2,,,
    ;404.0,,
    251,3,,,
    ;0.0,,
    251,4,,,
    ;0.0,,
    252,0,,
    252,1,,,
    ;15.0,,
    252,2,,,
    ;0.0,,
    252,3,,,
    ;15.0,,
    252,4,,,
    ;0.0,,
  6. Likes Uwe liked this post
  7. #85
    May 2015
    And did we ever figure out what the error is in the MVB 01?
    Wednesday,03,June,2015,17:23:27:07369
    VCDS Version: 14.10.2.0 (x64)
                    Address 08: Auto HVAC  (8T1 820 043 AQ)
    17:23:26 Group 001
      0.000 A  Current
      0.000 A  Current
      ERROR
    17:23:26 Group 002
      13.0  (no units)
      12.0  (no units)
      7.0  (no units)
      5.0  (no units)
    17:23:26 Group 013
      00111101  Bin. Bits
      00000000  Bin. Bits
      10000001  Bin. Bits
      74.5 %  Load
  8. #86
    Quote Originally Posted by B82010 View Post
    Group 001 would be:
    1. Compressor Current (Specified Value)
    2. Compressor Current (Actual Value)
    3. [empty]
    4. Refrigerant Pressure
    The module is aware it can't see the refrigerant pressure, so it flags that value as ERROR.
  9. Likes Sebastian, jyoung8607, B82010 liked this post
  10. #87
    May 2015
    FINNNAALLLYYYY have had the first breakthrough !
    Tried the Jump/overlay wire directly from the 3 sources to the existing wires themselves with no change.
    HOWEVER, I then took each of the overlay wires, stripped off the end, and slid each of the 3 wires into 1 of the 3 ports of the harness connector(so that when the connector was pushed together, it would have direct connection to the expose wire tips), one to the #12 fuse, the other to the chassis ground directly, and the other to a spliced LIN wire an inch away from J519.
    Turned on the car, Faults where there HOWEVER WHEN I CLEARED THEM through VCDS the compressor would kick on and blow cold for about 3 seconds, until the fault would come back
    Interestingly enough, while I had it configured that way, the air quality sensor would randomly throw a fault similar to the G395 no communication.... But when cleared it would go away after clearing once or twice.
    Looking into the ports of the connector is hard to see, but it does seem like there might be some distortion in the ports and perhaps even some residue of previous water getting into the connector.
    SOO my question is this, Should I go ahead and order a new connector (I found the part number) and throw it on and see if the entire communication error has been due to that connector being subpar.
    OR
    Should I keep my appt with AUDI tomorrow, just to have them first say (we need to change the connector before anything)
  11. Likes jyoung8607 liked this post
  12. #88
    May 2015
    I forgot that it threw this new code when I did the overlay wire into the connector setup. (this fault cleared and stayed away unlike the other 2 which kept returning after a few seconds/or backing out of the module and going back into it and scanning for faults again
    Address 09: Cent. Elect.       Labels: 8K0-907-063.clb
    Control Module Part Number: 8K0 907 063 P    HW: 8K0 907 063 P
      Component and/or Version: BCM1 1.0      H25 0380
               Software Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
                Work Shop Code: WSC 02391 823 56573
    03020 - Local databus 2
                        Fault Status: 00101100
                        Reset counter: 139
                        Mileage: 88099 km
                        Date: 2015.06.03
                        Time: 18:49:00
                        Reset counter: 99
                        Mileage: 88099 km
                        Date: 2015.06.03
                        Time: 18:49:00
    02258 - Door Opener Transmitter
                        Reset counter: 99
                        Mileage: 88099 km
                        Date: 2015.06.03
                        Time: 18:49:00
  13. #89
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Wouldn't hurt at all. Also, it wouldn't hurt to go ahead and repair that garage door transmitter connector. I don't have the WD for your car, so I can't say for sure, but it might share power, ground or LIN with those other devices. And it gets your garage door transmitter back.
    At this point, you know with very high probability that it's a wiring problem. You can fix that with money (at the dealer) or time (at home). It's entirely your choice.
    Jason
  14. Likes B82010, Uwe liked this post
  15. #90
    May 2015
    http://www.ebay.com/itm/AC-Pressure-...459002&vxp=mtr
    That is the AC connector.
    I certainly need a new Garage door opener connector as well, but it seems to be a 4 pin connector and the current connector AND harness for the garage door only has 3 wires, which makes me think either the 4th prong is just some other type of option OR there in fact was work done, and someone the entire 4th wire was removed (I traced the harness all the way up to the firewall and did not see any extra wires so liek you said without the WD it is hard to say
