Results 1 to 10 of 10
Thread: I need PIN key for coding ECU! Urgent, please
    Oct 2017
    Macedonia
    Exclamation I need PIN key for coding ECU! Urgent, please
    HELLO GUYS I NEED THE SECURITY ACCESS KEY TO DO CODING ON THIS VEHICLE !!
    I SWAPED THE ECU AND THE LONG CODING NOW IS 00000.. I HOPE ANYBODY CAN HELP ME !
    Tuesday,16,October,2018,21:11:03:42762
    VCDS Version: 18.9.0.2  HEX-NET CB: 0.4436.4
    VIN: WVGZZZ1TZCW117112   License Plate: TE-7932-AD
    Mileage: 361630km-224706mi   Repair Order:
    Chassis Type: 1T-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 25 37 3D 42 44 46 52 56 61 62 72
    VIN: WVGZZZ1TZCW117112   Mileage: 361630km-224706miles
    37-Navigation -- Status: Not registered 0011
    3D-Special Function -- Status: OK 0000
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 B    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H43 9971
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00000000000000000000
       ASAM Dataset: EV_ECM16TDI02103L906023B 003011
       ROD: EV_ECM16TDI02103L906023PA.rod
       VCID: A50285A7A4468C6206-80F0
    7461 - EGR Valve (N18)
              P0403 00 [101] - Malfunction
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:27:45
                        Engine speed: 780.75 /min
                        Normed load value: 36.1 %
                        Coolant temperature: 38 C
                        Intake air temperature: 22 C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 14.118 V
                        Accelerator position: normalized-Accelerator position: 0.00 %
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 7.001 %
                        EGR Solen.val.: actual value-ANG_EGRV[0]: 87.030 %
                        Air mass: actual value (mg/stroke)-MAF_MES: 346.874 mg/stroke
                        Sensor for engine block temperature: raw value-Coolant temperature: 38 C
    6548 - Engine Control Module Incorrectly Coded
              P1612 00 [101] - -
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:27:44
                        Engine speed: 780.25 /min
                        Normed load value: 36.5 %
                        Voltage terminal 30: 14.005 V
                        Coding in the engine control module-FRF_VARCOD: 4
                        Number of resets of main unit-CTR_RST_MC: 0
                        Control Module temperature-TECU: 30 C
    9857 - Engine Control Module Incorrectly Coded
              P1612 00 [165] - -
                        Time: 00:00:00
                        Voltage terminal 30: 0.000 V
                        Coding in the engine control module-FRF_VARCOD: 1
                        Control Module temperature-TECU: 19 C
    Readiness: 1110 1000
       Revision: 00H31001
       Coding: 323B401609230E014C0C02E5901B7041310000
       Shop #: WSC 29883 002 104857
       VCID: FBB683DF7A42EA9200-80AE
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:31:59
                        Count: 14
                        Count: 20992
                        Count: 8195
                        Count: 44800
                        Count: 1
                        Count: 65021
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:24:38
                        Count: 3
                        Count: 2
                        Count: 29184
                        Count: 8212
                        Count: 49920
                        Count: 1
                        Count: 65021
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001018
       Coding: 0000004002
       VCID: 804CF4331BA4894A55-80D4
       Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
       Component: BCM PQ35 B    021 0064
       Revision: BA021001
       Coding: 40180A38802100E0400000C0500000E4CB018E08F24DA520648042000040
       Shop #: WSC 03824 127 73028
       VCID: B73E5FEF06EA0EF2A4-80E2
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 19041  26  0512
       Coding: 009795
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:31:59
                            Term 15 On
                        Voltage: 12.65 V
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 03:31:59
                            Term 15 On
                        Voltage: 12.60 V
       Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
       Component: 02 AIRBAG VW8   022 0100
       Revision: 02022000    Serial number: 003K4D06E78W
       Coding: 0012338
       VCID: B73E5FEFC6EA0EF2A4-80E2
       Subsystem 1 - Serial number: 6332QSME59121C56G
       Subsystem 2 - Serial number: 6342QSME501205683
       Subsystem 3 - Serial number: 6352QSME431143687
       Subsystem 4 - Serial number: 6362QSME441128525
       Part No SW: 5K0 953 501 AN    HW: 5K0 953 569 F
       Revision: FF010041    Serial number: 20120423101251
       Coding: 5180040000
       VCID: F6A092EB4960B7FA7F-80A2
       Part No SW: 1T0 920 865 A    HW: 1T0 920 865 A
       Component: KOMBI         H04 0606
       Coding: 180D00
       VCID: B42468E31F9CE5EA81-80E0
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 C
       Component: Zuheizer        051 2730
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000011
       Shop #: WSC 38156 123 104340
       VCID: B42468E3D79CE5EA81-80E0
    01410 - Heater Over-Temp
                000 -  -
                        Reset counter: 125
                            After-Run
                        Temperature: 145.0C
                        Temperature: -48.0C
                        Voltage: 13.01 V
    02251 - Heater Unit Locked
                000 -  -
                        Reset counter: 125
       Part No SW: 7N0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway H43 1623
       Revision:   H43       Serial number: 230412F2003034
       Coding: 352002
       VCID: BB3643DF3AC22A9240-80EE
                000 -  -
                        Fault Frequency: 15
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:48
       Component: IMMO          H04 0606
       VCID: EA98B69B0DD8631AEB-80BE
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3319252
       Coding: 000004310400000000021000
       Shop #: WSC 01324 020 00200
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: E08CD4B3FBE4294A35-80B4
    1048595 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
              [woofer rear left open load]
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:51
    1048596 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
              [woofer rear right open load]
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:51
    1048599 - Rear Left Treble Speaker
              B1066 13 [009] - Open Circuit
              [tweeter rear left open load]
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:51
    1048600 - Rear Right Treble Speaker
              B1068 13 [009] - Open Circuit
              [tweeter rear right open load]
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:51
    1048634 - Antenna 2 for radio
              B111A 13 [009] - Open Circuit
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:49
    1048582 - GPS Antenna
              B1054 13 [009] - Open Circuit
              [GPS antenna open load]
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.16
                        Time: 00:00:49
    Address 3D: Special Function (J608)       Labels: None
       Part No SW: 5K0 907 427 B    HW: 5K0 907 427 B
       Component: MFG II        005 0003
       Revision: S0005000    Serial number: 00000000012270
       Coding: 0101010001000000000000000000000000
       VCID: AF2E678FFEBAC632FC-80FA
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2121
       Coding: 0000181
       VCID: C8DC2C13BB14710ADD-809C
       Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.083 0401
       Revision: 1AH02234    Serial number: 00081630085702
       Coding: 0000258
       Shop #: WSC 05311 321 54321
       VCID: B62052EBC1E0F7FABF-80E2
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 35
                            Term 15 On
                        (no units): 4.0
                        Voltage: 12.30 V
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000181
       VCID: C7DE2F2FB60A7E72D4-8092
       Component: Batt.regelung H43 1623
       Coding: 01041859
       VCID: F1AAA1F7280E90C2AA-80A4
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Component: Tuer-SG         007 2104
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: B2286EFB2D88EBDA93-80E6
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: B3266BFFD292E2D298-80E6
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
    Jun 2014
    no need any PIN code for coding, simple copy old one
    Pin isn't needed for coding, just read coding from old ECU.
    00114016030400080000
    00114014032401080000
    00114034032401080000
    00114016002400080000
  4. Likes iichel liked this post
    Oct 2017
    Macedonia
    It dosent code like that . Coding rejected says!!
    Oct 2017
    Macedonia
    It says coding rejected out of range !!
    Install old ecu and post the data.......
    Jun 2014
    Quote Originally Posted by besir707 View Post
    because you try code options not supporting by ECU, that is why is rejected
    or better tell what you swap that ECU, what is a reason
    I can see that CAYC engine in your Touran was build with 6 gear box
    your ECU is for Jetta / golf , which support 5 gear box only
    perhaps this is a reason your new ECU reject coding
    Anyway - next time post all info, inc old ECU number, and dont use CAPITAl letters - it not help at all
  9. Likes Uwe, Jack@European_Parts, Dana liked this post
  10. #8
    Oct 2017
    Macedonia
    I swaped the ecu because the old ecu is broken it gives me always the Valve for Fuel Metering (N290) every time the valve itself its good i checked the wires are good too for this way i changed the ecu . And on the car has been working a lot they have changed the transsmision from dsg to manual 5 speed .
    Here is the auto scan from old ecu
    Wednesday,17,October,2018,08:31:41:42762
    VIN: WVGZZZ1TZCW117112   License Plate: ORG ECU
       Part No SW: 03L 906 023 PJ    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9978
       Coding: 00254014030400080000
       ASAM Dataset: EV_ECM16TDI02103L906023PJ 003009
       ROD: EV_ECM16TDI02103L906023NB.rod
       VCID: FDB28DC76C56E4A23E-80A8
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:08
                        Engine speed: 797.25 /min
                        Normed load value: 34.9 %
                        Coolant temperature: 22 C
                        Voltage terminal 30: 12.311 V
                        EGR Solen.val.: actual value-ANG_EGRV[0]: 86.652 %
                        Air mass: actual value (mg/stroke)-MAF_MES: 197.027 mg/stroke
                        Sensor for engine block temperature: raw value-Coolant temperature: 21 C
    6088 - No Communication with Transmission Control Module
              U0101 00 [165] - -
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:00:51
                        Voltage terminal 30: 12.988 V
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 13 C
    10231 - Valve for Fuel Metering (N290)
              P0090 00 [165] - Open Circuit
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:00:51
                        Battery voltage: 12.1 V
                        Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.076 A
                        Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
                        Fuel Pressure Regulator Valve-PCV: 0.000 %
                        Fuel Metering Valve-VCV: 0.000 %
                        Fuel high pressure: actual value-FUP_FIL: 0.000 MPa
       Revision: 00H31001
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:54
                        Count: 2
                        Count: 20992
                        Count: 8212
                        Count: 43776
                        Count: 65021
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 10:47:30
                        Count: 14
                        Count: 20992
                        Count: 8195
                        Count: 43776
                        Count: 1
                        Count: 65021
       Revision: 00001018
       Coding: 0000004002
       Revision: BA021001
       Coding: 009795
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:05:27
                            Term 15 On
                        Voltage: 12.10 V
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:05:28
                            Term 15 On
                        Voltage: 12.10 V
       Coding: 0012338
       Coding: 5180040000
       Coding: 180D00
       Coding: 0000011
                000 -  -
                        Reset counter: 125
                            After-Run
                        Temperature: 145.0C
                        Temperature: -48.0C
                        Voltage: 13.01 V
                000 -  -
                        Reset counter: 125
       Coding: 352002
                000 -  -
                        Fault Frequency: 7
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:54
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:58
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:58
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:59
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:59
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:55
                        Reset counter: 35
                        Mileage: 361639 km
                        Date: 2018.10.17
                        Time: 00:01:55
       Coding: 0000181
       Coding: 0000258
                        Reset counter: 35
                            Term 15 On
                        (no units): 4.0
                        Voltage: 12.30 V
       Coding: 0000181
       Coding: 01041859
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:14, VBatt start/end: 12.3V/12.3V)-----------
  11. #9
    Oct 2017
    Macedonia
    It accepted the coding you give . THANKS to much i really appreciate it
  12. #10
    BASE Hardware abstract is different just an FYI!
  13. Likes Dana liked this post
