HVAC IN HELL please save me from heat :-) 2010 B8
B82010
C?ID=248569
Hey fellas-
Im new to the forum but not the car world, I am extremely excited to have my VAGCOM finally but NEED HELP PLEASE!
Ac is not working AT ALL.
replaced the g395 pressure sensor (but wondering if they sent me a generic sensor and not a true oem, hence still getting the Implausible signal)
When i ran the individual component checks, THE AC DID BLOW COLD WHEN THE N280 VALVE SAW CURRENT.
Please please can anyone help?
I know there is a TSB on this issue, which is what originally led me to change the pressure sensor.
Also I did have the system pumped(not flushed just dumped) and refilled with the computerized machine to Audi specs.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Saturday,30,May,2015,19:16:56:07369
Chassis Type: FL (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUEFAFL0AN047123   Mileage: 87960km-54655miles
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Component: 2.0l R4/4V TF H16 0001
   Revision: E1H16---
   Coding: 0104010A02070160
   Shop #: WSC 05136 444 12160
   VCID: 79F9A4A8F8C59BE9291-802C
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K1 927 155 J    HW: 0AW 927 156 H
   Component: 0AW 20TAVSUSA H04 0003
   Revision: --H04---    Serial number: 0000000118
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMVL381 A02017
   ROD: EV_TCMVL381_AU48.rod
   VCID: 3B757EA0B27969F97BD-806E
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
   Component: ESP8 front    H04 0010
   Coding: 080D18
   Shop #: WSC 02391 823 56573
   VCID: 0C17ED7CAF579E41027-8059
                    Reset counter: 92
                    Mileage: 87961 km
                    Date: 2015.05.30
                    Time: 17:30:26
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0035
                    Hex Value: 0x4097
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0327
   Coding: 090100
   Shop #: WSC 02399 823 56573
   VCID: 78FFA1ACCBCF82E156F-802D
   Subsystem 1 - Part No SW: 8T0 959 754 G    HW: 8T0 959 754 G
   Component: FBSAUDIB8 IDG  H61 0072
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01150120101817
   Coding: 64102000
   VCID: 000FC94C931FCA216EF-8055
00256 - A/C Pressure/Temperature Sensor (G395)
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 92
                    Mileage: 87962 km
                    Date: 2015.05.30
                    Time: 19:09:54
                    Temperature: 31.0°C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 92
                    Mileage: 87962 km
                    Date: 2015.05.30
                    Time: 19:09:54
00797 - Sunlight Photo Sensor (G107)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 92
                    Mileage: 87962 km
                    Date: 2015.05.30
                    Time: 19:09:55
                    Temperature: 33.0°C
                    Temperature: 31.0°C
                    Output: 300 W
                    Output: 300 W
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000559680
   Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
   VCID: 3C777DBCBF776EC1727-8069
   Component: WWS 140110  H06 0070
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
                    Reset counter: 92
                    Mileage: 87960 km
                    Date: 2015.05.30
                    Time: 17:11:00
02258 - Door Opener Transmitter
                    Reset counter: 92
                    Mileage: 87960 km
                    Date: 2015.05.30
                    Time: 17:11:00
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51291001503758
   Coding: 200103
   VCID: 479D1250F6B13D19EF5-8012
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EGD05F4F%
   Shop #: WSC 02135 785 00200
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 428B0344D593183138B-8017
   Serial number: 5810000R0900005WDS
   Serial number: 6334MSME4E420E15H
   Serial number: 6344MSME4F32416CL
   Serial number: 6352QSME624C5322D
   Serial number: 6362QSME734B3A28Q
   Serial number: 63732SME5B4A0F067
   Serial number: 63832SME1B4A040E1
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90304JAI000DU
   Coding: 000036
   VCID: 3D7170B8A46D67C9459-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 M    HW: 8K0 920 980 M
   Component: KOMBIINSTR.   H20 0255
   Revision: 00100000    Serial number: CIX33131A
   Coding: 8B1609000300D705020000
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E101128020
   Coding: 00C303
   VCID: 52AB33040DF388B188B-8007
   Component: J367-BDM  H07 0170
                    Reset counter: 92
                    Mileage: 87962 km
                    Date: 2015.05.30
                    Time: 19:13:14
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009905426
   Coding: 011C03204000410001
   VCID: 45811858CCBD2F091D9-8010
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0125749502
   Coding: 0106023A007A440400B0013200000000
   Component: GTO BF  H06 0050
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS045  H07 0041
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009932986
   VCID: 4487055CC78716010A7-8011
   Revision: 00000003    Serial number: 00000000540912
   VCID: 3467559C9727A681BA7-8061
Address 55: Headlight Range
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335AU0A7547550
   Coding: 020000020100000001
   VCID: 1D31903804AD07C9659-8048
02246 - Loudspeaker; Center
                    Fault Status: 01101011
                    Reset counter: 92
                    Mileage: 87960 km
                    Date: 2015.05.30
                    Time: 17:07:44
                    Voltage: 11.80 V
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 664 B    HW: 8T1 035 664 B
   Component: H-BN-NA       H47 0042
   Revision: --------    Serial number: 490AW0A7543554
   Coding: 010200000006A1EF01000B0E000000030000
   VCID: 377D629086514D999F5-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000102685070
   Coding: 010C03204000210001
   VCID: 428B0344DD93183138B-8017
   Revision: --H03---    Serial number: 525PA8-J9Z90PW
   Coding: 1000006
   VCID: 387F61AC4B4F42E196F-806D
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000102685067
End-------------------------(Elapsed Time: 03:11)--------------------------
B82010
C?ID=248569
when i ran the individual component output tests, this is the one that would turn the Compressor on briefly and blow cold air for the 1st time since i have owned the car !
as you can see, the current to it was going from 0 up to .7 and back to 0 constantly back and forward(not sure if that is how the output test works by sending signal then stopping then sending)
[/URL][/IMG]
[/URL][/IMG]
Sounds to me like a weak battery is in history here....
You have a COM error between the monitoring of the J519 watching the load circuit....... with load management override.
Correct the voltages and communications and it should be okay.
Check with meter or wiggle tests of the twisted pair between........ to gateway......verify via WD and with AID of VCDS advanced measuring blocks while logging!
B82010
C?ID=248569
thanks for the reply!
I have NO idea what a lot of that means unfortunately, I just got my VAGCOM today, barely even know how to use it, certainly dont know yet how to do measuring blocks.
What twisted pair are you speaking of?
I tested the three wires from the Pressure sensor G395 to J519 and they read voltage, but multiple Audi techs told me a LIN based system is pointless to use a Multimeter on.
So I am still stumped at this point as what I personally can do or try
B82010
C?ID=248569
Others that threw these same codes, just changed their pressure sensors and fixed the issue. The TSB I followed said that is the number 1 reason for these codes and the no Compressor kicking on/no cold air.
and/or the TSB mentions the LIN cable from G395 press sensor being cut and causing that, but I put a temporary jump wire from the Sensor to 1inch away from the j519 unit, and no luck (although i did not have vagcom then so maybe I had to erase the faults once the Jump wire was in?)
You must get the repair manual ......
Twisted pair means CAN/HIGH/LOW Network cable.
You need to review WD in repair manual and observe the TSB, as well as general testing procedures.
or seek a professionals aid and open wallet.
The tool is not a substitute for not having the repair manual.........and jumping stuff out isn't advised because you are gonna have a bad time.
B82010
C?ID=248569
ty again for the fast reply man.
Ross_tech said if no one could help me figure it out through these forums By Monday that I can call in and they will go over it with me to try and diagnose it. I will wait till then before I spend any more money on anything.
I Bought a Genuine Audi manual, and all it shows is how to remove or replace things, does not have any wiring diagrams or testing procedures whatsoever which certainly pissed me off. That is how I learned about the TSB and the sensor and LIN wire issue.
If there was a way that I could Use the VAGCOM to see if the Sensor was sending signal to the J519 unit, then I could cross off the sensor itself AND the LIN wire being an issue.
I still have a strong feeling that it is the Sensor, I got it off Ebay and they said it was "Original Equipment" but when I showed it to the Audi tech he said it is just a generic company sensor...
golfi_vend
Tartu, Estonia
C?ID=195131
Hey in this thread.
Jack why are you suggesting checking can wires? Fault code just suggest to go to 0x09 and check 02.
(For those who didn't understand: http://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000 )
Only weird issue is why isnt 55 - headlights range accessible.
Output test window.
One window shows specified amperage and second shows the actual amperage.
Because you would be surprised what happens when DTC's float on the network, causing disruptions for communications.
It is most likely a faulty sensor with a damaged harness as per TSB......... but it is not always.
I do stupid things....... like create shorts/opens and feedback to each pin or junctions .......then document in my own journals for what DTC's they create.
I have found that when certain DTC's are on bus, they create triggers to turn things off or impair functions in other modules.
I know ....I know I am boring people now with my nerd ways.
Exactly::p
B82010
C?ID=248569
Jack,Im not sure why or what "Oh boy FOD here we go" means, I am sorry that I Just got the cable and have not figured it all out already, I apologized in advance for being new.
As far as the Headlight range, thats because we pulled the fuse so it wouldn't show on the dash, until the new control device comes in next week.
I will pay someone if they can help briefly walk me through the measuring blocks, or whatever is needed to check the communication issue.
Again, thank you guys for any and all help!
B82010
C?ID=248569
If that came off as me sounding like a smart a$$, it was not AT ALL meant to lol. when i went back and read what I wrote, it certainly could be taken the wrong way, which was NOT my intention.
I truly am appreciative, and am desperate to figure out this issue, this being my only car, and it being above 90 outside everyday now, is HORRIBLE. Im a realtor so I cant even drive people around in my car because of this
golfi_vend
Tartu, Estonia
C?ID=195131
Measuring blocks - MVB for shrort.
You can learn about it from here:
http://www.ross-tech.com/vcds/tour/m-blocks.html
But your car being so new i would assume, it doesn't have the old style MVB, only advanced MVB.
http://www.ross-tech.com/vcds/tour/adv-meas-blocks.html
Correction. Your car climate control doesn't have label file. Didn't notice that before. You can learn about label files here: http://www.ross-tech.com/vag-com/labels.html
and here: http://wiki.ross-tech.com/wiki/index.php/Control_Module_Maps
B82010
C?ID=248569
Sunday,31,May,2015,12:55:10:07369
VCDS Version: 14.10.2.0 (x64)
Address 08: Auto HVAC (8T1 820 043 AQ)
12:55:08 Group 001
0.000 A Current
0.000 A Current
ERROR
12:55:08 Group 002
13.0 (no units)
7.0 (no units)
13.0 (no units)
7.0 (no units)
12:55:08 Group 003
0.0 (no units)
0.0 (no units)
0.0 (no units)
12:55:21 Group 004
11917 Count
11917 Count
10000 Count
11917 Count
12:55:21 Group 005
00000101 Bin. Bits
00000000 Bin. Bits
00001011 Bin. Bits
100.0 % Load
12:55:21 Group 006
10000 Count
10000 Count
10000 Count
11233 Count
12:55:33 Group 007
00111101 Bin. Bits
00000000 Bin. Bits
10000011 Bin. Bits
0.0 % Load
12:55:33 Group 008
10000 Count
10000 Count
10000 Count
11629 Count
12:55:33 Group 009
00000101 Bin. Bits
00000000 Bin. Bits
00001001 Bin. Bits
0.0 % Load
12:55:55 Group 010
15831 Count
15831 Count
10000 Count
15831 Count
12:55:55 Group 011
00111101 Bin. Bits
00000000 Bin. Bits
10001001 Bin. Bits
100.0 % Load
12:55:55 Group 012
15825 Count
15825 Count
10000 Count
15825 Count
B82010
C?ID=248569
that was with the car running, and the AC button switched to ON
I imagine the very first group 01 Saying ERROR is a bad thing?
B82010
C?ID=248569
sorry Golfi I didnt see that you said 0x09 02, here is that log (with car on)
Sunday,31,May,2015,18:24:03:07369
Mileage: Repair Order: 09x02 log
Address 09: Cent. Elect. (8K0 907 063 P)
18:23:50 Group 001
13.50 V Voltage
13.50 V Voltage
N/A
N/A
18:23:50 Group 002
13.50 V Voltage
13.50 V Voltage
13.60 V Voltage
N/A
18:23:50 Group 003
Inactive
Inactive
Inactive
N/A
B82010
C?ID=248569
Anyone? :-/
B82010
C?ID=248569
Just got a pressure sensor from the dealer this morning Jack, No luck.
If anyone wouldnt mind telling me if I did the proper measuring blocks (for the DTC's it called for) Then I could cross that off the list as well as far as the communication error right?
